Hi, I'm using a 4K monitor as my primary one with a 1080p monitor to its left. I can't seem to get the offset to work though, Garuda's display configuration menu caps anything to the left at pos 0x0 forcing my main display the be at pos 1920x0. I searx'd it and found a topic on xrandr, so I tried to set the pos to -3840x0 for my secondary monitor but when I list them again it shows that it has instead defaulted back to pos 0x0 and instead my primary display gets shifted to the right by that amount. Please save me lol!
PS: I tried using the screen layout options too, but they didn't seem to do anything other than randomly change my main monitor or force my secondary monitor to the right which is not ideal for my setup.
inxi -Faz
'System: Kernel: 5.15.6-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=73f46d96-0279-475c-beed-838a031cfcdc
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK (MS-7C02) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.H5 date: 04/22/2021
CPU: Info: 8-Core model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen family: 17 (23)
model-id: 1 stepping: 1 microcode: 8001138 cache: L1: 768 KiB L2: 4 MiB L3: 16 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 102395
Speed: 3200 MHz min/max: N/A Core speeds (MHz): 1: 3200 2: 3200 3: 3200 4: 3200 5: 3200 6: 3200
7: 3062 8: 3200 9: 2572 10: 3200 11: 3200 12: 3200 13: 3200 14: 3165 15: 3200 16: 3200
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 26:00.0 chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x2160 s-dpi: 152 s-size: 962x361mm (37.9x14.2") s-diag: 1028mm (40.5")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.9x11.8") diag: 609mm (24")
Monitor-2: DP-0 res: 3840x2160 hz: 60 dpi: 154 size: 632x360mm (24.9x14.2") diag: 727mm (28.6")
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44
direct render: Yes
Audio: Device-1: NVIDIA GP106 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 26:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 28:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Realtek Realtek Audio USB type: USB driver: snd-usb-audio bus-ID: 1-2:2
chip-ID: 0bda:4938 class-ID: 0102 serial: <filter>
Device-4: Kingston HyperX 7.1 Audio type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-4:3 chip-ID: 0951:16a4 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.6-zen2-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
Drives: Local Storage: total: 2.87 TiB used: 35.88 GiB (1.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 1TB size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000BX500SSD1 size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 054
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Samsung model: Flash Drive FIT size: 119.51 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB model: USB DISK 3.0 size: 28.88 GiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-5: /dev/sde maj-min: 8:64 type: USB vendor: Western Digital model: WD10EARS-00MVWB0
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 2021 scheme: MBR
Partition: ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 35.88 GiB (3.9%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 35.88 GiB (3.9%) fs: btrfs
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 35.88 GiB (3.9%) fs: btrfs
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 35.88 GiB (3.9%) fs: btrfs
ID-1: swap-1 type: zram size: 15.61 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: Message: No sensor data found. Is lm-sensors configured?
Info: Processes: 378 Uptime: 1h 10m wakeups: 0 Memory: 15.61 GiB used: 3.7 GiB (23.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 2278 lib: 508
Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09'
