Hi, I'm just having trouble updating my system because of conflicts:
garuda 75.7 KiB 151 KiB/s 00:01 [----------------------] 100%
core 157.4 KiB 568 KiB/s 00:00 [----------------------] 100%
extra 1721.3 KiB 3.15 MiB/s 00:01 [----------------------] 100%
community 6.7 MiB 5.24 MiB/s 00:01 [----------------------] 100%
multilib 172.6 KiB 568 KiB/s 00:00 [----------------------] 100%
chaotic-aur 1889.6 KiB 1724 KiB/s 00:01 [----------------------] 100%
spawn pacman -Su
warning: glib2: ignoring package upgrade (2.70.4-1 => 2.72.3-1)
resolving dependencies...
:: installing electron (19.0.8-1) breaks dependency 'electron18' required by code
Some software that I use relies on electron18 but I still need to update my system
Kernel: 5.18.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=5411b7ff-d53c-4780-9b50-82a7b4183826 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: Acer product: Nitro AN515-57 v: V1.17
Mobo: TGL model: Scala_TLS v: V1.17 serial: <superuser required>
UEFI: Insyde v: 1.17 date: 06/02/2022
ID-1: BAT1 charge: 54.0 Wh (100.0%) condition: 54.0/57.5 Wh (93.9%)
volts: 17.4 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
status: full cycles: 227
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm family: 6
model-id: 0x8D (141) stepping: 1 microcode: 0x3E
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 919 high: 1282 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 1019 2: 1025 3: 1282
4: 813 5: 1060 6: 801 7: 870 8: 786 9: 800 10: 769 11: 847 12: 800
13: 801 14: 762 15: 1259 16: 1016 bogomips: 73728
Device-1: Intel TigerLake-H GT1 [UHD Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen12.1
process: Intel 10nm built: 2020-21 ports: active: eDP-1 empty: DP-1,DP-2
bus-ID: 0000:00:02.0 chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 515.57
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 bus-ID: 0000:01:00.0 chip-ID: 10de:25a2 class-ID: 0300
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 3-9:3
chip-ID: 0408:a061 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: intel,nvidia
unloaded: modesetting,nouveau,vesa alternate: fbdev,nv gpu: i915
Monitor-1: eDP-1 mapped: eDP1 model: ChiMei InnoLux 0x1521 built: 2020
res: 1920x1080 hz: 144 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.3
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Acer Incorporated ALI
bus-ID: 0000:00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:2291 class-ID: 0403
Sound Server-1: ALSA v: k5.18.10-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.54 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:43f0
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
port: 3000 bus-ID: 0000:2c:00.0 chip-ID: 10ec:2600 class-ID: 0200
IF: enp44s0 state: down mac: <filter>
bus-ID: 3-14:4 chip-ID: 8087:0026 class-ID: e001
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev:
class-ID: 0104
Local Storage: total: 2.29 TiB used: 1.15 TiB (50.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX016N
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41020C20
temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-1: / raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
used: 254.99 GiB (85.7%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 50.6 MiB (52.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
ID-4: /var/log raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
ID-5: /var/tmp raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.41 GiB used: 0 KiB (0.0%) priority: 100
Message: No sensor data found. Is lm-sensors configured?
Processes: 364 Uptime: 10m wakeups: 4 Memory: 15.41 GiB
used: 4.33 GiB (28.1%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 2077
lib: 528 Shell: Bash v: 5.1.16 running-in: terminator inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-02-16
Last full system update: 2022-07-09
