I have a monitor plugged in but it does not work.
Kernel: 5.19.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=6a9e8edd-14c2-4d20-aa71-671321d8469d rw rootflags=subvol=@
quiet splash drm_kms_helper.edid_firmware=HDMI-A-1:edid/1920x1080.bin
Console: pty pts/0 wm: kwin_x11 DM: 1: LightDM v: 1.32.0 note: stopped
2: SDDM note: stopped Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Acer product: Nitro AN515-56 v: V1.05 serial: <filter>
Mobo: TGL model: Scala_TLM v: V1.05 serial: <filter> UEFI: Insyde v: 1.05
date: 04/22/2021
ID-1: BAT1 charge: 47.1 Wh (100.0%) condition: 47.1/57.5 Wh (82.0%)
volts: 16.7 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
status: full cycles: 60
Info: model: 11th Gen Intel Core i5-11300H socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm
family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0xA4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3026 high: 3100 min/max: 400/4400 base/boost: 4000/4400
scaling: driver: intel_pstate governor: performance volts: 0.8 V
ext-clock: 100 MHz cores: 1: 3100 2: 3100 3: 3100 4: 3100 5: 3100 6: 2512
7: 3100 8: 3100 bogomips: 49766
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Acer
Incorporated ALI driver: i915 v: kernel arch: Gen-12.1
process: Intel 10nm built: 2020-21 ports: active: eDP-1 empty: DP-1
bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Acer
Incorporated ALI driver: N/A alternate: nouveau non-free: 515.xx+
status: current (as of 2022-07) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 bus-ID: 0000:01:00.0 chip-ID: 10de:25a5
Device-3: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 3-8:3
chip-ID: 04f2:b72b class-ID: fe01 serial: <filter>
Monitor-1: eDP-1 model: AU Optronics 0xaf90 built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Acer Incorporated
ALI driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:2291 class-ID: 0403
Sound Server-1: ALSA v: k5.19.6-zen1-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX201 vendor: Rivet Networks driver: iwlwifi
v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
port: 3000 bus-ID: 0000:2c:00.0 chip-ID: 10ec:2600 class-ID: 0200
IF: enp44s0 state: up speed: 100 Mbps duplex: full mac: <filter>
bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev:
class-ID: 0104
Local Storage: total: 700.51 GiB used: 17.25 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1114 size: 476.94 GiB block-size: physical: 512 B
rev: 21113000 temp: 47.9 C scheme: GPT
SMART: yes health: PASSED on: 157d 2h cycles: 192 read-units: 168,037,689
[86.0 TB] written-units: 48,572,616 [24.8 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX200SSD1
family: based SSDs size: 223.57 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: .6 temp: 34 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 6d 17h cycles: 1252
read: 4.58 TiB written: 1.86 TiB
ID-1: / raw-size: 223.27 GiB size: 223.27 GiB (100.00%) used: 17.25 GiB
(7.7%) fs: btrfs block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
(0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 223.27 GiB size: 223.27 GiB (100.00%) used: 17.25
GiB (7.7%) fs: btrfs block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 223.27 GiB size: 223.27 GiB (100.00%) used: 17.25
ID-5: /var/tmp raw-size: 223.27 GiB size: 223.27 GiB (100.00%) used: 17.25
ID-1: swap-1 type: zram size: 7.56 GiB used: 46.8 MiB (0.6%)
Message: No sensor data found. Is lm-sensors configured?
Processes: 285 Uptime: 21m wakeups: 2573 Memory: 7.56 GiB used: 4.16 GiB
(55.0%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: apt: 0 pacman: 1949 lib: 532
inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-09-04
Last full system update: 2022-09-04 ↻
Windows dual boot: Yes
Also if I use xrandr it does not appear:
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 144.15*+ 60.01 59.97 59.96 59.93
1680x1050 59.95 59.88
1400x1050 74.76 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 85.02 75.02 60.02
1400x900 59.96 59.88
1280x960 85.00 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1152x864 75.00
1280x720 60.00 59.99 59.86 59.74
1024x768 85.00 75.05 60.04 85.00 75.03 70.07 60.00
1024x768i 86.96
960x720 85.00 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
832x624 74.55
960x540 59.96 59.99 59.63 59.82
800x600 85.00 75.00 70.00 65.00 60.00 85.14 72.19 75.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 74.76 59.98
800x450 59.95 59.82
640x512 85.02 75.02 60.02
700x450 59.96 59.88
640x480 85.09 60.00 85.01 72.81 75.00 59.94
720x405 59.51 58.99
720x400 85.04
684x384 59.88 59.85
640x400 59.88 59.98 85.08
576x432 75.00
640x360 59.86 59.83 59.84 59.32
640x350 85.08
512x384 85.00 75.03 70.07 60.00
512x384i 87.06
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
400x300 85.27 72.19 75.12 60.32 56.34
432x243 59.92 59.57
320x240 85.18 72.81 75.00 60.05
360x202 59.51 59.13
360x200 85.04
320x200 85.27
320x180 59.84 59.32
320x175 85.27
DP-1 disconnected (normal left inverted right x axis y axis)
My computer is dual booted with windows and on Win dual monitor works properly.
