Kernel: 5.18.1-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=6e538a78-4bce-4d23-922f-fcaf3b671583 rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Console: pty pts/0 DM: LightDM v: 1.30.0 Distro: Garuda Linux
Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK (MS-7C91) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.A1
date: 05/26/2022
Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2992 high: 2995 min/max: 1400/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2995 2: 2993
3: 2994 4: 2993 5: 2993 6: 2990 7: 2991 8: 2993 9: 2991 10: 2995 11: 2992
12: 2987 13: 2989 14: 2994 15: 2993 16: 2991 bogomips: 121415
STIBP: always-on, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ZOTAC driver: nvidia
v: 515.43.04 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Pascal pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 10:00.0
chip-ID: 10de:1c03 class-ID: 0300
Device-2: AMD Cezanne driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1
empty: DP-1,DP-2 bus-ID: 30:00.0 chip-ID: 1002:1638 class-ID: 0300
Display: server: X.org v: 1.21.1.3 driver: X: loaded: amdgpu
unloaded: nvidia gpu: amdgpu tty: 80x24
Monitor-1: HDMI-A-1 model: Acer G247HYL serial: <filter> built: 2018
res: 1920x1080 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Message: GL data unavailable in console. Try -G --display
Device-1: NVIDIA GP106 High Definition Audio vendor: ZOTAC
link-max: gen: 3 speed: 8 GT/s bus-ID: 10:00.1 chip-ID: 10de:10f1
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
speed: 16 GT/s bus-ID: 30:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.18.1-arch1-1 running: yes
Sound Server-3: PipeWire v: 0.3.51 running: no
lanes: 1 port: d000 bus-ID: 21:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp33s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 2a:00.0
IF: enp42s0 state: down mac: <filter>
Device-1: TP-Link UB500 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-3:3 chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Local Storage: total: 1.59 TiB used: 556.87 GiB (34.2%)
model: WDS250G2B0C size: 232.89 GiB block-size: physical: 512 B
rev: 211210WD temp: 27.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 1B6Q
model: WD10EZEX-21M2NA0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 temp: 24 C scheme: GPT
used: 57.73 GiB (24.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 27.37 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A
Fan Speeds (RPM): cpu: 1243 fan-2: 0 fan-3: 1261 fan-4: 1380 fan-5: 0
fan-6: 1067 fan-7: 963 fan-8: 0 fan-9: 0 fan-10: 0
GPU: device: nvidia screen: :0.0 temp: 31 C device: amdgpu temp: 30.0 C
Processes: 321 Uptime: 0m wakeups: 0 Memory: 27.37 GiB used: 1.2 GiB (4.4%)
Init: systemd v: 251 target: graphical.target tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 2053 lib: 516 Shell: Bash
v: 5.1.16 running-in: pty pts/0 (SSH) inxi: 3.3.16
e[1;34mGaruda (2.6.3-2):e[0m
e[1;34m System install date:e[0m
e[1;34m Last full system update:e[0m 2022-06-03
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m No/Undetected
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m lightdm.service
I know it's not particularly helpful to say "I've tried everything" but my lordy it seems I have. Sadly so many docs - in general - where left to die 20 years ago and the newer info or posts graze the topic but don't hit the mark.
So I've got (see inxi) ;p i.e. an integrated Radeon GPU so crappy AMD doesn't want to tell you what it really is. Then my main GPU. I have been running all my screens off the primary GPU forever however the system is basically new i.e. now I have the APU so I can offload rendering the flanking screens on the crappy APU which only needs to draw mail, calendar, yada yada and reduce the primary GPU strain.
There have been so many iterations of my xorg.conf it really comes back to "I've tried everything" style vagary. I've read almost anything I can get my hands on but again so much was 2009, 2014 era, anything newer is all touching on laptops and switching between GPU not running them together much less running them AS their own GPU (lots of pass through talk or cuda slave (no output)). Of course lots of nVidia slurring and don't use Xorg but xrandr --providers docs are terrible and while I can get that to work it's basically the weakest GPU sets the bar so it does the exact opposite of allowing the aging GPU to be less taxed and makes it taxing to even be idle. Wayland is better performance wise but again just dumps all the work on the primary GPU so that is again pointless. I know you can do this. Sadly I've seen tutorials on it but thanks to "the algorithm" pushing "exciting" and "fresh" content it's virtually impossible to find some old videos or docs I once found long ago.
Below is my current text xorg.conf so if you spot an issue or know of something please let me know.
Right now amdgpu & nvidia drivers are being used but X dies with
(EE) Screen 0 deleted because of no matching config section.
If you notice the xorg.conf has xrandr syntax for the AMD outputs but if I change them to DP-1 and HDMI-A-1 I get
(II) UnloadModule: "nvidia"
(II) UnloadSubModule: "wfb"
(EE) Device(s) detected, but none match those in the config file.
(EE) Fatal server error:
(EE) no screens found(EE)
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
Screen 1 "Screen1" 1920 0
Screen 2 "Screen2" 3840 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Acer G246HYL"
HorizSync 31.0 - 75.0
VertRefresh 56.0 - 75.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "Acer SA270"
HorizSync 31.0 - 84.0
VertRefresh 48.0 - 76.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor2"
ModelName "Acer G247HYL"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "amdgpu"
# Driver "modesetting"
VendorName "Advanced Micro Devices"
BoardName "Cezanne"
# BusID "PCI:30:0:0"
BusID "AXI"
Screen 0
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA GeForce GTX 1060 6GB"
BusID "PCI:16:0:0"
Screen 1
EndSection
Section "Device"
Identifier "Device2"
Driver "amdgpu"
BoardName "Cezanne"
BusID "PCI:30:0:0"
Screen 2
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "DisplayPort-1-0: 1920x1080_60 +0+0"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "HDMI-0: 1920x1080_75 +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen2"
Device "Device2"
Monitor "Monitor2"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "HDMI-A-1-0: 1920x1080_60 +0+0"
Depth 24
EndSubSection
EndSection
