im using a touchpad on gnome, and everytime i try to open up a folder, the folder simply does not open. I have to right click and open. I've only seen a solution on KDE, can someone help me?
Welcome
Check settings from your file browser, try to post your garuda-inxi as text
Hi,
What is the garuda-inxi? Im new to garuda...I'm using the standart file browser (nautilus) and when i change to open a file with a single click it works, but with double click it doenst. PS: The double click also doenst work on files such as .zip, .mp4 etc.
Another thing is that i kinda need the double click to work because im trying to set-up the epsxe, and i can't open the BIOS folder.
From template
Check settings from nautilus.
Off topic, use Garuda KDE dragonized
λ garuda-inxi
Kernel: 5.16.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=91b6efbb-10f8-4406-93e2-5eb350b61faf rw rootflags=subvol=@
Desktop: GNOME 41.4 tk: GTK 3.24.33 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: LENOVO product: 80UF v: Lenovo V310-14ISK
Mobo: LENOVO model: Viking V310 SKL v: NO DPK
serial: <superuser required> UEFI: LENOVO v: 0ZCN40WW date: 07/12/2017
ID-1: BAT1 charge: 19.6 Wh (96.1%) condition: 20.4/32.0 Wh (63.8%)
volts: 16.0 min: 14.4 model: LGC L15L4A02 type: Li-ion serial: N/A
status: N/A
Info: model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEC
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 494 high: 500 min/max: 400/2000 scaling:
driver: intel_pstate governor: powersave cores: 1: 478 2: 500 3: 500 4: 500
bogomips: 15999
Device-1: Intel HD Graphics 520 vendor: Lenovo driver: i915 v: kernel
chip-ID: 8086:1921 class-ID: 0300
Device-2: Acer EasyCamera type: USB driver: uvcvideo bus-ID: 1-9:5
chip-ID: 5986:0712 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: gnome-shell driver: X:
loaded: intel unloaded: modesetting,vesa alternate: fbdev gpu: i915
display-ID: :1 screens: 1
s-diag: 414mm (16.3")
Monitor-1: eDP1 mapped: eDP-1 model: Chi Mei Innolux built: 2015
res: 1366x768 hz: 60 dpi: 112 gamma: 1.2 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Sound Server-1: ALSA v: k5.16.14-zen1-1-zen running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-8:4
chip-ID: 0cf3:e360 class-ID: e001
Local Storage: total: 465.76 GiB used: 15.76 GiB (3.4%)
model: WD5000LPCX-24VHAT0 size: 465.76 GiB block-size: physical: 4096 B
rev: 1A02 scheme: GPT
ID-1: / raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
used: 15.73 GiB (32.2%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
used: 29.8 MiB (31.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-4: /var/log raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-5: /var/tmp raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.56 GiB used: 363 MiB (10.0%)
System Temperatures: cpu: 42.0 C pch: 42.0 C mobo: N/A
Processes: 229 Uptime: 35m wakeups: 9 Memory: 3.56 GiB used: 2 GiB (56.2%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1
Packages: pacman: 1351 lib: 406 Shell: fish v: 3.3.1 default: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-03-08
Last full system update: 2022-03-16 ↻
If you include terminal outputs in your post please use the proper output format in your post.
Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
Hi,
I've already try that. When i set to double click the folder don't open. Only when i set to single click it works.
I've just installed another file browser and the double click doesn't work there either. I don't think its a software error, i might be wrong....im open to suggestions.
About the off topic suggestion, i would need to complete reinstall my system to change to KDE dragonized right?
I just saw another topic talking about this. I will reinstall the OS and use KDE. Thanks for the help.
Try restarting your Pc you havent restarted after a update
I just did and remains the same.
Ah Sorry, I saw touchpad and for some reasons I assumed you needed single click.
Could it be a matter of click Speed? See e.g.
IT WAS! Thank you so much, i was already going to buy a flash drive to reinstall the OS. I really appreciate how fast the responses where, thanks everyone!
