Edit Enviroment variables
I need to add two things to my enviroment. This is something I have not had to do yet. I need add a path, so a directory is added and I need to do the following.
    • edit the /etc/environment file
    • sudo nano /etc/environment
    • add this: WEBKIT_DISABLE_DMABUF_RENDERER=1
    • save the file
    • log out of your session (or reboot)
I am looking for Syntax for line 3 there. Does it start with Key=xxxxx or ENV=*** or do I just add the line?
Kernel: 6.12.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=c31be1c8-8b6d-4962-95cf-1bed6c6e8ce7 rw rootflags=subvol=@
rd.driver.pre=vfio-pci intel_iommu=on rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3 vfio_pci.ids=10de:1c82,10de:0fb9
pcie_acs_override=downstream,multifunction video=efifb:off iommu=pt
wm: kwin_wayland tools: avail: hyprlock vt: 1 dm: SDDM Distro: Garuda
Mobo: ASUSTeK model: TUF GAMING Z590-PLUS WIFI v: Rev 1.xx
UEFI: American Megatrends v: 1801 date: 12/26/2022
Info: model: 11th Gen Intel Core i9-11900KF bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x62
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB
Speed (MHz): avg: 800 min/max: 800/5100:5300 scaling: driver: intel_pstate
bogomips: 112128
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: Dell
driver: nvidia v: 565.77 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-2,DP-3,HDMI-A-1 empty: DP-1
bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: vfio-pci v: N/A alternate: nouveau,nvidia_drm,nvidia
non-free: 550.xx+ status: current (as of 2024-09; EOL~2026-12-xx)
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 04:00.0 chip-ID: 10de:1c82 class-ID: 0300
Device-3: Adomax Nuroum C40
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4.2:17 chip-ID: 0627:a6bf
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4.3:19
alternate: fbdev,nouveau,nv,vesa gpu: nvidia,vfio-pci d-rect: 7253x4080
display-ID: 0
Monitor-1: DP-2 pos: middle-l res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-3 pos: top-center res: 3413x1920 size: N/A modes: N/A
Monitor-3: HDMI-A-1 pos: bottom-r res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6.0 vendor: nvidia v: 565.77 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
API: Vulkan v: 1.4.303 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: N/A device-ID: 10de:2504
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: Dell
Device-3: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: vfio-pci alternate: snd_hda_intel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s bus-ID: 04:00.1 chip-ID: 10de:0fb9
Device-4: SteelSeries ApS Arctis 7
lanes: 1 mode: 1.1 bus-ID: 1-4.2:9 chip-ID: 1038:12ad class-ID: 0300
Device-5: GN Netcom Jabra Engage 75 driver: jabra,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.4.1:15
chip-ID: 0b0e:1112 class-ID: 0300 serial: <filter>
Device-6: Adomax Nuroum C40
Device-7: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
Device-8: Giga-Byte ESS SABRE HiFi USB Audio Device
lanes: 1 mode: 2.0 bus-ID: 1-9.2:14 chip-ID: 0414:a00c class-ID: 0300
Device-9: Giga-Byte USB Audio driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9.3:20 chip-ID: 0414:a008
API: ALSA v: k6.12.6-zen1-1-zen status: kernel-api tools: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:18 chip-ID: 8087:0026
Local Storage: total: 9.36 TiB used: 543.71 GiB (5.7%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 233010WD temp: 31.9 C scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:11 model: PCIe SSD size: 931.51 GiB
tech: SSD serial: <filter> fw-rev: EHFM60.0 temp: 31.9 C scheme: MBR
ID-3: /dev/nvme2n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 35.9 C
ID-4: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
size: 931.52 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 00RL scheme: MBR
ID-5: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 1000GB
tech: SSD serial: <filter> fw-rev: 00RL scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SDSSDH3 512G
tech: SSD serial: <filter> fw-rev: 1000 scheme: MBR
ID-7: /dev/sdd maj-min: 8:48 model: External USB3.0 size: 476.94 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 0301
ID-8: /dev/sde maj-min: 8:64 model: External USB3.0 size: 223.57 GiB
ID-9: /dev/sdf maj-min: 8:80 model: External USB3.0 size: 476.94 GiB
ID-10: /dev/sdg maj-min: 8:96 model: SATA SSD size: 931.51 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1
mode: 3.2 gen-1x1 tech: SSD serial: <filter> fw-rev: 0301 scheme: MBR
ID-11: /dev/sdh maj-min: 8:112 vendor: Samsung model: SSD 860 EVO 500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 0301 scheme: GPT
ID-12: /dev/sdi maj-min: 8:128 vendor: Samsung model: SSD 860 EVO 500GB
ID-13: /dev/sdj maj-min: 8:144 vendor: Samsung model: SSD 860 EVO 500G
ID-14: /dev/sdk maj-min: 8:160 vendor: Samsung model: SSD 860 EVO 500G
ID-15: /dev/sdl maj-min: 8:176 vendor: Samsung model: SSD 850 PRO 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 0103 scheme: MBR
ID-16: /dev/sdm maj-min: 8:192 vendor: Samsung model: SSD 850 PRO 256GB
fw-rev: 0103 scheme: GPT
ID-1: / raw-size: 205.13 GiB size: 205.13 GiB (100.00%)
used: 116.83 GiB (57.0%) fs: btrfs dev: /dev/nvme2n1p5 maj-min: 259:8
used: 44.9 MiB (46.8%) fs: vfat dev: /dev/nvme2n1p1 maj-min: 259:4
ID-3: /home raw-size: 205.13 GiB size: 205.13 GiB (100.00%)
ID-4: /var/log raw-size: 205.13 GiB size: 205.13 GiB (100.00%)
ID-5: /var/tmp raw-size: 205.13 GiB size: 205.13 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.15 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 32.5 C mobo: 29.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 1053 fan-3: 0 fan-4: 0 fan-5: 0
fan-6: 4179 fan-7: 0
Memory: total: 32 GiB note: est. available: 31.15 GiB used: 4.53 GiB (14.5%)
Processes: 415 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.41 GiB services: org_kde_powerdevil,
Packages: 1959 pm: pacman pkgs: 1953 libs: 502
tools: octopi,pacseek,pamac,paru,yay pm: flatpak pkgs: 6 Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-11-23
Last full system update: 2024-12-24
So you want to use some variable from someone who tells you use nano, Garuda has micro preinstalled and doesn’t tell you how to do it?
Maybe my search on the internet will help, see how it was done in the corresponding files.
printenv
https://wiki.archlinux.org/title/Environment_variables
Thank you, ill give it a read. I don’t use nano so don’t care, just need to add line 3 to see if it fixes an appimage issue from creality, they can’t seem to build appimage that works with Arch. Im pretty much a vi user, as I cut my teeth on it on HP/UX.
No vi needed :wink:
sudo sh -c "echo 'WEBKIT_DISABLE_DMABUF_RENDERER=1' >> /etc/environment"
In /etc/environment you just add the line. It is not a script, it is a special config file specifically for reading these environment variables, so you don’t need to add export or anything like that.
After you add the variable, log out and log back in, then use echo to test that the variable is set.
echo $WEBKIT_DISABLE_DMABUF_RENDERER
Thank you, Darn it guess I have to use a windows VM for now. Orca 2.2 and Creality Print seem to hate Wayland and Arch. Could be nvidia, but it runs fine on laptop with Nvidia and Mint.
This thread sounds like an XY problem. What is the actual issue you need help with? Describe what is happening, and what you have tried so far to fix it.
