I am very new, I am trying to import my passwords from windows chrome as a csv file into chromium version 108.0.5359.124 (Official Build) Arch Linux (64-bit).
The import/export features are turned off by default. I found a command line (I know very little about command line) that was supposed to turn these features on but all I get is an error about "no sandbox". Looking up what to do with that, I found someone saying to add "no sandbox" to the chromium app properties but I can't figure out how to get into that. All I want is to be able to import the passwords without having to manually do so.
╭─[email protected] in ~
╰─λ sudo chromium --flag-switches-begin --enable-features=PasswordImport --flag-switches-end
[sudo] password for laura:
[6114:6114:1230/192724.906140:ERROR:zygote_host_impl_linux.cc(100)] Running as root without --no-sandbox is not supported. See https://crbug.com/638180.
╭─[email protected] in ~ as 🧙 took 6s
[🔴] × garuda-inxi
Kernel: 6.1.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=4b9f847b-2370-4a10-b94f-f73f20a55106 rw [email protected]
loglevel=3 ibt=off
Desktop: Cinnamon v: 5.6.5 tk: GTK v: 3.24.36 wm: muffin vt: 7 dm: LightDM
v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Micro product: G113 v: 1.0
Mobo: Micro-Star model: PRO H610M-G DDR4 (MS-7D46) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.M3
date: 07/18/2022
Info: model: 12th Gen Intel Core i5-12400F bits: 64 type: MT MCP
microcode: 0x26
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 2216 high: 2500 min/max: 800/5600 scaling:
driver: intel_pstate governor: powersave cores: 1: 2500 2: 800 3: 2500
4: 2500 5: 2500 6: 2500 7: 800 8: 2500 9: 2500 10: 2500 11: 2500 12: 2500
bogomips: 59904
Device-1: Intel DG2 [Arc A380] vendor: ASRock driver: i915 v: kernel
arch: Gen-12.7 code: Alchemist process: TSMC n6 (7nm) built: 2022+ pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 ports: active: HDMI-A-1,HDMI-A-2
empty: DP-1, DP-2, DP-3, HDMI-A-3, HDMI-A-4 bus-ID: 03:00.0
chip-ID: 8086:56a5 class-ID: 0300
Display: x11 server: X.Org v: 21.1.6 driver: X: loaded: modesetting
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,left
model: Gigabyte G24F 2 serial: <filter> built: 2022 res: 1920x1080 hz: 60
dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 595mm (23.4")
Monitor-2: HDMI-A-2 mapped: HDMI-2 pos: right model: BenQ GW2485TC
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
missing.
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: Intel vendor: ASRock driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:4f92
Sound API: ALSA v: k6.1.1-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: N/A
modules: e1000e port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1d class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 06:00.0
IF: wlp6s0 state: up mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-14:5 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 931.52 GiB used: 16.21 GiB (1.7%)
model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 234110WD temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
used: 16.21 GiB (3.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.48 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 321 Uptime: 48m wakeups: 0 Memory: 15.48 GiB
used: 3.33 GiB (21.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1382
libs: 368 tools: octopi,pamac,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.24
Garuda (2.6.12-1):
System install date: 2022-12-27
Last full system update: 2022-12-29
