Hello Garuda users.
- I installed easy effects but it was shows something like this how i fix it
Kernel: 6.4.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=c2a1ce2d-f45a-46a8-8f05-8cd48a950b58 rw rootflags=subvol=@
rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3 psi=1
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
Type: Desktop System: Gigabyte product: A320M-S2H v: N/A
Mobo: Gigabyte model: A320M-S2H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F53 date: 01/05/2021
Info: model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1584 high: 1654 min/max: 1600/3500 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1459 2: 1654
3: 1649 4: 1577 bogomips: 27947
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 07:00.0
chip-ID: 1002:15dd class-ID: 0300 temp: 50.0 C
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: AMD Radeon Vega 8 Graphics
(raven LLVM 15.0.7 DRM 3.52 6.4.7-zen1-1-zen) direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 07:00.1
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.4.7-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.76 status: active with: 1: pipewire-pulse
vendor: Gigabyte driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168
IF-ID-1: enp7s0f3u4 state: unknown speed: -1 duplex: half mac: <filter>
IF-ID-2: vetht5tkho state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-3: virbr1 state: down mac: <filter>
IF-ID-4: waydroid0 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
Device-1: OPPO RMX2027 driver: rndis_host v: kernel type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:5 chip-ID: 22d9:2766
Report: bt-service: disabled note: tool can't run
Local Storage: total: 585 GiB used: 255.6 GiB (43.7%)
ID-1: /dev/sda maj-min: 8:0 model: SSD 128GB size: 119.24 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: XKR scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT3500SC 6
CTB5029G21Y034 size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s tech: HDD rpm: 7200 serial: <filter> fw-rev: A52B
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 55.06 GiB (46.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 13.59 GiB used: 1.19 GiB (8.7%)
System Temperatures: cpu: 50.1 C mobo: N/A gpu: amdgpu temp: 50.0 C
i also tryed reinstall that package from pacman but not works
