inxi
╰─λ garuda-inxi
Kernel: 5.16.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=ba2fb729-b4b9-49f0-8223-47f0378d19c9 rw rootflags=subvol=@
Type: Laptop System: ASUSTeK product: ROG Strix G513QM_G513QM v: 1.0
Mobo: ASUSTeK model: G513QM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G513QM.314 date: 09/03/2021
ID-1: BAT0 charge: 69.5 Wh (91.9%) condition: 75.6/90.0 Wh (84.0%)
volts: 16.0 min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1640 high: 3646 min/max: 1200/4889 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1546 2: 1561
3: 1844 4: 1397 5: 1395 6: 2151 7: 1428 8: 1396 9: 1456 10: 3646 11: 1395
12: 1458 13: 1396 14: 1396 15: 1395 16: 1395 bogomips: 105400
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.16.5-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.3.5 direct render: Yes
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
driver: snd_hda_intel v: kernel bus-ID: 06:00.1 chip-ID: 1002:1637
Device-3: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x
Device-4: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.16.5-zen1-1-zen running: yes
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
Device-2: MEDIATEK vendor: AzureWave driver: mt7921e v: kernel port: N/A
bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Local Storage: total: 1.4 TiB used: 343.02 GiB (24.0%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: SK Hynix model: HFM001TD3JX013N
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41000C20
temp: 39.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Intel model: SSDPEKKW512G8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 004C
temp: 41.9 C scheme: GPT
ID-1: / raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
used: 343 GiB (71.9%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:1
used: 25.5 MiB (26.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
ID-4: /var/log raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
ID-5: /var/tmp raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.12 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 56.0 C mobo: N/A gpu: amdgpu temp: 47.0 C
Fan Speeds (RPM): cpu: 0
Processes: 419 Uptime: 8m wakeups: 4 Memory: 15.12 GiB
used: 4.35 GiB (28.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1873 lib: 552 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-01-27
Last full system update: 2022-02-03
Output from update-grub
╰─λ sudo update-grub
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: amd-ucode.img initramfs-linux-zen-fallback.img
Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
Found Garuda Linux on /dev/nvme1n1p1
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2022-02-09 16:03:00 | @/.snapshots/748/snapshot | post | linux-xanmod-rog |
Found snapshot: 2022-02-09 16:02:53 | @/.snapshots/747/snapshot | pre | pacman -Rsu linux-xanmod-rog |
Found snapshot: 2022-02-09 16:00:01 | @/.snapshots/746/snapshot | single | timeline |
Found snapshot: 2022-02-09 15:00:02 | @/.snapshots/745/snapshot | single | timeline |
Found snapshot: 2022-02-09 06:00:03 | @/.snapshots/744/snapshot | single | timeline |
Found snapshot: 2022-02-09 05:56:13 | @/.snapshots/743/snapshot | single | timeline |
Found snapshot: 2022-02-09 02:00:12 | @/.snapshots/742/snapshot | single | timeline |
Found snapshot: 2022-02-09 01:00:12 | @/.snapshots/741/snapshot | single | timeline |
Found snapshot: 2022-02-09 00:00:05 | @/.snapshots/740/snapshot | single | timeline |
Found snapshot: 2022-02-08 23:00:12 | @/.snapshots/739/snapshot | single | timeline |
Found snapshot: 2022-02-08 22:00:12 | @/.snapshots/738/snapshot | single | timeline |
Found snapshot: 2022-02-08 21:00:12 | @/.snapshots/737/snapshot | single | timeline |
Found snapshot: 2022-02-08 20:00:04 | @/.snapshots/736/snapshot | single | timeline |
Found snapshot: 2022-02-08 00:00:18 | @/.snapshots/719/snapshot | single | timeline |
Found snapshot: 2022-02-07 09:00:03 | @/.snapshots/706/snapshot | single | timeline |
Found snapshot: 2022-02-06 19:04:16 | @/.snapshots/705/snapshot | post | balena-etcher |
Found snapshot: 2022-02-06 19:04:14 | @/.snapshots/704/snapshot | pre | pacman --sync -- balena-etcher |
Found snapshot: 2022-02-06 10:37:47 | @/.snapshots/694/snapshot | single | timeline |
Found snapshot: 2022-02-05 14:00:15 | @/.snapshots/684/snapshot | single | timeline |
Found snapshot: 2022-02-04 09:00:02 | @/.snapshots/672/snapshot | single | timeline |
Found snapshot: 2022-02-03 14:25:19 | @/.snapshots/665/snapshot | post | acl alsa-card-profiles ark attr audit baloo-widgets bbswitch-dkms dolphi |
Found snapshot: 2022-02-03 14:23:13 | @/.snapshots/664/snapshot | pre | pacman -Su |
Found snapshot: 2022-02-03 14:12:50 | @/.snapshots/663/snapshot | single | Manual Snapshot |
Found snapshot: 2022-02-03 00:00:06 | @/.snapshots/648/snapshot | single | timeline |
Found snapshot: 2022-02-02 10:11:09 | @/.snapshots/634/snapshot | post | mullvad-vpn |
Found snapshot: 2022-02-02 10:11:07 | @/.snapshots/633/snapshot | pre | pacman --sync -- mullvad-vpn |
Found snapshot: 2022-02-02 00:00:14 | @/.snapshots/622/snapshot | single | timeline |
Found snapshot: 2022-02-01 16:10:52 | @/.snapshots/614/snapshot | post | bbswitch-dkms curl dxvk-mingw-git elfutils expat garuda-common-settings |
Found snapshot: 2022-02-01 16:09:46 | @/.snapshots/613/snapshot | pre | pacman -Su |
Found snapshot: 2022-02-01 09:00:00 | @/.snapshots/610/snapshot | single | timeline |
Found snapshot: 2022-01-31 11:20:35 | @/.snapshots/602/snapshot | post | garuda-hotfixes |
Found snapshot: 2022-01-31 11:20:34 | @/.snapshots/601/snapshot | pre | pacman -Udd --noconfirm --needed archlinux-keyring-20220125-1-any.pkg.ta |
Found snapshot: 2022-01-31 11:00:58 | @/.snapshots/600/snapshot | single | timeline |
Found snapshot: 2022-01-29 00:06:57 | restore_backup_@_131746595 | N/A | N/A |
Found snapshot: 2022-01-28 23:33:07 | @/.snapshots/568/snapshot | single | Manual Snapshot |
Found snapshot: 2022-01-28 23:29:44 | restore_backup_@_000657046 | N/A | N/A |
Found snapshot: 2022-01-28 23:21:22 | restore_backup_@_232938162 | N/A | N/A |
Found snapshot: 2022-01-15 19:44:28 | restore_backup_@_232122884 | N/A | N/A |
Found snapshot: 2022-01-10 10:00:19 | @/.snapshots/255/snapshot | single | timeline |
Found snapshot: 2022-01-10 09:53:25 | @/.snapshots/254/snapshot | single | Manual Snapshot |
Found snapshot: 2021-11-28 17:01:03 | @/.snapshots/143/snapshot | single | Manual Snapshot |
Found 41 snapshot(s)
Unmount /tmp/grub-btrfs.FlCwjgyavi .. Success
/usr/bin/grub-probe: warning: unknown device type nvme1n1.
done
I had a second kernel installed a while back, but that was weeks before this started happening; but I removed it to eliminate that option. I don't have any grub-customizer installed looking at previous threads I also checked for files not owned by proper daemons/users
╰─λ bash -c 'pacman -Qo /etc/grub.d/*'
/etc/grub.d/00_header is owned by grub 2:2.06-4
/etc/grub.d/10_linux is owned by grub 2:2.06-4
/etc/grub.d/20_linux_xen is owned by grub 2:2.06-4
/etc/grub.d/30_os-prober is owned by grub 2:2.06-4
/etc/grub.d/30_uefi-firmware is owned by grub 2:2.06-4
/etc/grub.d/35_fwupd is owned by fwupd 1.7.4-1
/etc/grub.d/40_custom is owned by grub 2:2.06-4
/etc/grub.d/41_custom is owned by grub 2:2.06-4
/etc/grub.d/41_snapshots-btrfs is owned by grub-btrfs 4.11-1
/etc/grub.d/60_memtest86+ is owned by memtest86+ 5.31b-1
/etc/grub.d/61_custom_leave_options is owned by garuda-common-settings 2.5.4-2
/etc/grub.d/README is owned by grub 2:2.06-4
But this all looks correct to me. Would appreciate any input on how to get the duplicate entries removed.
