Hello all!
I've done some searching not seeing any similar posts.. sorry if i missed one!
I'm running KDE Dragonized blackarch fully updated.
Whenever i connect my second monitor the entire system lags.
Here is my inxi -Fxxxza output.
System: Kernel: 5.11.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=db93769c-7124-4351-985b-120b646c2e1c rw
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: Micro-Star model: X470 GAMING PLUS (MS-7B79) v: 2.0 serial: <filter> UEFI: American Megatrends
v: A.G0 date: 11/11/2019
CPU: Info: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 8 stepping: 2
microcode: 800820D cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 118380
Speed: 2586 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz): 1: 2586 2: 2427 3: 3949 4: 2422 5: 2453
6: 2578 7: 2435 8: 2925 9: 2435 10: 2442 11: 2806 12: 3095 13: 2409 14: 2927 15: 2472 16: 2585
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK driver: nvidia v: 465.24.02 alternate: nouveau,nvidia_drm
bus-ID: 27:00.0 chip-ID: 10de:1b81 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9") s-diag: 610mm (24")
Monitor-1: DP-2 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 465.24.02 direct render: Yes
Audio: Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 27:00.1
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 29:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.11.16-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: down mac: <filter>
Device-2: Microsoft Wireless XBox Controller Dongle type: USB driver: mt76x2u bus-ID: 1-4.4:8 chip-ID: 045e:02e6
IF: wlp3s0f0u4u4 state: down mac: <filter>
Device-3: Realtek RTL88x2bu [AC1200 Techkey] type: USB driver: rtl88x2bu bus-ID: 5-4:5 chip-ID: 0bda:b812
IF: wlp40s0f3u4 state: up mac: <filter>
Drives: Local Storage: total: 4.8 TiB used: 605.13 GiB (12.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WDS500G2X0C-00L350 size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 101110WD temp: 46.9 C
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Silicon Power model: SPCC M.2 PCIe SSD size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: T0214B0L temp: 47.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD5000AAKX-001CA0 size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 1H15 scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD1001FALS-00Y6A0 size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 1D05 scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: HP model: MB2000EBUCF size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter> rev: HPG0 scheme: GPT
Partition: ID-1: / raw-size: 147.41 GiB size: 147.41 GiB (100.00%) used: 26.81 GiB (18.2%) fs: btrfs dev: /dev/nvme1n1p3
maj-min: 259:9
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%) used: 31.7 MiB (33.4%) fs: vfat dev: /dev/nvme0n1p2
maj-min: 259:2
ID-3: /home raw-size: 147.41 GiB size: 147.41 GiB (100.00%) used: 26.81 GiB (18.2%) fs: btrfs dev: /dev/nvme1n1p3
maj-min: 259:9
ID-4: /var/log raw-size: 147.41 GiB size: 147.41 GiB (100.00%) used: 26.81 GiB (18.2%) fs: btrfs
dev: /dev/nvme1n1p3 maj-min: 259:9
ID-5: /var/tmp raw-size: 147.41 GiB size: 147.41 GiB (100.00%) used: 26.81 GiB (18.2%) fs: btrfs
ID-1: swap-1 type: zram size: 1000.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1000.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1000.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1000.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 1000.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 1000.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 1000.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 1000.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-9: swap-9 type: zram size: 1000.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-10: swap-10 type: zram size: 1000.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-11: swap-11 type: zram size: 1000.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-12: swap-12 type: zram size: 1000.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
ID-13: swap-13 type: zram size: 1000.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram12
ID-14: swap-14 type: zram size: 1000.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram13
ID-15: swap-15 type: zram size: 1000.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram14
ID-16: swap-16 type: zram size: 1000.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram15
Sensors: System Temperatures: cpu: 38.0 C mobo: 0 C gpu: nvidia temp: 36 C
Info: Processes: 385 Uptime: 23m wakeups: 0 Memory: 15.64 GiB used: 4.37 GiB (27.9%) Init: systemd v: 248 tool: systemctl
Compilers: gcc: 10.2.0 Packages: pacman: 1852 lib: 414 Shell: fish v: 3.2.1 running-in: yakuake inxi: 3.3.04
Any tips are greatly appriciated!
