Dual Boot Fedora and Garuda
  Kernel: 6.3.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=3c048265-5eb1-422d-982c-97552a7af3f8 rw rootflags=subvol=@
    loglevel=3 ibt=off
  Desktop: GNOME v: 44.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Laptop System: HP product: HP Laptop 15-da0xxx v: Type1ProductConfigId
  Mobo: HP model: 84A6 v: 80.50 serial: <superuser required> UEFI: Insyde
    v: F.38 date: 08/31/2021
  ID-1: BAT1 charge: 30.2 Wh (73.8%) condition: 40.9/40.9 Wh (100.0%)
    volts: 11.5 min: 11.3 model: Hewlett-Packard PABAS0241231 type: Li-ion
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: N/A
  Info: model: Intel Core i3-7020U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check gen: core 7 level: v3 note: check built: 2017
    process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
    microcode: 0xF2
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1925 high: 2300 min/max: 400/2300 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2300 2: 2300 3: 803
    4: 2300 bogomips: 18399
  Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
    active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
  Device-2: Chicony HP TrueVision HD Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 04f2:b65d
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: AU Optronics 0x38ed built: 2017 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: EGL/GBM Message: No known Wayland EGL/GBM data sources.
  API: ALSA v: k6.3.4-zen2-1-zen status: kernel-api tools: N/A
    lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
    vendor: Hewlett-Packard driver: rtw_8723de v: N/A modules: rtw88_8723de
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0
    chip-ID: 10ec:d723 class-ID: 0280
  Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 0bda:b009
    address: <filter>
    v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 1.36 TiB used: 7 GiB (0.5%)
    model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
    fw-rev: 234100WD temp: 34.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 4C
  ID-1: / raw-size: 101.46 GiB size: 101.46 GiB (100.00%)
    used: 6.98 GiB (6.9%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
    used: 17 MiB (2.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 101.46 GiB size: 101.46 GiB (100.00%)
  ID-4: /var/log raw-size: 101.46 GiB size: 101.46 GiB (100.00%)
  ID-5: /var/tmp raw-size: 101.46 GiB size: 101.46 GiB (100.00%)
  ID-1: swap-1 type: zram size: 11.6 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 42.0 C pch: 42.0 C mobo: N/A
  Processes: 232 Uptime: 15m wakeups: 3 Memory: available: 11.6 GiB
  used: 2.14 GiB (18.4%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1231
  libs: 385 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
  running-in: gnome-terminal inxi: 3.3.27
  System install date:     2023-05-30
  Last full system update: 2023-05-31
Hi I have Fedora and Garuda linux installed in my SSD.Every time I was booting I cannot boot into the Garuda linux in the Grub Bootloader if I select Garuda it was saying not found so everytime I booting into Garuda from boot menu option
Please help how I can boot Fedora and Garuda from the Grub Bootloader
Dual booting Garuda and Fedora might be quite challenging, at least with GRUB. See Eg:
To piggy back off of what @filo said, your best bet is to install them on separate hard drives and install Grub for each OS on their own drive. Grub on each drive can then be configured to find them. Just make sure you're using EFI for both. Nobara is definitely finicky.
