Hello everyone, yesterday i decided to try garuda linux ultimate on my laptop, but my hp monitor wasn`t detected at all. what am i missing?PS. i installed now garuda Dr460nized and the same problem
tbg
26 November 2020 07:51
2
What is your graphics, and which driver did you select to install?
This second monitor, what type of connection are you using?
Is your laptop's display screen working properly?
i have two graphics Intel Corporation UHD Graphics 630 (Mobile) and NVIDIA Corporation TU117M [GeForce GTX 1650 Mobile / Max-Q] (rev a1)
i am using HDMI. and laptop display works fine,
tbg
26 November 2020 08:01
4
Please post the output of:
inxi -Fxxxza
Please do not post outputs or log excerpts as pictures. Always post terminal outputs as text.
I will likely hand you off to someone else who is better at troubleshooting these type of issues. If @petsam is around he is pretty good with graphics display issues.
I think KDE has been known to be having issues with a second monitor of late. I would search the forum with the terms "KDE dual monitor" and see what advice you turn up.
Welcome to Garuda, hopefully this issue can be rectified without too much of a lwait.
many thanks for your reply. i am getting to love Garuda linux.
here is the output
╭─monier at Monier in ⌁
╰─λ inxi -Fxxxza
System: Kernel: 5.9.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=cf3970cf-13b3-4f05-8eea-ac1fee3ccb79 rw rootflags=subvol=@ quiet splash
Console: tty 3 DM: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: LENOVO product: 81LK v: IdeaPad L340-15IRH Gaming serial:
Chassis: type: 10 v: IdeaPad L340-15IRH Gaming serial:
Mobo: LENOVO model: LNVNB161216 v: SDK0R33126 WIN serial: UEFI: LENOVO v: BGCN31WW
date: 06/23/2020
Battery: ID-1: BAT0 charge: 38.7 Wh condition: 38.7/45.0 Wh (86%) volts: 12.8/11.5
model: Celxpert L18C3PF1 type: Li-poly serial: status: Full cycles: 119
CPU: Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 9E (158) stepping: A (10) microcode: DE L2 cache: 12.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62399
Speed: 2600 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 2600 2: 2600 3: 2464 4: 2601
5: 2600 6: 2500 7: 2600 8: 2600 9: 2604 10: 2600 11: 2600 12: 2600
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP:
conditional, RSB filling
Graphics: Device-1: Intel UHD Graphics 630 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo driver: nvidia
v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f91
Device-3: Lite-On Integrated Camera type: USB driver: uvcvideo bus ID: 1-8:3
chip ID: 04ca:7070
Display: server: X.org 1.20.9 compositor: kwin_wayland driver: vesa FAILED: modesetting
unloaded: intel,nvidia alternate: fbdev,nouveau,nv tty: 107x22
Message: Advanced graphics data unavailable in console. Try -G --display
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:a348
Sound Server: ALSA v: k5.9.10-zen1-1-zen
Network: Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lenovo
driver: ath10k_pci v: kernel port: 4000 bus ID: 07:00.0 chip ID: 168c:0042
IF: wlp7s0 state: up mac:
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 3000 bus ID: 08:00.0 chip ID: 10ec:8168
IF: enp8s0 state: down mac:
Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-14:4 chip ID: 0cf3:e500
Drives: Local Storage: total: 1.14 TiB used: 11.68 GiB (1.0%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFM256GDHTNG-8310A size: 238.47 GiB block size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 serial: rev: 80070C00
ID-2: /dev/sda vendor: Western Digital model: WD10SPZX-24Z10 size: 931.51 GiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial:
rev: 1A05 scheme: GPT
Partition: ID-1: / raw size: 238.17 GiB size: 238.17 GiB (100.00%) used: 11.68 GiB (4.9%) fs: btrfs
dev: /dev/nvme0n1p2
ID-2: /home raw size: 238.17 GiB size: 238.17 GiB (100.00%) used: 11.68 GiB (4.9%) fs: btrfs
dev: /dev/nvme0n1p2
ID-3: /var/log raw size: 238.17 GiB size: 238.17 GiB (100.00%) used: 11.68 GiB (4.9%)
fs: btrfs dev: /dev/nvme0n1p2
ID-4: /var/tmp raw size: 238.17 GiB size: 238.17 GiB (100.00%) used: 11.68 GiB (4.9%)
ID-1: swap-1 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-9: swap-9 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-10: swap-10 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-11: swap-11 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-12: swap-12 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
Sensors: System Temperatures: cpu: 52.0 C mobo: N/A
Info: Processes: 316 Uptime: 3h 38m wakeups: 5530 Memory: 15.51 GiB used: 3.59 GiB (23.2%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: pacman: 1328 lib: 289
Shell: fish v: 3.1.2 running in: tty 3 (SSH) inxi: 3.1.09
tbg:
no matter what i do it will not activate
below is after i run the comand.
─λ systemctl status autorandr
autorandr.service - autorandr execution hook
Loaded: loaded (/usr/lib/systemd/system/autorandr.service; enabled; vendor preset: disabled)
Active: inactive (dead)
Nov 26 08:29:12 Monier autorandr[91560]: Running autorandr as monier for display :1
Nov 26 08:29:12 Monier systemd[1]: autorandr.service: Succeeded.
Nov 26 08:29:12 Monier systemd[1]: Finished autorandr execution hook.
Nov 26 10:11:07 Monier systemd[1]: Starting autorandr execution hook…
Nov 26 10:11:07 Monier autorandr[176507]: Config already loaded
Nov 26 10:11:07 Monier autorandr[176507]: autorandr running as user monier (started from batch instance)
Nov 26 10:11:07 Monier autorandr[176507]: new (detected) (current)
Nov 26 10:11:07 Monier autorandr[176506]: Running autorandr as monier for display :1
Nov 26 10:11:07 Monier systemd[1]: autorandr.service: Succeeded.
Nov 26 10:11:07 Monier systemd[1]: Finished autorandr execution hook.
You have hybrid graphics
And we use optimus manager
Its set to intel mode by default
Change it to hybrid mode
would you please advise mw how to do it?
librewish:
Open
optimus-manager-qt
Or
optimus-manager --switch hybrid
i tried this and it didn`t solve the problem.
and also searched and found this solution
I tried that and rebooted, but it did not switch to nvidia, even after rebooting a couple of times. ❯ optimus-manager --status Optimus Manager (Client) version 1.2.2 Current GPU mode : intel GPU mode requested for next login : nvidia GPU mode...
and still same problem.
and below is the output of
optimus -manager --status
WARNING: hybrid mode is set but Nvidia card does not seem to be available for offloading.
Log at /var/log/optimus -manager/switch/switch-20201126T191323.log
Optimus Manager (Client) version 1.3
Current GPU mode : hybrid
GPU mode requested for next login : no change
GPU at startup : intel
Temporary config path: no
tbg
27 November 2020 03:21
12
Are you in a wayland session by any chance, because it's been causing a lot strange issues for people?
yes i using the default of the installation, i will try with xorg and let you know.
indeed it was the wayland, it is working now,
but i have to do both command every time i boot my system
sudo modprobe nvidia
optimus-manager --switch nvidia
can you help me how to solve this
tbg
27 November 2020 10:44
15
I think you'll have to wait for someone more experienced with dealing with graphics problems than myself. Perhaps you may have a better chance of getting this resolved by opening a separate thread for your driver issue.
Good luck.
i will try this and let you know
toor
18 December 2021 19:38
18
Hi ihad same issue! But when you launch Optimus-manager, just right click on optimus tray icon-->setting-->launch att startup. It worked for me. If not make sure Optimus-manager ticked on Desktop session Settings! And edit .conf "
sudo vim /etc/optimus-manager/optimus-manager.conf
" and make sure "startup_mode=nvidia " !
SGS
Closed
18 December 2021 19:50
19
I must close if the forum software don't do it.
