Hello, I have installed Garuda OS and everything works for the most part. The main issue I am having is that after booting into the OS, the OS recognizes my DualSense Controller and I can see the inputs being detected in the system settings, but Steam says that no supported gamepads are connected. It only detects the controller after I unplug it from USB and replug the controller. That technically means that the controller works, but having to physically unplug and replug every boot is not really a solution. What I have noticed is that after unplugging and replugging the controller, Steam does not detect the controller until the system settings page is closed. I have a feeling that the system settings is taking some kind of exclusive access of the controller and only releases it after being closed. This could also explain why steam does not detect it on boot.
Kernel: 6.9.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=9cb6b727-12ca-46c0-9500-80421889bcc6 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Mobo: ASUSTeK model: ROG STRIX Z790-E GAMING WIFI v: Rev 1.xx
UEFI: American Megatrends v: 2202 date: 04/18/2024
Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
Info: model: 13th Gen Intel Core i7-13700K bits: 64 type: MST AMCP
microcode: 0x123
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 2494 high: 5379 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 5301 2: 800 3: 5300
4: 800 5: 5300 6: 800 7: 800 8: 800 9: 5379 10: 800 11: 800 12: 800
13: 5289 14: 800 15: 5300 16: 800 17: 800 18: 4199 19: 4200 20: 800
21: 4199 22: 4197 23: 800 24: 800 bogomips: 164044
Device-1: NVIDIA AD103 [GeForce RTX 4080 SUPER] vendor: ZOTAC driver: nvidia
v: 550.90.07 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: DP-1,DP-2 empty: DP-3,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2702
Screen-1: 0 s-res: 5120x1440 s-dpi: 108 s-size: 1204x342mm (47.40x13.46")
s-diag: 1252mm (49.28")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,left
model: VG27WQ1B serial: <filter> built: 2023 res: 2560x1440 dpi: 109
gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: max: 2560x1440 min: 640x480
Monitor-2: DP-2 note: disabled pos: right model: VG27AQ1A serial: <filter>
built: 2022 res: 2560x1440 hz: 165 dpi: 109 gamma: 1.2
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.90.07
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4080
SUPER/PCIe/SSE2 memory: 15.62 GiB
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4080 SUPER driver: nvidia v: 550.90.07 device-ID: 10de:2702
surfaces: xcb,xlib
Device-1: Intel Raptor Lake High Definition Audio vendor: ASUSTeK
Device-2: NVIDIA vendor: ZOTAC driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:22bb class-ID: 0403
Device-3: Sony DualSense wireless controller (PS5) driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2.1:5
chip-ID: 054c:0ce6 class-ID: 0300
Device-4: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:4
Device-5: Corsair HS80 RGB Wireless Gaming Receiver
lanes: 1 mode: 1.1 bus-ID: 1-5.4:10 chip-ID: 1b1c:0a6b class-ID: 0300
API: ALSA v: k6.9.5-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0
Device-2: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel
chip-ID: 8086:125c class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:12 chip-ID: 8087:0032
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 6.37 TiB used: 167.31 GiB (2.6%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 50.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 44.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-1: / raw-size: 300 GiB size: 300 GiB (100.00%) used: 167.28 GiB (55.8%)
fs: btrfs dev: /dev/nvme1n1p5 maj-min: 259:6
used: 27 MiB (28.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
ID-3: /home raw-size: 300 GiB size: 300 GiB (100.00%)
used: 167.28 GiB (55.8%) fs: btrfs dev: /dev/nvme1n1p5 maj-min: 259:6
ID-4: /var/log raw-size: 300 GiB size: 300 GiB (100.00%)
ID-5: /var/tmp raw-size: 300 GiB size: 300 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.09 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 37.0 C mobo: N/A gpu: nvidia temp: 51 C
Memory: total: 32 GiB note: est. available: 31.09 GiB used: 5.23 GiB (16.8%)
Processes: 502 Power: uptime: 20m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.39 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1930 libs: 568 tools: octopi,pamac,paru
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date: 2024-06-06
Last full system update: 2024-06-17
