Osprey
5 February 2024 13:01
1
IS it a problem for the efivars directory to be full?
Machine seems to be running normally.
df- h reports
Filesystem Size Used Avail Use% Mounted on
efivarfs 256K 252K 0 100% /sys/firmware/efi/efivars
If I need to cull this directory is there any guidance?
I don’t think I can enlarge this partition as it is at the start of the disk… and was setup by the Garuda Installer…
Bro
5 February 2024 13:07
2
Delete some of the old/unused ones from your BIOS. They can accumulate.
filo
5 February 2024 13:15
3
If present, for sure you should delete the dump files /sys/firmware/efi/efivars/dump-*.
And, please, always provide your garuda-inxi, as required in the topic template.
E.g. do you dual/multiple boot? If so, make sure to delete old unused bootloaders.
Osprey
5 February 2024 13:42
4
Thank you for jogging my memory!
Had a problem with debian12 and ran efibootmgr revealing 16 old entries (including old irrelevant windows bootloaders).
I have a dual boot with Garuda KDE lite on a 2TB nvme and ARCH LTS in a 3TB HDD (which I use for testing and maitenance/backups etc.)
This is the current list:
efibootmgr
BootCurrent: 0000
Timeout: 1 seconds
BootOrder: 0000,0008,0007,0001,0002,0003,0009,0004,0005,0006
Boot0000* Garuda HD(1,GPT,18c64e2b-3a27-4b28-9d5e-5aaed1f112c5,0x1000,0x96000)/\EFI\Garuda\grubx64.efi
Boot0001* Diskette Drive BBS(Floppy,Diskette Drive,0x0)0000424f
Boot0002* KINGSTON SNV2S2000G BBS(HD,KINGSTON SNV2S2000G,0x0)0000424f
Boot0003* P0: ST3000DM001-9YN166 BBS(HD,P0: ST3000DM001-9YN166,0x0)0000424f
Boot0004* USB Storage Device BBS(USB,USB Storage Device,0x0)0000424f
Boot0005* CD/DVD/CD-RW Drive BBS(CDROM,P1: HL-DT-ST DVD+/-RW GU90N,0x0)0000424f
Boot0006 Onboard NIC BBS(Network,IBA CL Slot 00FE v0106,0x0)0000424f
Boot0007* UEFI: ST3000DM001-9YN166 HD(1,GPT,89c72213-bbf9-46fd-9678-d3227fc11483,0x800,0xff800)/EFI\boot\bootx64.efi0000424f
Boot0008* Arch 3TB PciRoot(0x0)/Pci(0x17,0x0)/Sata(0,65535,0)/HD(1,GPT,89c72213-bbf9-46fd-9678-d3227fc11483,0x800,0xff800)/\EFI\BOOT\BOOTX64.EFI
Boot0009* P2: WDC WD30EZRZ-00WN9B0 BBS(HD,P2: WDC WD30EZRZ-00WN9B0,0x0)0000424f
Boot0010* CD/DVD/CD-RW Drive BBS(CDROM,P1: HL-DT-ST DVD+/-RW GU90N,0x0)0000424f
Boot0011 Onboard NIC BBS(Network,Onboard NIC,0x0)0000424f
Boot0012* KINGSTON SNV2S2000G BBS(HD,KINGSTON SNV2S2000G,0x0)0000424f
Boot0013* P0: ST3000DM001-9YN166 BBS(HD,P0: ST3000DM001-9YN166,0x0)0000424f
Boot0014* UEFI: ST3000DM001-9YN166 HD(1,GPT,89c72213-bbf9-46fd-9678-d3227fc11483,0x800,0xff800)/EFI\boot\bootx64.efi0000424f
Boot0015* UEFI: HL-DT-ST DVD+/-RW GU90N PciRoot(0x0)/Pci(0x17,0x0)/Sata(1,65535,0)/CDROM(1,0xc1373,0x2000)0000424f
I am running in Boot0000*
Boot0003*, Boot0007*, Boot0008*,Boot0008*,Boot0014* all appear to point to the ARCH LTS drive.
I think Boot0008* is the only one I created. The others are automatic from the Dell OptiPlex 7040 bios.
Garuda is running beautifully and I really don’t want to run into boot issues as this is a preventative issue.
NOTE: The Garuda Grub does not properly boot the ARCH LTS so I do that via f12 at startup. This might fix that too?
Appreciate any assistance before I break a beautiful set up.
Osprey
5 February 2024 13:47
5
Filo: Apologies, I didn’t think the question warranted the inxi as the efivars issue is not causing any errors or problems, but might!.
I just thought it can’t be good to overflow that directory.
inxi -Fxxxza
Kernel: 6.7.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=799058ae-c22b-4474-a408-c7b9c71279cd rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Desktop System: Dell product: OptiPlex 7040 v: N/A
Mobo: Dell model: 0HD5W2 v: A00 serial: <superuser required> UEFI: Dell
v: 1.24.0 date: 07/14/2022
Info: model: Intel Core i5-6500 bits: 64 type: MCP arch: Skylake-S
desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3600 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 25599
Type: gather_data_sampling status: Vulnerable: No microcode
disabled
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
Type: spec_rstack_overflow status: Not affected
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: disabled,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: HDMI-A-1,HDMI-A-3 empty: DP-1, DP-2, DP-3, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:1912 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.11 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0 note: <missing: xdpyinfo/xrandr>
Monitor-1: HDMI-A-1 model: Acer V227Q serial: <filter> built: 2021
res: 1920x1080 dpi: 102 gamma: 1.2 size: 476x268mm (18.74x10.55")
diag: 546mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-3 model: LG (GoldStar) 23MP75 built: 2014 res: 1920x1080
dpi: 96 gamma: 1.2 size: 510x290mm (20.08x11.42") diag: 587mm (23.1")
API: Vulkan v: 1.3.276 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 530 (SKL GT2) driver: mesa intel v: 23.3.5-arch1.1
device-ID: 8086:1912 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.5-arch1.1 (LLVM
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Dell
API: ALSA v: k6.7.3-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
Device-2: ASIX AX88179 Gigabit Ethernet driver: ax88179_178a type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3:2
chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp0s20f0u3 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 7.28 TiB used: 1.45 TiB (20.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S2000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 36.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3000DM001-9YN166
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC4B scheme: GPT
model: WD30EZRZ-00WN9B0 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80 scheme: GPT
ID-1: / raw-size: 1.31 TiB size: 1.31 TiB (100.00%) used: 678.26 GiB (50.6%)
ID-3: /home raw-size: 1.31 TiB size: 1.31 TiB (100.00%)
used: 678.26 GiB (50.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.31 TiB size: 1.31 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.31 TiB size: 1.31 TiB (100.00%)
ID-1: swap-1 type: zram size: 27.29 GiB used: 15.2 MiB (0.1%)
System Temperatures: cpu: 34.0 C pch: 59.5 C mobo: N/A
Processes: 225 Uptime: 43m wakeups: 0 Memory: total: 28 GiB
available: 27.29 GiB used: 5.88 GiB (21.6%) Init: systemd v: 255
pm: pacman pkgs: 1288 libs: 407 Shell: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.31
filo
5 February 2024 14:09
6
Quite frankly, not having a very technical background and this being a very critical aspect, I don’t feel comfortable suggesting what to delete.
Most likely the problem is related to the existence of so many entries in efibootmgr.
I think you could delete one entry for each of the surely equal pairs (Boot0007/Boot0014, Boot0002/Boot0012, Boot0003/Boot0013, I’d say).
Furthermore, the BootOrder doesn’t go beyond 0009, so the later ones perhaps could be deleted.
Or maybe just wait for feedback from someone with more experience in these aspects…
Osprey
5 February 2024 14:22
7
Great response!
As the machine is running really well I think I leave things alone and do more research on this potential problem.
It would be fantastic to get the Garuda Grub to properly boot the second ARCH LTS drive directly AND rehabilitate the efivars directory LOL
I don’t appear to have a /dump directory, though the file listing is really long !!!
Thank you for your insights!!!
Osprey
5 February 2024 14:30
9
I have tried that but the issue is that I don’t seem to be able to edit the
/\EFI\BOOT\BOOTX64.EFI String
This is a nice to have feature but the underlying issue is What happens if the EFIVARS directory runs out of space? My guess is nothing good LOL
filo
5 February 2024 14:31
10
In my case (I have a laptop with Garuda and Arch), Arch didn’t want to show up in the os-prober until it was mounted before (now I have it in the fstab and everything runs smootly).
But your case is different. I use there a single disk with two partitions; you have separate disks, and I seem to remember that os-prober works only if the distro’s share the same EFI System Partition (and maybe you have one ESP in each disk).
Osprey:
nothing good
For sure. See the warning here.
https://wiki.archlinux.org/title/Unified_Extensible_Firmware_Interface#Userspace_tools_are_unable_to_modify_UEFI_variable_data
In a different context, but:
bricking of machines when the NVRAM gets too full
Osprey
5 February 2024 14:34
11
That is correct both the nvme and the hdd have their own independant efi directories.
Osprey
5 February 2024 14:36
12
Yikes-
Thank goodness I run df -h when I back-up.
–reading your link now…
Osprey
5 February 2024 14:43
13
OK this is a bit over my head.
To be clear the current situation is that I have noticed that my efivars directory has grown to be essentially full (~1-2% available)
While not a problem NOW it appears it could become catastrophic?
This also very likely NOT a Garuda issue.
Any help will be appreciated.
NVRAM is on the motherboard and is likely only 256K and I’m guessing it is read into efivars. So with only 4K available in nvram I guess I need to reset it in the bios interface.
Hopefully I’ll be back to report success.
…And an update…
Wonders never cease!
I restarted in my Arch LTS HDD ran df- h which does not see the efivars directory
Updated Arch LTS and rebooted back into Garuda on SSD nmve.
Magically my efivars is down to 31% use so problem gone.
Arch LTS is on an EXT4 drive.
Garuda KDE-lite is on a BTRFS drive (which is new for me and I’m learning the FS)
Something to watch carefully i guess.
Will review resetting the BIOS to defaults but for now Loving Garuda and don’t want to break it.
Thank you all for helping me along with this.
It is not a problem. /sys/firmware is not a “real” filesystem, it is part of a RAM-based filesystem called sysfs . The sysfs filesystem provides information about devices and drivers in the kernel through virtual files, so certain device properties can be interacted with using “normal” file operations.
Since sysfs resides in memory, it is kind of a temporary structure that gets recreated fresh at every boot. There is no need to make it larger than whatever virtual files it needs to contain, so usually it appears to be full or nearly full.
NVRAM and EFI boot variables are not related to the sysfs virtual filesystem.
Osprey
6 February 2024 11:45
15
Thank You for this clarity!
Garuda Soars!
system
Closed
8 February 2024 11:45
16
