I saw multiple people online talking about how to run Minecraft Java with the dedicated graphics card. It said to make a script with the code #! /bin/sh DRI_PRIME=1 exec java "$@" but this didn't work for me. Every time I start the game from the launcher, it freezes and I have to restart my laptop. Does anybody know how I can fix this?
Here is the output of inxi -Fxxxza (I saw someone ask for it in a different thread)
System: Kernel: 5.12.1-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=9cf7a108-8742-4bdb-9c93-c2c9a68465e9 rw rootflags=subvol=@ quiet splash
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Dell product: G5 5500 v: N/A serial: <filter> Chassis: type: 10
Mobo: Dell model: 0D1G65 v: A02 serial: <filter> UEFI: Dell v: 1.7.1 date: 12/04/2020
Battery: ID-1: BAT0 charge: 44.5 Wh (92.5%) condition: 48.1/51.0 Wh (94.3%) volts: 13.1
min: 11.4 model: BYD DELL M4GWP01 type: Li-poly serial: <filter> status: Charging
CPU: Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: A5 (165) stepping: 2 microcode: E2 cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62399
Speed: 3877 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 3877 2: 4222 3: 4599
4: 4709 5: 4801 6: 4801 7: 4749 8: 4800 9: 4802 10: 4513 11: 4560 12: 4751
Graphics: Device-1: Intel UHD Graphics vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Dell driver: nvidia
v: 465.27 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f95
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:2
chip-ID: 0bda:5678 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:06c8 class-ID: 0401
Sound Server-1: ALSA v: k5.12.1-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.27 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell
driver: r8169 v: kernel port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Dell
driver: ath10k_pci v: kernel port: 3000 bus-ID: 05:00.0 chip-ID: 168c:003e
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-14:3
chip-ID: 0cf3:e007 class-ID: e001
Drives: Local Storage: total: 1.14 TiB used: 29 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC511 NVMe 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
rotation: SSD serial: <filter> rev: 11004101 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LX015-1U7172
rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
Partition: ID-1: / raw-size: 249.36 GiB size: 249.36 GiB (100.00%) used: 29 GiB (11.6%)
fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 560 KiB (0.1%)
fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 249.36 GiB size: 249.36 GiB (100.00%) used: 29 GiB (11.6%)
ID-4: /var/log raw-size: 249.36 GiB size: 249.36 GiB (100.00%) used: 29 GiB (11.6%)
ID-5: /var/tmp raw-size: 249.36 GiB size: 249.36 GiB (100.00%) used: 29 GiB (11.6%)
ID-1: swap-1 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767
ID-2: swap-2 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram5
ID-7: swap-7 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram6
ID-8: swap-8 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram7
ID-9: swap-9 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram8
ID-10: swap-10 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram9
ID-11: swap-11 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram10
ID-12: swap-12 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram11
ID-13: swap-13 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: 1024
Sensors: System Temperatures: cpu: 58.0 C mobo: N/A
Info: Processes: 324 Uptime: 19m wakeups: 3964 Memory: 15.42 GiB used: 3.65 GiB (23.7%)
Init: systemd v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages:
pacman: 1657 lib: 508 Shell: fish v: 3.2.1 default: Zsh v: 5.8 running-in: alacritty
inxi: 3.3.04
