EGPU switching hooks would also be helpful along with hybrid GPU switching
Firestorm is not able to see GPD EGPU 7600XT so it does not use it.
Seemed to work fine in Cyberpunk 2077 or possibly was working.
In windows there is a driver hook that shows connection to the EGPU on power on after windows detects it. This is likely missing in the Linux AMD Driver. Looking into which project or projects this falls under.
Also noticed the CPU only has 1 core showing up. Is that normal? There is no issue with the hardware it seems to be working as intended so far.
Also still trying to test the GPD EGPU to make sure it is working as intended.
Much appreciated.
Kernel: 6.17.13-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 15.2.1 clocksource: tsc avail: hpet,acpi_pm parameters: pti=on
root=UUID=eb0284d7-2336-46a1-85b4-47a90c730cdb rw rootflags=subvol=@
quiet rd.luks.uuid=2794a39d-6cb8-4ec5-b4e9-86ce6c7ff2f9 loglevel=3
Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
Type: Laptop System: ASUSTeK product: ASUS Zenbook 14 UM3406HA_UM3406HA
Mobo: ASUSTeK model: UM3406HA v: 1.0 serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
v: UM3406HA.306 date: 10/08/2024
ID-1: BAT0 charge: 67.3 Wh (100%) condition: 67.3/75 Wh (89.7%) volts: 17.41
min: 16.03 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A charging:
status: full control: start: N/A end: 100% cycles: 65
Device-1: ps-controller-battery-14:3a:9a:84:09:6f model: N/A serial: N/A
charge: N/A status: full
Info: model: AMD Ryzen 7 8840HS w/ Radeon 780M Graphics bits: 64
process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x75 (117) stepping: 2
microcode: 0xA705208
Speed (MHz): avg: 1330 min/max: 419/5135 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1330 2: 1330 3: 1330
4: 1330 5: 1330 6: 1330 7: 1330 8: 1330 9: 1330 10: 1330 11: 1330 12: 1330
13: 1330 14: 1330 15: 1330 16: 1330 bogomips: 105401
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Navi 33 [Radeon RX 7600/7600
XT/7600M XT/7600S/7700S / PRO W7600] vendor: IP3 Tech driver: amdgpu
v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n6 (6nm) built: 2023+
pcie: gen: 4 speed: 16 GT/s lanes: 8 ports: active: none empty: DP-8,
DP-9, HDMI-A-2, Writeback-2 bus-ID: 07:00.0 chip-ID: 1002:7480
Device-2: Advanced Micro Devices [AMD/ATI] HawkPoint1 vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, HDMI-A-1, Writeback-1
bus-ID: 63:00.0 chip-ID: 1002:1900 class-ID: 0300 temp: 51.0 C
Device-3: Shinetech USB2.0 FHD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 3277:0055
Device-4: USB C Video Adaptor driver: N/A type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-1.2.3:6 chip-ID: 25a4:9411
class-ID: 1100 serial: <filter>
Monitor-1: eDP-1 model: Samsung 0x41a0 built: 2022 res: mode: 1920x1200
hz: 60 scale: 100% (1) dpi: 161 gamma: 1.2 size: 302x189mm (11.89x7.44")
diag: 356mm (14") ratio: 16:10 modes: max: 1920x1200 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M Graphics (radeonsi
phoenix LLVM 21.1.6 DRM 3.64 6.17.13-hardened1-1-hardened)
device-ID: 1002:1900 memory: 500 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.335 layers: 10 device: 0 type: integrated-gpu name: AMD
Radeon 780M Graphics (RADV PHOENIX) driver: mesa radv v: 25.3.3-arch1.1
device-ID: 1002:1900 surfaces: N/A device: 1 type: discrete-gpu name: AMD
Radeon RX 7600M XT (RADV NAVI33) driver: mesa radv v: 25.3.3-arch1.1
device-ID: 1002:7480 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 21.1.6 256 bits) driver: mesa llvmpipe v: 25.3.3-arch1.1 (LLVM
bus-ID: 07:00.1 chip-ID: 1002:ab30 class-ID: 0403
bus-ID: 63:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Audio Coprocessor vendor: ASUSTeK
bus-ID: 63:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: ASUSTeK
bus-ID: 63:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-5: Sony DualSense wireless controller (PS5)
driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 7-1.1:8 chip-ID: 054c:0ce6 class-ID: 0300
API: ALSA v: k6.17.13-hardened1-1-hardened status: kernel-api tools: N/A
lanes: 1 bus-ID: 01:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
Device-2: Sony DualSense wireless controller (PS5)
Device-3: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 8-1.2.1:4
chip-ID: 0b95:1790 class-ID: 0a00 serial: <filter>
IF: eth0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0489:e0f5
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.4 lmp-v: 13
Local Storage: total: 1.82 TiB used: 22.77 GiB (1.2%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 45.9 C
ID-2: /dev/sdc maj-min: 8:32 vendor: Transcend model: N/A size: 1.87 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: TS37
scheme: MBR
ID-1: / raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
used: 22.7 GiB (15.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-2794a39d-6cb8-4ec5-b4e9-86ce6c7ff2f9
ID-2: /boot/efi raw-size: 200 MiB size: 196 MiB (98.00%)
used: 64 MiB (32.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
ID-4: /var/log raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
ID-5: /var/tmp raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.91 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 61.4 C mobo: 40.0 C
Fan Speeds (rpm): fan-1: 2204
GPU: device: amdgpu temp: 55.0 C watts: 21.05 device: amdgpu temp: 34.0 C
mem: 42.0 C fan: 0 watts: 3.00
Memory: total: 16 GiB note: est. available: 14.91 GiB used: 4.71 GiB (31.6%)
Processes: 541 Power: uptime: 23m states: freeze,mem suspend: s2idle
wakeups: 0 services: org_kde_powerdevil, power-profiles-daemon, upowerd
Init: systemd v: 259 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1480 libs: 395 tools: octopi,paru Compilers:
clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.9 default: fish v: 4.3.3
running-in: konsole inxi: 3.3.40
Garuda (2.11.1-1):
System install date:     2025-12-30
Last full system update: 2026-01-08
Failed units:            nmb.service
25/26 checks run in 0.65 seconds ⌛
Powered by garuda-health 🦅
--- LOW ---
- Failed systemd services found: nmb.service
Wrong and right !! lol Yes it shows “only” 1x cpu (you have only one with 8x “real” and 8x"smt" kernels.
Egpus in Linux are very specialized and not so easy to integrate into a system but if you’re also using such a kernel, you shouldn’t be surprised that it doesn’t work.
Perhaps with another kernel (zen, lts or znver4), can’t test this reason no metal.
As Info:
and default the DE works with your igpu not with dgpu or egpu. Think on this.
You need then prime.
Arch is actually seeing it; thunderbolt 4/usb bridge is functioning as intended; working in Steam just not being seen by Firestorm; which also does not see the discrete NVIDIA graphics card on another laptop; just uses the 680m on the AMD APU.
Again: !!Install prime!!
in Terminal then : prime-run “command” and then ?
This is not a valid solution for AMD GPUs.
@shelled, please look at the Garuda Linux wiki carefully. Your use case is described. Switching between integrated and dedicated graphics | Garuda Linux wiki
It doesn’t though:
Yes prime-run is wrong..sorry
if example for /bash/fish : DRI_PRIME=1 /usr/bin/vlc
Also possible is a environment (global) in /etc/environment = DRI_PRIME=1
or a export in bashrc / config.fish = export DRI_PRIME=1
I have a alias on my laptop, that’s why. :person_gesturing_no:
On some desktop motherboards there is a setting to disable the igpu that has worked for one.
New hyrbid graphics setups that are all AMD should be able to use both cards simultaneously.
AMD driver is open source so this should be possible for older setups too possibly.
Kernel: 6.17.13-hardened1-2-hardened arch: x86_64 bits: 64 compiler: gcc
root=UUID=255ad231-e2c1-403b-82c1-92e5ff8d19af rw rootflags=subvol=@
quiet rd.luks.uuid=ea4bba1c-8a33-4594-9183-99b5bf7b46b0 loglevel=3
Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0
Mobo: ASUSTeK model: ROG STRIX B850-I GAMING WIFI v: Rev 1.xx
Firmware: UEFI vendor: American Megatrends v: 1022 date: 03/05/2025
Info: model: AMD Ryzen 7 8700G w/ Radeon 780M Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x75 (117) stepping: 2 microcode: 0xA70520A
Speed (MHz): avg: 2991 min/max: 423/5177 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2991 2: 2991 3: 2991
4: 2991 5: 2991 6: 2991 7: 2991 8: 2991 9: 2991 10: 2991 11: 2991 12: 2991
13: 2991 14: 2991 15: 2991 16: 2991 bogomips: 134388
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT /
7800 XT] vendor: XFX driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,DP-3 empty: DP-2,HDMI-A-1,Writeback-1 bus-ID: 03:00.0
chip-ID: 1002:747e class-ID: 0300
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 6880x1440
display-ID: 0
Monitor-1: DP-1 pos: primary,left model: Samsung S34CG50 serial: <filter>
built: 2024 res: mode: 3440x1440 hz: 100 scale: 100% (1) dpi: 109 gamma: 1.2
size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes: max: 3440x1440
min: 720x400
Monitor-2: DP-3 pos: right model: Samsung S34CG50 serial: <filter>
min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
navi32 LLVM 21.1.6 DRM 3.64 6.17.13-hardened1-2-hardened)
device-ID: 1002:747e memory: 15.62 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.335 layers: 6 device: 0 type: discrete-gpu name: AMD
Radeon RX 7800 XT (RADV NAVI32) driver: mesa radv v: 25.3.3-arch1.2
device-ID: 1002:747e surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.6 256 bits) driver: mesa llvmpipe v: 25.3.3-arch1.2 (LLVM
Device-2: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
chip-ID: 0b05:1be1 class-ID: 0300
API: ALSA v: k6.17.13-hardened1-2-hardened status: kernel-api tools: N/A
Device-1: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0 chip-ID: 8086:125c
Device-2: MEDIATEK MT7925 802.11be 160MHz 2x2 PCIe Wireless Network
Adapter [Filogic 360] vendor: AzureWave driver: mt7925e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0b:00.0 chip-ID: 14c3:7925
IF: wlp11s0 state: down mac: <filter>
Local Storage: total: 2.73 TiB used: 15.81 GiB (0.6%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 48.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-3: /dev/sdb maj-min: 8:16 vendor: Transcend model: N/A size: 1.87 GiB
scheme: MBR
ID-1: / raw-size: 173.61 GiB size: 173.61 GiB (100.00%)
used: 15.78 GiB (9.1%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ea4bba1c-8a33-4594-9183-99b5bf7b46b0
used: 32 MiB (16.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 173.61 GiB size: 173.61 GiB (100.00%)
ID-4: /var/log raw-size: 173.61 GiB size: 173.61 GiB (100.00%)
ID-5: /var/tmp raw-size: 173.61 GiB size: 173.61 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.45 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 54.5 C mobo: 49.0 C gpu: amdgpu temp: 66.0 C
mem: 68.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 797
Memory: total: 64 GiB available: 62.45 GiB used: 3.25 GiB (5.2%)
Processes: 429 Power: uptime: 0m states: freeze,mem suspend: deep
avail: s2idle wakeups: 0 services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1302 libs: 339 tools: octopi,paru Compilers:
gcc: 15.2.1 Shell: Bash v: 5.3.9 default: fish v: 4.3.3 running-in: konsole
inxi: 3.3.40
Garuda (2.12.3-2):
System install date:     2026-01-17
Last full system update: 2026-01-17
This is not correct for your hardware. You don’t have these kind of metal.
Hybrid mode means the dgpu works “over” the igpu.
This is not possible with your metal. You have a igpu + egpu.
as Info:
