Hello,
request Type : Feedback + issue assestant
I am having an issue with Droidcam I downloaded it from garuda grammar and when I try to connect to my device it shows an error I tried a few things and was able to fix the camera and it's working now but my mic is not working
*devise info *
CPU : i3 5th gen
Ram: 4GB
GPU: Intel HD Graphics
Model: Lenovo G50-80
Os: garuda Dragonized.
Kernel: 6.4.3-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=377b3793-ae8b-4ea9-adac-8cc5c5f3188f rw rootflags=subvol=@
Type: Laptop System: LENOVO product: 80E5 v: Lenovo G50-80
serial: <superuser required> Chassis: type: 10 v: Lenovo G50-80
Mobo: LENOVO model: Lenovo G50-80 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: B0CNA0WW date: 09/30/2016
ID-1: BAT0 charge: 6.0 Wh (37.3%) condition: 16.1/28.5 Wh (56.4%)
power: 8.0 W volts: 14.9 min: 14.4 model: Lenovo IdeaPad type: Unknown
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 798 high: 799 min/max: 500/1900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 798 3: 798 4: 799
bogomips: 15963
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: Bison Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4 chip-ID: 5986:014f
class-ID: 0e02
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x061d built: 2014 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 389mm (15.3")
ratio: 16:9, 15:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: Mesa Intel HD Graphics 5500 (BDW
GT2) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
API: ALSA v: k6.4.3-zen1-2-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.74 status: active with: 1: pipewire-pulse
vendor: Lenovo driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b4 class-ID: 0280
Device-3: Realtek RTL8188CUS 802.11n WLAN Adapter driver: rtl8192cu
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:17
chip-ID: 0bda:8176 class-ID: 0000 serial: <filter>
IF: wlp0s20u1 state: up mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 8087:07dc
Local Storage: total: 223.57 GiB used: 10.19 GiB (4.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
tech: SSD serial: <filter> fw-rev: 0103 scheme: GPT
ID-1: / raw-size: 83.49 GiB size: 83.49 GiB (100.00%)
used: 10.16 GiB (12.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 1 GiB size: 1023 MiB (99.80%)
used: 25.9 MiB (2.5%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 83.49 GiB size: 83.49 GiB (100.00%)
ID-4: /var/log raw-size: 83.49 GiB size: 83.49 GiB (100.00%)
ID-5: /var/tmp raw-size: 83.49 GiB size: 83.49 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.74 GiB used: 1.94 GiB (51.7%)
ID-2: swap-2 type: partition size: 7.73 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda7 maj-min: 8:7
System Temperatures: cpu: 54.0 C mobo: N/A
Processes: 220 Uptime: 1h 25m wakeups: 1 Memory: total: 4 GiB
available: 3.74 GiB used: 2.36 GiB (63.2%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages:
pm: pacman pkgs: 1307 libs: 367 tools: octopi,paru,yay Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date: 2023-07-15
Last full system update: 2023-07-21
Is partially upgraded: Yes
*All the issues faced *
- error loading devise check if adb is installed (fixed)
sol: $ sudo pacman -S android-tools
$ adb kill-server
$ adb start-server
2)device is in unauthorised state (fixed)
sol: Enable USB debugging(Android)
$ adb kill-server
$ adb start-server
3)droidcam/bv4l2loopback device not found(/dev/video[0-9]) (fixed)
sol: $ sudo pacman -S v4l2loopback-dkms
$ sudo modprobe v4l2loopback exclusive_caps=1
$ ls /dev/video*
4)mic is not working (not fixed)
problem description: droid cam is able to connect with the PC and the camera is working fine but the mic is not working.
I had tried to fix this one but I was not able to fix this.
btw I forgot to mention when I connect with my mobile it shows like little pop-up stating that Audio is connected and I can see a few new audio devices named "Analog input" in my mic section but when I switch to them I don't get any audio I had tried in a different app like Obs, brave(WhatsApp web) and other the camera is working but the mic is not.
If you need any more info regarding the issue let me know.
thanks for your time.
