Enabling G-Sync on "Unvalidated monitor"
Kernel: 6.6.0-AMD-znver3 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver3
root=UUID=0e15d879-199f-4a32-bf42-2353804e1470 rw rootflags=subvol=@
quiet resume=UUID=7b9b8ca6-2b28-46e0-a79e-d08d96485f78 loglevel=3 ibt=off
Type: Desktop System: Alienware product: Alienware Aurora Ryzen Edition
v: 2.4.2 serial: <superuser required> Chassis: type: 3
Mobo: Alienware model: 0TYR0X v: A00 serial: <superuser required>
UEFI: Alienware v: 2.4.2 date: 07/03/2023
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201025
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3787 high: 3800 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 3800
3: 3800 4: 3800 5: 3800 6: 3800 7: 3800 8: 3593 9: 3800 10: 3800 11: 3800
12: 3800 13: 3800 14: 3800 15: 3800 16: 3800 bogomips: 121422
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: Dell
driver: nvidia v: 545.29.02 alternate: nvidia_drm non-free: 545.xx+
status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 8 link-max: lanes: 16 bus-ID: 0b:00.0 chip-ID: 10de:2216
Device-2: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-14:7
chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 5280x2560 s-dpi: 110 s-size: 1219x596mm (47.99x23.46")
s-diag: 1357mm (53.42")
Monitor-1: DP-0 pos: left res: 1440x2560 dpi: 109
size: 336x598mm (13.23x23.54") diag: 686mm (27.01") modes: N/A
Monitor-2: DP-4 pos: primary,right res: 3840x1600 dpi: 111
size: 880x370mm (34.65x14.57") diag: 955mm (37.58") modes: N/A
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
memory: 9.77 GiB
API: Vulkan v: 1.3.269 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3080 driver: nvidia v: 545.29.02
device-ID: 10de:2216 surfaces: xcb,xlib
Device-1: NVIDIA GA102 High Definition Audio vendor: Dell
link-max: lanes: 16 bus-ID: 0b:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Dell driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.4
chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS Arctis 7 wireless adapter
lanes: 1 mode: 1.1 bus-ID: 1-12.1:8 chip-ID: 1038:1260 class-ID: 0300
Device-4: Texas Instruments PCM2704 16-bit stereo audio DAC
lanes: 1 mode: 1.1 bus-ID: 1-12.2:9 chip-ID: 08bb:2704 class-ID: 0300
Device-5: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.6.0-AMD-znver3 status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
Device-1: Realtek driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:2600 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:11 chip-ID: 8087:0029
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 3.64 TiB used: 213.45 GiB (5.7%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 51.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA200
tech: HDD rpm: 7200 serial: <filter> fw-rev: AC70 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
ID-1: / raw-size: 896.83 GiB size: 896.83 GiB (100.00%)
used: 213.45 GiB (23.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 896.83 GiB size: 896.83 GiB (100.00%)
ID-4: /var/log raw-size: 896.83 GiB size: 896.83 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.83 GiB size: 896.83 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.28 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 69.0 C mobo: N/A gpu: nvidia temp: 60 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 32%
Processes: 353 Uptime: 23m wakeups: 0 Memory: total: 32 GiB
available: 31.28 GiB used: 3.31 GiB (10.6%) Init: systemd v: 254
pm: pacman pkgs: 1851 libs: 550 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.17-1):
System install date:     2023-11-06
Last full system update: 2023-11-06
I read somewhere that the newer versions of Plasma will automatically enable vrr when an application is running in full screen. I just wanted to validate if that is true for KDE Dragonized Gaming Edition.
If it isn’t, is there a preferred method for enabling G-Sync on an “unvalidated” monitor? When I use nvidia-settings to enable G-Sync it screws up the fonts in non-KDE applications. I’ve been able to fix that somewhat, but apps like Brave still don’t appear “normal.”
