Since a recent update, the login screen appears double (on HDMI external monitor). It shows up on the screen as usual, then a 2nd copy of the login screen shows up in the upper-left corner, which looks really odd. After login, the spinning icon also shows double, then the double disappears and I'm on the desktop as normal.
But if laptop goes to the lock screen and I come back, then I have screen clipping problems, where the mouse can extend way outside the screen, making it hard to find my mouse and hard to use the bottom shortcuts bar.
Inxi
Kernel: 6.4.0-x64v1-xanmod2-2 arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod
root=UUID=58203bda-e2e2-4c32-a006-c91d933cad4e rw rootflags=subvol=@
loglevel=3 quiet intel_iommu=on iommu=pt ibt=off
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
Type: Laptop System: Acer product: Predator PH315-53 v: V1.01
Mobo: CML model: QX50_CMS v: V1.01 serial: <filter> UEFI: Insyde v: 1.01
date: 04/27/2020
ID-1: BAT1 charge: 42.6 Wh (100.0%) condition: 42.6/58.8 Wh (72.5%)
volts: 16.4 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-10750H socket: U3E1 bits: 64 type: MT MCP
arch: Comet Lake gen: core 10 level: v3 note: check built: 2020
process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 2
microcode: 0xF6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3100 high: 3601 min/max: 800/5000 base/boost: 2574/8300
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 3600 2: 3600 3: 2600 4: 2600 5: 3600 6: 3601
7: 3600 8: 3600 9: 2600 10: 2600 11: 2600 12: 2600 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: none off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 535.54.03
alternate: nvidiafb,nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: HDMI-A-2 empty: DP-1 bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0408:a061
class-ID: 0e02
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 15360x8640 s-dpi: 96
s-size: 4053x2280mm (159.57x89.76") s-diag: 4650mm (183.08")
Monitor-1: HDMI-A-2 mapped: HDMI-0 note: disabled pos: primary
model: Samsung serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 40
gamma: 1.2 size: 1210x680mm (47.64x26.77") diag: 1168mm (46") ratio: 16:9
Monitor-2: eDP-1 mapped: eDP-1-1 note: disabled model: AU Optronics 0x82ed
built: 2018 res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 394mm (15.5") ratio: 16:9 modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_cnl
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated ALI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC
lanes: 1 mode: 1.1 bus-ID: 1-1.3:6 chip-ID: 08bb:29b0 class-ID: 0300
API: ALSA v: k6.4.0-x64v1-xanmod2-2 status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.72 status: n/a (root, process) with:
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 08:00.0
chip-ID: 10ec:2600 class-ID: 0200
IF-ID-2: virbr1 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 3.19 TiB used: 1.29 TiB (40.3%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234200WD temp: 50.9 C scheme: GPT
SMART: yes health: PASSED on: 21d 15h cycles: 27
read-units: 11,856,519 [6.07 TB] written-units: 13,538,109 [6.93 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11101100 temp: 24.9 C scheme: GPT
SMART: yes health: PASSED on: 320d 2h cycles: 331
read-units: 300,298,257 [153 TB] written-units: 102,965,500 [52.7 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
family: Travelstar 7K1000 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: A3J0 temp: 42 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 5y 36d 16h cycles: 673
ID-1: / raw-size: 1.81 TiB size: 1.81 TiB (100.00%) used: 480.56 GiB (26.0%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5 maj-min: 259:5
used: 51.2 MiB (53.4%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:3
ID-3: /home raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
used: 480.56 GiB (26.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-4: /var/log raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 15.45 GiB used: 67.5 MiB (0.4%)
ID-2: swap-2 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:4
System Temperatures: cpu: 56.0 C pch: 63.0 C mobo: N/A gpu: nvidia
temp: 57 C
Processes: 366 Uptime: 11h 53m wakeups: 1 Memory: available: 15.45 GiB
used: 6.62 GiB (42.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 alt: 11/12 clang: 15.0.7 Packages:
pm: pacman pkgs: 2131 libs: 560 tools: octopi,pamac,paru pm: appimage
pkgs: 0 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date: 2021-11-24
Last full system update: 2023-07-02
Windows dual boot: Yes
