Errors in journalctl:
Jan 05 22:31:38 JoLi-HauptPC-Garuda kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_GPE._L09.D1F0], AE_NOT_FOUND (20210730/psargs-330)
Jan 05 22:31:38 JoLi-HauptPC-Garuda kernel: ACPI Error: Aborting method \_GPE._L09 due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jan 05 22:31:38 JoLi-HauptPC-Garuda kernel: ACPI Error: AE_NOT_FOUND, while evaluating GPE method [_L09] (20210730/evgpe-511)
These 3 Lines are repeated all the time (30k lines per second, probably more)
This started today at about 5pm, since then ~5 freezes, for a few seconds, then I see my bios screen.
My BIOS is up-to-date, the only thing on my system that is not up-to-date is llvm-git and llvm-libs-git which I can't update because they take ~5h to compile and then it failes (This is the case since ~2 weeks ago)
The Errors appear while running with Kernel linux-zen5.15.12.zen1-1 and linux5.15.12.arch1-1
I just installed linux-mainline5.16rc7-1 which I'll try out next.
edit I forgot inxi -Faz output:
Kernel: 5.15.12-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=ed7d29e6-cb8d-43b9-8031-6acbb474bc2d rw rootflags=subvol=@
Desktop: N/A wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux
Type: Desktop System: MSI product: MS-7926 v: 1.0
Mobo: MSI model: Z97 GAMING 9 AC (MS-7926) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.13
date: 02/16/2016
Info: model: Intel Core i7-4790K bits: 64 type: MT MCP arch: Haswell
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4580 high: 4597 min/max: 800/4600 scaling:
driver: intel_cpufreq governor: performance cores: 1: 4597 2: 4592 3: 4564
4: 4580 5: 4576 6: 4582 7: 4572 8: 4582 bogomips: 64030
Type: l1tf
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT / 6800M]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 03:00.0
chip-ID: 1002:73df class-ID: 0300
Display: server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 4864x1280 s-dpi: 96 s-size: 1283x337mm (50.5x13.3")
s-diag: 1327mm (52.2")
Monitor-1: DisplayPort-1 res: 1024x1280
Monitor-2: DisplayPort-2 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
Monitor-3: HDMI-A-0 res: 1920x1080 hz: 75 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
OpenGL: renderer: AMD Radeon RX 6700 XT (navy_flounder LLVM 14.0.0 DRM
3.42 5.15.12-arch1-1)
v: 4.6 Mesa 22.0.0-devel (git-268fc8e5c1) direct render: Yes
Device-1: Intel 9 Series Family HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
Device-2: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: Digidesign Mbox 2 type: USB driver: snd-usb-audio
bus-ID: 3-3.3:6 chip-ID: 0dba:3000 class-ID: 0102
Device-4: Micro Star USB2.0 High-Speed True HD Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-8:9 chip-ID: 0db0:7926
Sound Server-1: ALSA v: k5.15.12-arch1-1 running: yes
Sound Server-5: PipeWire v: 0.3.43 running: yes
Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel bus-ID: 05:00.0
chip-ID: 8086:08b1 class-ID: 0280
Device-2: Qualcomm Atheros Killer E220x Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: d000 bus-ID: 06:00.0
chip-ID: 1969:e091 class-ID: 0200
bus-ID: 3-7:8 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 14.33 TiB used: 975.69 GiB (6.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 QVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: MZ7LN256HMJP-000H1
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1H3Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: DT01ACA050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A7C0
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD40EZAZ-00SF3B0 size: 3.64 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD60EZAZ-00SF3B0 size: 5.46 TiB block-size: physical: 4096 B
ID-6: /dev/sdf maj-min: 8:80 type: USB vendor: Western Digital
model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 4096 B type: HDD rpm: 5400 serial: <filter> scheme: MBR
ID-7: /dev/sdg maj-min: 8:96 type: USB vendor: Western Digital
model: WD Elements SE 2623 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1026 scheme: GPT
ID-1: / raw-size: 191.11 GiB size: 191.11 GiB (100.00%)
used: 59.44 GiB (31.1%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 916.25 GiB (98.4%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/log raw-size: 191.11 GiB size: 191.11 GiB (100.00%)
ID-5: /var/tmp raw-size: 191.11 GiB size: 191.11 GiB (100.00%)
ID-1: swap-1 type: partition size: 46.87 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.3 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 56.5 C mobo: 46.0 C gpu: amdgpu temp: 53.0 C
mem: 50.0 C
Fan Speeds (RPM): cpu: 310 fan-1: 377 fan-3: 0 fan-4: 579 fan-5: 765
gpu: amdgpu fan: 0
Processes: 383 Uptime: 18m wakeups: 20589 Memory: 31.3 GiB
used: 6.78 GiB (21.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 alt: 10 clang: 14.0.0 Packages: pacman: 1986 lib: 517
flatpak: 0 Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.11
, but I'm still curious what caused it because afaik I didn't change anything at the time the problem started appearing...
