Double Window issue
Hey everyone,
I’m super new to Garuda (and Linux in general; I just started yesterday), so please bear with me if I ask stupid questions.
I was navigating Garuda and poking around with different configurations, just seeing what I could do within reason and just learning how Garuda/Arch Linux works. Well, I somehow created this double border situation for myself, and I have absolutely no clue how I did it or how to fix it :sweat_smile:. I had checked the forums for anyone with a similar issue, but from what I could see, the solution to those posts was unchecking the ‘Support borderless’ option within Latte Dock, which I have already done. My issue feels specifically different than the ones I came across on this forum, so I wanted to make a post about it and see if, hopefully, there is a fix to my learning (growing) pains with Garuda. Since I am a new guy and can’t post pictures, below are some screenshots I took and uploaded to Imgur.
Double Window Action: Imgur: The magic of the Internet
More Double Window Action: Imgur: The magic of the Internet
Latte Dock Settings: Imgur: The magic of the Internet
Kernel: 6.6.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=ed989d3a-1309-4549-b161-9c85dbe4fc23 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 info: latte-dock
wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-I GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4802
date: 06/15/2023
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201025
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3480 high: 4340 min/max: 2200/5083 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3586 2: 3400
3: 3400 4: 3400 5: 3590 6: 3400 7: 3400 8: 3400 9: 3654 10: 3400 11: 3400
12: 3400 13: 3619 14: 3594 15: 3400 16: 3400 17: 3593 18: 3400 19: 3400
20: 3400 21: 3400 22: 3400 23: 3400 24: 3598 25: 3400 26: 3400 27: 3400
28: 3590 29: 3400 30: 3400 31: 3400 32: 4340 bogomips: 217196
Device-1: NVIDIA GA102 [GeForce RTX 3090] driver: nvidia v: 545.29.06
2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: DP-1,DP-3 empty: DP-2,HDMI-A-1 bus-ID: 0a:00.0 chip-ID: 10de:2204
Device-2: Logitech HD Webcam C615 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 046d:082c
Screen-1: 0 s-res: 2006x2160 s-dpi: 88 s-size: 579x624mm (22.80x24.57")
s-diag: 851mm (33.51")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,bottom-l
model: VG278 serial: <filter> built: 2018 res: 1920x1080 dpi: 82 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-2: DP-3 mapped: DP-4 note: disabled pos: top-right
model: Lenovo Y25-25 serial: <filter> built: 2020 res: 1920x1080 dpi: 82
gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 631mm (24.9") ratio: 16:9
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3090/PCIe/SSE2
memory: 23.44 GiB
API: Vulkan v: 1.3.269 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3090 driver: nvidia v: 545.29.06
device-ID: 10de:2204 surfaces: xcb,xlib
Device-1: NVIDIA GA102 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 10de:1aef
Device-3: Kingston HyperX QuadCast S
lanes: 1 mode: 1.1 bus-ID: 1-1.4:4 chip-ID: 0951:171d class-ID: 0300
Device-4: Logitech HD Webcam C615 driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.6.4-zen1-1-zen status: kernel-api tools: N/A
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6:5 chip-ID: 8087:0029
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 2.27 TiB used: 366.61 GiB (15.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket Q
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT30Q.3 temp: 34.9 C
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Crucial model: CT500P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 56.9 C
used: 12.2 GiB (2.6%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 62.7 GiB used: 13.5 MiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 49.5 C mobo: 49.0 C gpu: nvidia temp: 44 C
Fan Speeds (rpm): fan-1: 0 fan-2: 1322 fan-5: 0 fan-7: 0 gpu: nvidia
fan: 30%
Processes: 565 Uptime: 8h 34m wakeups: 0 Memory: total: 64 GiB note: est.
available: 62.7 GiB used: 11.04 GiB (17.6%) Init: systemd v: 255
Packages: pm: pacman pkgs: 1294 libs: 366
tools: gnome-software,octopi,pamac,paru,yay pm: appimage pkgs: 0 Shell: fish
v: 3.6.2 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-12-07
Last full system update: 2023-12-08 ↻
Failed units:            NetworkManager-wait-online.service
code tags
Are you not using the most latest ISO or did you install Latte-dock later? Either way Garuda hasn’t used latte-dock in a long time now Dr460nized migration info | Garuda Linux wiki
I downloaded the ISO from this forum in the Garuda Linux “Raptor” post (Garuda Linux "Raptor" (230305)) using the first link under ‘Where to get it :eyes:
This explains a lot; I had been watching (admittedly older) videos explaining how to navigate Garuda, and one mentioned how to configure/edit the Latte dock. Initially, I didn’t have it, so I thought I had done something wrong in my configuration. I grabbed it via the terminal, thinking Latte was supposed to be in my build. But that’s good to know; I’ll go through the steps of removing it.
Sorry, I don’t mean to be difficult, but I honestly have no clue what you mean by ‘code tags.’ Again, this is my first time using Garuda/Linux, so a lot of the very basic level terminology is still quite new to me. Would you mind explaining what you mean by code tags?
Point to
garuda-dr460nized-linux-zen-231029.iso
for long terminal output like garuda-inxi, be sure to select that part of the text of your post and hit the code tag option ( looks like </> )
Example of how it looks with code tags on output with multiple lines:
Sample text
Sample text
On very long outputs, this makes it much more readable across different devices.
@BlueN3on I edited your inxi to put it in a code block if you want to see for yourself. Kayo is right, it is way easier to read that way.
That one looks more like triple window action! :smile_cat:
