After todays update of garuda-dr460nized 4.2.7-4 and a restart the desktop environment is not in hdr anymore. Grub and the login screen are fine, as are games but the desktop is all faded:
Turning my other display on or off does not make a difference.
Couldn’t find anything on google and I’m kinda new to this. It worked fine before the update and my monitor settings haven’t changed (I checked).
```text
Kernel: 6.8.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
root=UUID=009286cb-0285-4127-a549-89672838992b rw rootflags=subvol=@ quiet
resume=UUID=58b306a5-086f-46bd-affd-6a1e60fb5244 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0 wm: kwin_wayland vt: 1
Mobo: ASUSTeK model: ROG STRIX B650E-E GAMING WIFI v: Rev 1.xx serial: <superuser required>
part-nu: SKU uuid: <superuser required> UEFI: American Megatrends v: 1654 date: 08/25/2023
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 5 level: v4 note: check
built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x61 (97) stepping: 2
microcode: 0xA601203
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1826 high: 5500 min/max: 400/5573 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 400 2: 3349 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400
10: 4431 11: 4400 12: 3141 13: 4400 14: 400 15: 5500 16: 400 bogomips: 143991
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Micro-Star MSI driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-3 off: HDMI-A-1 empty: DP-1,DP-2,Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:73bf class-ID: 0300
Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.5 compositor: kwin_wayland
gpu: amdgpu display-ID: 0
Monitor-1: DP-3 res: 2560x1440 size: N/A modes: N/A
surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.4-arch1.2 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 6800 (radeonsi navi21 LLVM 17.0.6 DRM 3.57
6.8.4-zen1-1-zen) device-ID: 1002:73bf memory: 15.62 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD Radeon RX 6800 (RADV
NAVI21) driver: mesa radv v: 24.0.4-arch1.2 device-ID: 1002:73bf surfaces: xcb,xlib,wayland
device: 1 type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
v: 24.0.4-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 0b05:1a52 class-ID: 0300
API: ALSA v: k6.8.4-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 port: N/A bus-ID: 08:00.0 chip-ID: 8086:15f3 class-ID: 0200
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter vendor: Foxconn
driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 14c3:0616
IF: wlp9s0 state: up mac: <filter>
Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_suppl
icant
Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:6 chip-ID: 0489:e0e2 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2 lmp-v: 11 status:
Local Storage: total: 6.84 TiB used: 1.61 TiB (23.6%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung model: SSD 980 PRO 1TB size: 931.51 GiB
fw-rev: 5B2QGXA7 temp: 42.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Addlink model: M.2 PCIE G3x4 NVMe RGB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD
serial: <filter> fw-rev: ECFM12.3 temp: 27.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
fw-rev: 2B6Q scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000DM001-1CH166 size: 2.73 TiB
fw-rev: CC27 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 2TB size: 1.82 TiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 3B6Q
ID-1: / raw-size: 897.02 GiB size: 897.02 GiB (100.00%) used: 203.43 GiB (22.7%) fs: btrfs
dev: /dev/nvme0n1p2 maj-min: 259:7
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:6
ID-3: /home raw-size: 897.02 GiB size: 897.02 GiB (100.00%) used: 203.43 GiB (22.7%) fs: btrfs
ID-4: /var/log raw-size: 897.02 GiB size: 897.02 GiB (100.00%) used: 203.43 GiB (22.7%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
ID-5: /var/tmp raw-size: 897.02 GiB size: 897.02 GiB (100.00%) used: 203.43 GiB (22.7%)
ID-1: swap-1 type: zram size: 31.08 GiB used: 40 MiB (0.1%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 16 dev: /dev/zram0
ID-2: swap-2 type: partition size: 34.19 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:8
System Temperatures: cpu: 47.0 C mobo: 42.0 C gpu: amdgpu temp: 54.0 C mem: 60.0 C
Memory: total: 32 GiB note: est. available: 31.08 GiB used: 5.06 GiB (16.3%)
Processes: 370 Power: uptime: 39m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.42 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 255
Packages: pm: pacman pkgs: 2105 libs: 592 tools: octopi,pamac,paru pm: appimage pkgs: 0
Compilers: clang: 17.0.6 gcc: 13.2.1 Client: shell wrapper v: 5.2.26-release inxi: 3.3.33
Garuda (2.6.24-1):
System install date: 2024-03-21
Last full system update: 2024-04-09 ↻
