How do you edit the transparency on windows such as the search bar and the terminal to be less transparent or how do I disable it altogether?
Edit terminal profile.
There are many search bars. Which one are you referring to?
And Welcome to forums.
Eidt terminal profile
How so?
The application menu, but also Dolphin windows. It’s just a bit too transparent for my liking and it makes it hard to read/type when there are bright backgrounds.
Open terminal, go to click on settings in task bar > Edit Current profile > Appearence > sweet > edit > Adjust Transperency
Change kvantum settings. (Open kvantum manager and configure to your likings)
Also, you can change application menu by changing plasma style. I personally like breeze dark if you don’t want blurs.
Also, try to search on search engine / try to search things yourself from next time.
Have a good day.
