Hello,
Kernel: 6.1.5-arch2-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux root=UUID=b6611412-3db3-4a22-9d8c-edc4a4424df6 rw
[email protected] quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
resume=UUID=ff91a649-2990-43d3-a552-a78edf138d2a loglevel=3 ibt=off
Console: tty 1 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: HP product: HP EliteBook 845 14 inch G9 Notebook PC v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: HP model: 8990 v: KBC Version 09.48.00 serial: <filter> UEFI: HP v: U82 Ver. 01.03.01
date: 10/19/2022
ID-1: BAT0 charge: 45.0 Wh (90.4%) condition: 49.8/51.3 Wh (97.1%) volts: 13.1 min: 11.6
model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: charging cycles: 6
Info: model: AMD Ryzen 7 6800U with Radeon Graphics socket: FP7 bits: 64 type: MT MCP
arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm) family: 0x19 (25)
model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1668 high: 2700 min/max: 1600/4767 boost: enabled base/boost: 2700/4750
scaling: driver: acpi-cpufreq governor: schedutil volts: 1.2 V ext-clock: 100 MHz cores: 1: 2700
2: 1600 3: 1600 4: 1600 5: 1600 6: 1600 7: 1600 8: 1600 9: 1600 10: 1600 11: 1600 12: 1600
13: 1600 14: 1600 15: 1600 16: 1600 bogomips: 86279
Device-1: AMD Rembrandt [Radeon 680M] vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, HDMI-A-1
bus-ID: e3:00.0 chip-ID: 1002:1681 class-ID: 0300 temp: 34.0 C
Device-2: Chicony HP 5MP Camera type: USB driver: uvcvideo bus-ID: 5-1:2 chip-ID: 04f2:b738
Display: server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7 driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa dri: radeonsi gpu: amdgpu tty: 192x60
Monitor-1: eDP-1 model: AU Optronics 0xa49a built: 2021 res: 1920x1200 dpi: 162 gamma: 1.2
size: 301x188mm (11.85x7.4") diag: 355mm (14") ratio: 16:10 modes: max: 1920x1200 min: 640x480
API: OpenGL Message: GL data unavailable in console and glxinfo missing.
Device-1: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: e3:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard driver: snd_pci_acp6x
v: kernel
alternate: snd_pci_acp3x,snd_rn_pci_acp3x,snd_pci_acp5x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: e3:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: e3:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.1.5-arch2-1 running: yes
Sound Server-2: PipeWire v: 0.3.64 running: no
Device-1: Qualcomm QCNFA765 Wireless Network Adapter vendor: Foxconn driver: ath11k_pci
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 17cb:1103 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
Device-1: Foxconn / Hon Hai type: USB driver: btusb v: 0.8 bus-ID: 1-3:4 chip-ID: 0489:e0d6
Report: bt-adapter note: tool can't run ID: hci0 rfk-id: 2 state: down
bt-service: enabled,stopped rfk-block: hardware: no software: no address: N/A
Local Storage: total: 1.82 TiB used: 113.58 GiB (6.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P5PSSD8 size: 1.82 TiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: P7CR403 temp: 27.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: HP model: v125w size: 3.73 GiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 4096 scheme: MBR
ID-1: / raw-size: 442.9 GiB size: 442.9 GiB (100.00%) used: 113.16 GiB (25.6%) fs: btrfs
block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 608 KiB (0.2%) fs: vfat
block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 442.9 GiB size: 442.9 GiB (100.00%) used: 113.16 GiB (25.6%) fs: btrfs
ID-4: /var/log raw-size: 442.9 GiB size: 442.9 GiB (100.00%) used: 113.16 GiB (25.6%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 442.9 GiB size: 442.9 GiB (100.00%) used: 113.16 GiB (25.6%)
ID-1: swap-1 type: partition size: 33.74 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 30.67 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 34.9 C mobo: N/A gpu: amdgpu temp: 35.0 C
Processes: 302 Uptime: 12m wakeups: 512 Memory: 30.67 GiB used: 919.9 MiB (2.9%) Init: systemd
v: 252 default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages:
pm: pacman pkgs: 1688 libs: 373 tools: pamac,paru Shell: Bash v: 5.1.16 running-in: tty 1
inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-01-01
Last full system update: 2023-01-14
Relevant software: snapper mkinitcpio
Failed units: data.mount systemd-modules-load.service systemd-sysctl.service
I successfully installed Garuda Linux (GNOME) on my HP Elitebook 845 G9 a few weeks ago. It came with a small 500Gb NVME drive that I wanted to swap with larger 2Tb drive.
I cloned my 500Gb SSD using a newly downloaded Clonezilla, to a larger 2Tb SSD (attached via a USB adapter) (both NVME Gen 4). Everything appeared to go smoothly, and then I turned the system off, and swapped the smaller drive out for the larger one.
I tried to boot up my Linux system. But while it showed the GRUB menu, after showing the Garuda eagle and then a black screen, it put me quickly into emergency mode and asking for the root password.
When I looked at the logs using journalctl -xb | grep error, I see a bunch of references to "BTRFS error (device nvm0n1p2): bad tree block start, mirror 1 want XXXXXX have 0
" where XXXX is a variety of large numbers.
I looked at /etc/fstab and checked the UUIDs of all the mounts/subvolumes and the SWAP (I have a swap partition) and it all looks correct.
Update: I was able to boot the system after commenting out a subvolume mount that I had created @data. But trying to list the subvolumes on my machine led to "Error: failed to lookup path for root 263: Input/output error" and trying BTRFS scrub shows 66 uncorrectable csum errors (yikes!!)
I suppose I could nuke the system and start from scratch (I have good backups of my files). But how could mere cloning a drive lead to BTRFS errors? Is this normal?
