hello devs , i hope you are having a very good time , i’m trying to use google chrome for image search for this i’m dragging my image from thunar file manager and dropping it to chrome unfortunatly it is not working is there any shortcut for this cause i think copy paste does not works here and now without drag and drop i’m lost , if you have some time will you mind helping me and provide me with steps on which conf file , and what should i change to make this happen
thanks in advance .
here is my garuda-inxi
Kernel: 6.6.63-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=a145f039-cd46-43ce-94c8-f4dddfa6a370 rw rootflags=subvol=@
resume=UUID=fc25ac61-372f-48da-af41-8ff11127cc2a loglevel=3 verbose
Desktop: Hyprland v: N/A with: waybar tools: avail: swayidle,swaylock
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15
FA506IHRB_FA506IHRB v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FA506IHRB v: 1.0 serial: <filter>
uuid: c24fe503-6232-8340-8cdd-86e97147d59a UEFI: American Megatrends
v: FA506IHRB.307 date: 12/28/2022
ID-1: BAT1 charge: 61.1 Wh (88.9%) condition: 68.7/90.2 Wh (76.2%)
volts: 16.9 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: charging
Info: model: AMD Ryzen 5 4600H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
microcode: 0x8600106
desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 400 min/max: 400/4006 base/boost: 3000/4000 scaling:
driver: amd-pstate-epp governor: performance volts: 1.2 V ext-clock: 100 MHz
cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400
10: 400 11: 400 12: 400 bogomips: 71899
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 565.57.01 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:1f9d class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:1636 class-ID: 0300
temp: 39.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 322e:202c
class-ID: 0e02
Display: unspecified server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
compositor: Hyprland driver: X: loaded: amdgpu,nvidia
gpu: amdgpu display-ID: :1
Monitor-1: eDP-1 model: Najing CEC Panda 0x004d built: 2019 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
Device-2: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
Device-4: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6
API: ALSA v: k6.6.63-1-lts status: kernel-api tools: N/A
Server-2: PipeWire v: 1.2.7 status: n/a (root, process) with:
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 13d3:3563
Local Storage: total: 942.7 GiB used: 477.05 GiB (50.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 42.9 C
SMART: yes health: PASSED on: 101d 2h cycles: 3,411
read-units: 43,899,724 [22.4 TB] written-units: 19,959,937 [10.2 TB]
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
fw-rev: FXM7201Q temp: 42.9 C scheme: GPT
SMART: yes health: PASSED on: 27d 2h cycles: 3,325
read-units: 31,566,399 [16.1 TB] written-units: 22,400,006 [11.4 TB]
ID-1: / raw-size: 184.69 GiB size: 184.69 GiB (100.00%)
used: 23.61 GiB (12.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p8
maj-min: 259:12
used: 154.7 MiB (60.4%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:5
ID-3: /home raw-size: 184.69 GiB size: 184.69 GiB (100.00%)
maj-min: 259:12
ID-4: /var/log raw-size: 184.69 GiB size: 184.69 GiB (100.00%)
maj-min: 259:12
ID-5: /var/tmp raw-size: 184.69 GiB size: 184.69 GiB (100.00%)
maj-min: 259:12
ID-1: swap-1 type: zram size: 15.05 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p3 maj-min: 259:7
System Temperatures: cpu: 44.9 C mobo: 42.0 C gpu: amdgpu temp: 40.0 C
Fan Speeds (rpm): cpu: 3100
Memory: total: 16 GiB note: est. available: 15.05 GiB used: 3.9 GiB (25.9%)
Processes: 369 Power: uptime: 1h 11m states: freeze,mem,disk
suspend, test_resume image: 5.97 GiB
services: power-profiles-daemon,upowerd Init: systemd v: 256
Packages: pm: pacman pkgs: 2504 libs: 515
tools: gnome-software,pacseek,paru Compilers: clang: 18.1.8 gcc: 14.2.1
alt: 13 Shell: garuda-inxi (sudo) default: Bash v: 5.2.37 running-in: foot
inxi: 3.3.36
System install date: 2024-12-02
Last full system update: 2024-12-04 ↻
Windows dual boot: Yes
