Hi
Garuda may overrule the settings in /etc/systemd/logind.conf
I edited the file to:
HandleLidSwitch=ignore
I obviously uncommented the line, and saved as root.
It still goes into suspend, once I close the lid of my laptop.
Does anything else cause this, besides logind.conf?
Thanks
I believe this file here is the culprit: etc/skel/.config/sway/config.d/clamshell · master · Garuda Linux / Themes and Settings / Settings / garuda-sway-settings · GitLab
~/.config/sway/config.d/clamshell
# Clamshell Mode
set $laptop <eDP-1>
bindswitch --reload --locked lid:on output $laptop disable
bindswitch --reload --locked lid:off output $laptop enable
exec_always ~/.config/sway/scripts/clamshell.sh
Obviously there is an associated script in ~/.config/sway/scripts
, but just commenting out/deleting/moving the clamshell file should be enough to stop the behavior.
Thanks
I commented out each line, still same behavior.
I reloaded Sway after changing the file.
Hmm, try logging out/back in or rebooting in case the script is still in play somehow.
system
Closed
11 August 2023 20:15
6
