I have just installed Garuda dragonized KDE desktop and i must mention i love it's looks and feel but i am having an issue with activating it double click to open folder.
I have searched on here and didnt see this issue being addressed, i am sorry for any incoveniences caused if i am reposting this after it has been addressed
Thanks
SGS
20 March 2021 03:33
#2
Why you do not look in dolphin settings?
On the other hand, IDK what the question is
Where?
thanks for the reply, have checked settings but didnt find it, can you give me pointers please?
As for where, folders in my home, desktop and other places, i only click them once and they open and i am not comfortable with that
Catra
20 March 2021 04:01
#5
System Settings General Behavior Clicking Files or Folders
thanks a million bro, i really do appreaciate, one more thing though, how do i hide folders and icons on my desktop
Naman
20 March 2021 08:21
#7
Rename and add a dot (.) Before name.
For example, you have to hide sample.png , just rename it to .sample.png and it is hidden.
sunda
20 March 2021 08:47
#8
The demands can be so different.
The first thing I do after installing an OS is to disable the annoying double click.
With the easy-to-use Garuda, that wasn't necessary.
Thanks boss, what i mean is on KDE neon there's an option to hide the whole desktop, not just file folder so i was hoping i could achieve this on Garuda
Naman
20 March 2021 16:37
#10
Where? Btw, you can also change desktop folder location. Maybe you are trying to use that.
sunda
20 March 2021 16:51
#11
I don't know if that's what you want. You could drag the corresponding applet "Show desktop" onto the bar.
thanks @sunda and @Naman , you guys are a life saver... i appreciate you guys a lot
system
closed
22 March 2021 16:56
#13
