Hi, I have weird issue. Recently I’ve got a new monitor 180 hz. To check fps i’m using kde’s “show fps” desktop effect. When I move any window on the laptop screen (120hz) everything is smooth and it shows 180 fps. However, when I move window on my external screen, kde shows current fps at 60 and I can see that window is laggy. Also, sometimes both screen just freezes for a second.
I’m on wayland. When i switched to x11 and disabled laptop display, the external display worked as expected (rendering 180 fps).
I tried adding MaxFPS=180 to ~/.config/kwinrc, but it doesn’t work.
Kernel: 6.8.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=9ab680d1-bec4-4d96-8638-f920e8bf7007 rw rootflags=subvol=@
nvidia-drm.modeset=1 nvidia-drm.modeset=1 rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Laptop System: Micro-Star product: GF65 Thin 9SEXR v: REV:1.0
Mobo: Micro-Star model: MS-16W1 v: REV:1.0 serial: <superuser required>
part-nu: 16W1.1 uuid: <superuser required> UEFI: American Megatrends
v: E16W1IMS.10A date: 03/26/2020
ID-1: BAT1 charge: 39.7 Wh (95.4%) condition: 41.6/51.3 Wh (81.0%)
volts: 12.7 min: 11.4 model: MSI Corp. MS-16W1 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xFC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3999 high: 4003 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 4000 2: 4000 3: 4002
4: 3992 5: 4003 6: 4000 7: 4000 8: 3999 bogomips: 38400
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-1
empty: none bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
gpu: i915,nvidia d-rect: 1920x2160 display-ID: 0
Monitor-1: HDMI-A-1 pos: primary,top res: 1920x1080 size: N/A modes: N/A
Monitor-2: eDP-1 pos: bottom res: 1920x1080 size: N/A modes: N/A
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.4-arch1.2
GT2) device-ID: 8086:3e9b memory: 15.1 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: integrated-gpu
name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel v: 24.0.4-arch1.2
device-ID: 8086:3e9b surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 2060 driver: nvidia v: 550.67
device-ID: 10de:1f15 surfaces: xcb,xlib,wayland device: 2 type: cpu
v: 24.0.4-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.8.2-zen2-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Info: services: NetworkManager, smbd, systemd-networkd, systemd-timesyncd
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3
Local Storage: total: 476.94 GiB used: 433.41 GiB (90.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: LITE-ON model: CL1-8D512
lanes: 4 tech: SSD serial: <filter> fw-rev: 1.00 temp: 43.9 C scheme: GPT
ID-1: / raw-size: 469.65 GiB size: 469.65 GiB (100.00%)
used: 433.41 GiB (92.3%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:2
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 469.65 GiB size: 469.65 GiB (100.00%)
ID-4: /var/log raw-size: 469.65 GiB size: 469.65 GiB (100.00%)
ID-5: /var/tmp raw-size: 469.65 GiB size: 469.65 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.46 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 1.91 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:3
System Temperatures: cpu: 77.0 C pch: 63.0 C mobo: N/A
Memory: total: 16 GiB available: 15.46 GiB used: 3.67 GiB (23.7%)
Processes: 297 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.12 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 2147 libs: 558 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26
Garuda (2.6.23-1):
System install date: 2023-09-04
Last full system update: 2024-04-06
xrandr:
Screen 0: minimum 16 x 16, current 1920 x 2160, maximum 32767 x 32767
eDP-1 connected primary 1920x1080+0+1080 (normal left inverted right x axis y axis) 340mm x 190mm
1920x1080 120.01*+
1440x1080 120.03
1400x1050 120.01
1280x1024 119.96
1280x960 119.89
1152x864 119.94
1024x768 120.02
800x600 119.85
640x480 119.52
320x240 119.73
1680x1050 119.99
1440x900 120.07
1280x800 120.01
1152x720 119.94
960x600 120.04
928x580 119.87
800x500 119.91
768x480 119.71
720x480 119.65
640x400 119.64
320x200 117.55
1600x900 120.07
1368x768 119.99
1280x720 119.86
1024x576 119.85
864x486 119.69
720x400 119.54
640x350 120.03
HDMI-A-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 540mm x 310mm
1920x1080 179.98*+
1440x1080 179.92
1400x1050 179.92
1280x1024 179.91
1280x960 179.87
1152x864 179.78
1024x768 179.84
800x600 179.71
640x480 179.43
320x240 178.06
1680x1050 179.94
1440x900 179.84
1280x800 179.74
1152x720 179.84
960x600 179.74
928x580 179.47
800x500 179.63
768x480 179.51
720x480 179.35
640x400 179.55
320x200 176.99
1600x900 179.77
1368x768 179.92
1280x720 179.72
1024x576 179.77
864x486 179.75
720x400 179.53
640x350 179.74
