Hello,
i am having some issues with my Dualshock 4 controller.
It worked fine until recently but due to a specific game issue i have installed sc-controller in an attempt to fix it. When that did not work i removed sc-controller. After, it stopped showing up in the wine control panel and any games launched via wine/lutris did not recognize any input from it, wether wired or bluetooth on any kernel i have installed (lts, linux and zen).
The weird part is that i can still use the touchpad as a mouse, it shows up in input devices(along with another entry for an xbox 360pad that does not react to anything) and it works perfectly on steam on any game, including any game where i would use lutris or wine.
I would much rather be able to restore its functionality, has anyone come across anything similar or has any idea how to fix this?
Kernel: 6.1.45-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=58d3aace-5477-467a-aae1-04bba92f4f0c rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 info: latte-dock
wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7B79 v: 3.0
Mobo: Micro-Star model: X470 GAMING PLUS MAX (MS-7B79) v: 3.0
serial: <superuser required> UEFI: American Megatrends v: H.60
date: 06/11/2020
Device-1: sony_controller_battery_40:1b:5f:1f:90:27 model: N/A serial: N/A
charge: N/A status: discharging
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2200 high: 2205 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2205 10: 2200
11: 2200 12: 2200 bogomips: 86434
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nvidia v: 535.98 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 27:00.0 chip-ID: 10de:1c03 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x301mm (41.73x11.85")
s-diag: 1102mm (43.38")
Monitor-1: DVI-D-0 pos: right res: 1920x1080 dpi: 93
Monitor-2: HDMI-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 92
API: OpenGL v: 4.6.0 NVIDIA 535.98 renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Gigabyte
bus-ID: 27:00.1 chip-ID: 10de:10f1 class-ID: 0403
bus-ID: 29:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Generalplus USB Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-12:2 chip-ID: 1b3f:2008 class-ID: 0300
API: ALSA v: k6.1.45-1-lts status: kernel-api
Server-2: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 2357:0604
Local Storage: total: 3.39 TiB used: 1.35 TiB (39.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8250G
size: 232.89 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105
temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Patriot model: Burst
size: 223.57 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 61.2 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SV300S37A240G
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: BBF0 scheme: MBR
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A02 scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 860 EVO 500GB
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 3B6Q scheme: MBR
ID-6: /dev/sde maj-min: 8:64 vendor: Seagate model: Expansion
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 9300 scheme: MBR
ID-7: /dev/sdf maj-min: 8:80 vendor: Toshiba model: MQ01ABF050
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
serial: <filter> fw-rev: 5438 scheme: MBR
used: 82.14 GiB (35.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.56 GiB used: 17.2 MiB (0.1%)
System Temperatures: cpu: 43.0 C mobo: 35.0 C gpu: nvidia temp: 50 C
Fan Speeds (RPM): cpu: 9820 fan-1: 0 fan-2: 1785 fan-4: 0 fan-5: 0
fan-6: 0 gpu: nvidia fan: 0%
Power: 12v: N/A 5v: N/A 3.3v: 3.30 vbat: 3.30
Processes: 341 Uptime: 42m wakeups: 1 Memory: total: 16 GiB
available: 15.56 GiB used: 5.2 GiB (33.4%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 15.0.7 Packages: pm: pacman pkgs: 1621 libs: 415 tools: pamac,paru
Shell: fish v: 3.6.1 running-in: cool-retro-term inxi: 3.3.28
System install date: 2022-03-17
Last full system update: 2023-08-15
