I am having an issue with my second NVME SSD not showing up in Lutris but it shows up fine in Dolphin and works fine in Steam… I have it auto-mounted on system startup and have even tried taking ownership of the drive and it still wont show up in Lutris. Anybody ever encountered this issue and know some ideas on how to fix it?
Thanks
Blockquote
Kernel: 6.5.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b57ccd9d-2722-4636-bfb8-ebddbe2ad009 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Desktop System: ASUS product: N/A v: N/A serial:
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING WIFI II v: Rev X.0x
serial: UEFI: American Megatrends v: 3002
date: 02/23/2023
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3614 high: 4145 min/max: 2200/4549 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3598 2: 3598
3: 3598 4: 3599 5: 3601 6: 3552 7: 3596 8: 3603 9: 3598 10: 3535 11: 3609
12: 4145 13: 3603 14: 3597 15: 3400 16: 3597 bogomips: 108804
active: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 0a:00.0 chip-ID: 1002:73df
s-diag: 1245mm (49.01")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: primary,left
model: Gigabyte G27Q serial: built: 2021 res: 2560x1440 dpi: 109
gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 685mm (27") ratio: 16:9
modes: max: 2560x1440 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Samsung S27C230
serial: built: 2014 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (navi22 LLVM
16.0.6 DRM 3.54 6.5.5-zen1-1-zen) device-ID: 1002:73df memory: 11.72 GiB
unified: no
API: Vulkan v: 1.3.264 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.1.8-arch1.1
device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.1.8-arch1.1 (LLVM
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:ab28
Device-3: SteelSeries ApS Arctis 7
lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 1038:12ad class-ID: 0300
API: ALSA v: k6.5.5-zen1-1-zen status: kernel-api with: aoss
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:0608
IF: wlp6s0 state: up mac:
IF: enp7s0 state: down mac:
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0e8d:0608
class-ID: e001 serial:
rfk-block: hardware: no software: yes address: bt-v: 5.2 lmp-v: 11
Local Storage: total: 1.36 TiB used: 796.96 GiB (57.0%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 980 500GB
lanes: 4 tech: SSD serial: fw-rev: 1B4QFXO7 temp: 40.9 C
model: WD BLACK SN770 500GB size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial:
fw-rev: 731100WD temp: 39.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 500GB SSD
tech: SSD serial: fw-rev: 06B5 scheme: GPT
used: 252.13 GiB (54.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.5 GiB used: 243.2 MiB (1.5%)
System Temperatures: cpu: 38.0 C mobo: 36.0 C gpu: amdgpu temp: 45.0 C
mem: 44.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 533 fan-3: 525 fan-4: 937 fan-5: 922
fan-6: 2561 fan-7: 0 gpu: amdgpu fan: 486
Processes: 401 Uptime: 1h 20m wakeups: 0 Memory: total: 16 GiB
available: 15.5 GiB used: 7.2 GiB (46.5%) Init: systemd v: 254
Packages: 2037 pm: pacman pkgs: 2031 libs: 573 tools: octopi,paru
pm: flatpak pkgs: 6 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
System install date: 2022-11-15
Last full system update: 2023-09-29
Failed units: fancontrol.service
