Hi,
how to enable Edimax AC600 USB WiFI Stick in aruda-dr460nized-gaming-linux-zen-231029 ?
lsusb output:
Bus 002 Device 006: ID 7392:a812 Edimax Technology Co., Ltd Edimax AC600 USB
sh-5.2# garuda-inxi
12System:
12Kernel 6.5.9-zen2-1-zen 12arch x86_64 12bits 64 12compiler gcc 12v 13.2.1 12clocksource tsc
12available hpet,acpi_pm 12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=de
tz=Europe/Berlin misobasedir=garuda root=miso:LABEL=GARUDA_DR460NIZEDGAMING_RAPTOR quiet
systemd.show_status=1 ibt=off driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
12Console N/A 12Distro Garuda Linux 12base Arch Linux
12Machine:
12Type Desktop 12System ASUS 12product All Series 12v N/A 12serial N/A
12Mobo ASUSTeK 12model Z87-C 12v Rev 1.xx 12serial <filter> 12UEFI American Megatrends 12v 2103
12date 08/15/2014
12CPU:
12Info 12model Intel Core i7-4770K 12socket BGA1155 (1150) 12note check 12bits 64 12type MT MCP 12arch Haswell
12gen core 4 12level v3 12note check 12built 2013-15 12process Intel 22nm 12family 6 12model-id 0x3C (60)
12stepping 3 12microcode 0x28
12Topology 12cpus 1x 12cores 4 12tpc 2 12threads 8 12smt enabled 12cache 12L1 256 KiB
12desc d-4x32 KiB; i-4x32 KiB 12L2 1024 KiB 12desc 4x256 KiB 12L3 8 MiB 12desc 1x8 MiB
12Speed (MHz) 12avg 3783 12high 3900 12min/max 800/3900 12base/boost 3517/3800 12scaling
12driver intel_cpufreq 12governor performance 12volts 1.2 V 12ext-clock 100 MHz 12cores 121 3900 122 3900
123 3900 124 3900 125 3503 126 3761 127 3900 128 3500 12bogomips 55998
12Flags avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
12Vulnerabilities <filter>
12Graphics:
12Device-1 NVIDIA GP104 [GeForce GTX 1070] 12driver nvidia 12v 535.113.01 12alternate nouveau,nvidia_drm
12non-free 545.xx+ 12status current (as of 2023-10; EOL~2026-12-xx) 12arch Pascal 12code GP10x
12process TSMC 16nm 12built 2016-2021 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 16 12link-max 12gen 3
12speed 8 GT/s 12bus-ID 01:00.0 12chip-ID 10de:1b81 12class-ID 0300
12Display 12server X.org 12v 1.21.1.10 12with Xwayland 12v 23.2.3 12compositor kwin_x11 12driver N/A
12tty 80x40
12Monitor-1 Unknown-1 12size-res N/A in console 12modes 1024x768
12API EGL 12v 1.5 12platforms 12device 1 12drv swrast 12gbm 12drv kms_swrast 12surfaceless 12drv swrast
12inactive wayland,x11,device-0
12API OpenGL 12v 4.5 12vendor mesa 12v 23.3.1-arch1.1 12note console (EGL sourced) 12renderer llvmpipe
(LLVM 16.0.6 256 bits)
12API Vulkan 12Message No Vulkan data available.
12Audio:
12Device-1 Intel 8 Series/C220 Series High Definition Audio 12vendor ASUSTeK 8 12driver snd_hda_intel
12v kernel 12bus-ID 00:1b.0 12chip-ID 8086:8c20 12class-ID 0403
12Device-2 NVIDIA GP104 High Definition Audio 12driver snd_hda_intel 12v kernel 12pcie 12gen 1
12speed 2.5 GT/s 12lanes 16 12link-max 12gen 3 12speed 8 GT/s 12bus-ID 01:00.1 12chip-ID 10de:10f0
12class-ID 0403
12API ALSA 12v k6.5.9-zen2-1-zen 12status kernel-api 12with aoss 12type oss-emulator 12tools N/A
12Server-1 PipeWire 12v 1.0.0 12status n/a (root, process) 12with 121 pipewire-pulse 12status active
122 wireplumber 12status active 123 pipewire-alsa 12type plugin 124 pw-jack 12type plugin
12tools pactl,pw-cat,pw-cli,wpctl
12Network:
12Device-1 Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet 12vendor ASUSTeK AM1I-A
12driver r8169 12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 1 12port d000 12bus-ID 03:00.0
12chip-ID 10ec:8168 12class-ID 0200
12IF enp3s0 12state down 12mac <filter>
12Device-2 TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS] 12driver rtl8xxxu 12type USB 12rev 2.0
12speed 480 Mb/s 12lanes 1 12mode 2.0 12bus-ID 3-12:4 12chip-ID 2357:010c 12class-ID 0000 12serial <filter>
12IF wlp0s20u12 12state up 12mac <filter>
12Drives:
12Local Storage 12total 960.17 GiB 12used 17.2 GiB (1.8%)
12ID-1 /dev/sda 12maj-min 8:0 12vendor Crucial 12model CT1000MX500SSD1 12family Micron Client SSDs
12size 931.51 GiB 12block-size 12physical 4096 B 12logical 512 B 12sata 3.3 12speed 3.0 Gb/s 12tech SSD
12serial <filter> 12fw-rev 023 12temp 50 C
12SMART yes 12state enabled 12health PASSED 12on 30d 23h 12cycles 174 12written 2.57 TiB 12Old-Age
12UDMA CRC errors 543 12alert Bad cable/connection?
12ID-2 /dev/sdb 12maj-min 8:16 12vendor SanDisk 12model Ultra 12size 28.65 GiB 12block-size 12physical 512 B
12logical 512 B 12type USB 12rev 2.1 12spd 480 Mb/s 12lanes 1 12mode 2.0 12tech N/A 12serial <filter> 12fw-rev 1.00
12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12Partition:
12ID-1 / 12raw-size 914.1 GiB 12size 914.1 GiB (100.00%) 12used 17.2 GiB (1.9%) 12fs btrfs
12block-size 4096 B 12dev /dev/sda2 12maj-min 8:2
12ID-2 /boot/efi 12raw-size 300 MiB 12size 299.4 MiB (99.80%) 12used 576 KiB (0.2%) 12fs vfat
12block-size 512 B 12dev /dev/sda1 12maj-min 8:1
12ID-3 /home 12raw-size 914.1 GiB 12size 914.1 GiB (100.00%) 12used 17.2 GiB (1.9%) 12fs btrfs
12ID-4 /var/log 12raw-size 914.1 GiB 12size 914.1 GiB (100.00%) 12used 17.2 GiB (1.9%) 12fs btrfs
12ID-5 /var/tmp 12raw-size 914.1 GiB 12size 914.1 GiB (100.00%) 12used 17.2 GiB (1.9%) 12fs btrfs
12Swap:
12Kernel 12swappiness 133 (default 60) 12cache-pressure 100 (default) 12zswap no
12ID-1 swap-1 12type zram 12size 15.56 GiB 12used 0 KiB (0.0%) 12priority 100 12comp zstd
12avail lzo,lzo-rle,lz4,lz4hc,842 12max-streams 8 12dev /dev/zram0
12Sensors:
12System Temperatures 12cpu 29.0 C 12mobo N/A
12Fan Speeds (rpm) N/A
12Info:
12Processes 237 12Uptime 8m 12wakeups 0 12Memory 12total 16 GiB 12available 15.56 GiB 12used 3.84 GiB (24.7%)
12Init systemd 12v 255 12default graphical 12tool systemctl 12Compilers 12gcc 13.2.1 12Packages 12pm pacman
12pkgs 1776 12libs 519 12tools octopi,paru 12Client 12inxi 3.3.31
Garuda (2.6.21-1):
System install date: 2023-12-22
Last full system update: 2023-12-22
Relevant software: snapper NetworkManager connman dracut nvidia-dkms
Running in chroot, ignoring command 'list-units'
