Arch based distros might not be the right choice for you if you are prioritizing DE over the distroās features.
As you know arch updates too often and having a broken DE/extension is inevitable.
I might not be a āmainā Gnome user and thatās one of the reasons why.
But we have to admit arch is not a good fit for Gnome, at least for now. You may still tweak it though by āblockingā some package updates⦠(shell & extensions)
Hopefully, @dr460nf1r3 will maintain it for other Gnome users that still want to ātryā.
MY my totally incorrect been using Arch since 2004 so I know arch inside out Arch is very robust and stable if you do things the Arch way Lol
@Mr.Donova But we have to admit arch is not a good fit for Gnome, at least for now. You may still tweak it though by āblockingā some package updates⦠(shell & extensions)
More totally inaccurate nonsense my friend Gnome is very well suited to Arch as is every other DE and WM.
As for blocking updates shell and extensions I run pure arch using testing repros for the last 10 years before that I ran stable.
Broken updates Extensions you are joking of course I canāt remember the last breakage i had and if their is a chance of one the Arch front page informs you about it, Extensions again very rare they give a problem I get them direct from Gnome Extensions.org never from a specific distro.
Also i like to test out Arch based distros and give back limited feedback to the devs, Iām not elitist as you may think just because i use pure Arch as my work rig.
For me every Arch based distro has its place they all offer a unique experience the devs are willing to share with others Why because they are based on the Arch Core base as is Arch every Arch install is unique in its own way, the the same goes for Gentoo and Slackware the user builds a distro for themselves. So spins are the same built with the same care and enthusiasm
Glad to hear that, you know what you do as an experienced user of Arch / Gnome.
As I told you, I tried Gnome a long time ago and it didn't match my work style. And I have a very bad upload rate to even try to create isos and help the community here with it or other DEs.
But I guess you could share more about your experience and help @dr460nf1r3 build isos based on Gnome.
My vision for Gnome, is to do it with useful ready-to-use extensions to help newcomers (Arch / Gnome) to understand the flexibility and functionality of Gnome (and even to know the existence of certain extensions).
NO DE will ever match every bodies work style as not every car matches our driving style its personal
For my use its just dash to dock and Arc-menu that can now be incorporated into dash to dock as dd incorparates most things needed
[edit] I will have to elaborate on this. (still on mobile, so not in absolute terminology or links)
On the website from KDE is a tutorial to set i3 as WM for KDE. I tried to set the same param to Wayfire on the āstart-plasma-waylandā. But it didnāt lite any fire. Probably due a faulty wayfire from my side. Even if I did get it lit, I donāt have a clue how to mend the keys. Especially hard as the env I tried it in, didnāt have WCM. (wich needs gtk btw)
