I have seen that recently dracut is used and i dont known what it does or how. I search a little on arch wiki and it seem it handle what mkinitcpio was doing before. My issue is that some stuff doesnt load and i dont known how to accede the config of that tool. Everywhere i should have a config files i have non of them. My principal concern is loading amd-ucode and btusb, im not knwoledgebale enough to know what s missing
Kernel: 6.6.2-AMD-znver3 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver3
root=UUID=61948177-a3b3-4b12-941f-f5b21febe7f5 rw rootflags=subvol=@
quiet resume=UUID=8dfa610f-7554-4173-b2c6-1951b938f62c loglevel=3 ibt=off
Type: Laptop System: HUAWEI product: CREM-WXX9 v: M1010
Mobo: HUAWEI model: CREM-WXX9-PCB-B1 v: M1010 serial: <superuser required>
UEFI: HUAWEI v: 2.26 date: 05/13/2022
ID-1: BATT charge: 71.8 Wh (100.0%) condition: 71.8/83.1 Wh (86.3%)
volts: 12.9 min: 11.5 model: DYNAPACK HB9790T7ECW-32T0 type: Li-ion
serial: <filter> status: full cycles: 252
Device-1: ps-controller-battery-d0:27:88:69:39:8b model: N/A serial: N/A
charge: N/A status: discharging
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 689 high: 2602 min/max: 400/4463 scaling:
4: 400 5: 400 6: 400 7: 400 8: 400 9: 1645 10: 400 11: 400 12: 400 13: 400
14: 1588 15: 2602 16: 400 bogomips: 102247
vendor: Wingtech driver: amdgpu v: kernel arch: GCN-5 code: Vega
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:1638
class-ID: 0300 temp: 44.0 C
Device-2: ShineTech HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 3277:0003
Screen-1: 0 s-res: 2520x1680 s-dpi: 96 s-size: 666x444mm (26.22x17.48")
s-diag: 800mm (31.51")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x092f serial: <filter>
built: 2021 res: 2520x1680 hz: 60 dpi: 189 gamma: 1.2
size: 338x226mm (13.31x8.9") diag: 407mm (16") ratio: 3:2 modes:
max: 2520x1680 min: 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
16.0.6 DRM 3.54 6.6.2-AMD-znver3) device-ID: 1002:1638 memory: 500 MiB
unified: no
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:1638 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: AMD Renoir Radeon High Definition Audio vendor: Wingtech
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Wingtech
driver: N/A alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Wingtech
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.6.2-AMD-znver3 status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.85 status: active with: 1: pipewire-pulse
vendor: & Tele RSH driver: rtw_8822ce v: kernel modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
Device-1: Realtek 802.11ac WLAN Adapter driver: btusb v: 0.81 type: USB
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 1358:c123
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 476.94 GiB used: 391.04 GiB (82.0%)
model: PC SN730 SDBPNTY-512G size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11120000 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
used: 391.04 GiB (85.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-4: /var/log raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-5: /var/tmp raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-1: swap-1 type: zram size: 15 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.48 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 52.0 C mobo: N/A gpu: amdgpu temp: 45.0 C
Fan Speeds (rpm): fan-1: 2051 fan-2: 1954
Processes: 376 Uptime: 2h 10m wakeups: 1 Memory: total: 16 GiB note: est.
available: 15 GiB used: 6.67 GiB (44.5%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1807 libs: 543 tools: octopi,pamac,paru
Shell: fish v: 3.6.1 running-in: yakuake inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-11-22
Last full system update: 2023-11-25
I dont have this files present
/etc/dracut.conf.d/myflags.conf
that should do most of the config
and when i tried to build one i get that error
dracut: Executing: /usr/bin/dracut
dracut: Can't write to /boot/efi/d6fc98c8133142e7841c99556eef1a57/6.6.2-AMD-znver3: Directory /boot/efi/d6fc98c8133142e7841c99556eef1a57/6.6.2-AMD-znver3 does not exist or is not accessible.
