I was happily using Plasma 5 and everything worked the way I liked it. With Plasma 6, the overall experience just felt less polished and buggy. No kvantum, odd bugs here and there, and a lot of Kwin scripts still missing.
Is there any way to downgrade to Plasma 5? I tried to do a quick search earlier but it seems that it’s not recommended to do that, especially on Arch.
So if that’s not possible, how could I switch to GNOME instead? Is it just as simple as keeping a backup of my home folder and using that when I install it?
Describe your issue in detail. The more we know, the better we can help
Show us the results of your searches, and what you’ve tried
After rebooting, post the FULL output of garuda-inxi in the body of the post (not linked externally, or collapsed with the “hide details” feature)
Format terminal output (including your garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
Downgrade, no.
Restore a snapshot and avoid updating until you “hear” that KDE 6 has been extensively fixed (difficult to say…), yes.
But this is not in the philosophy of a rolling release distro.
You should accept the challenge and walk your way through the troubleshooting path…
And that’s where the garuda-inxi can provide some info.
If you want to switch to GNOME, it’s safer to reinstall.
Keep your data for sure, but not mess up with config files. KDE and GNOME are two very different beasts.
