I was wondering if it's possible to include double bar on sway? I'm still learning about sway and I have thought of having double bar.
Kernel: 6.3.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=2a2fc659-dbc1-45d8-939b-62a902bed571 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: sway v: 1.8.1 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
Type: Laptop System: ASUSTeK product: X441NA v: 1.0
Mobo: ASUSTeK model: X441NA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X441NA.205 date: 11/18/2016
ID-1: BAT0 charge: 25.9 Wh (90.6%) condition: 28.6/34.6 Wh (82.7%)
volts: 10.8 min: 10.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: discharging cycles: 468
Info: model: Intel Pentium N4200 bits: 64 type: MCP arch: Goldmont level: v2
built: 2016 process: Intel 14nm family: 6 model-id: 0x5C (92) stepping: 9
microcode: 0x48
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 2388 min/max: 800/2500 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 2388 2: 2388 3: 2388 4: 2388 bogomips: 8755
Device-1: Intel Apollo Lake [HD Graphics 505] vendor: ASUSTeK driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5a84
Device-2: IMC Networks USB2.0 VGA UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 13d3:5a01
Display: wayland server: Xwayland v: 23.1.2 compositor: sway v: 1.8.1
driver: gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: AU Optronics 0x2d3c built: 2013 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 scale: 1 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: 1366x768
Message: No known Wayland EGL/GBM data sources. API: EGL/GBM
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
vendor: ASUSTeK driver: snd_hda_intel v: kernel alternate: snd_soc_skl,
snd_soc_avs, snd_sof_pci_intel_apl bus-ID: 00:0e.0 chip-ID: 8086:5a98
API: ALSA v: k6.3.8-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.71 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On
driver: rtl8723be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 02:00.0 chip-ID: 10ec:b723 class-ID: 0280
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 0bda:b721
Local Storage: total: 465.76 GiB used: 15.55 GiB (3.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT012-1DG142
tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM1 scheme: GPT
used: 15.55 GiB (3.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 3.66 GiB used: 104.2 MiB (2.8%)
System Temperatures: cpu: 62.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3600
Processes: 217 Uptime: 14m wakeups: 1 Memory: available: 3.66 GiB
used: 2.29 GiB (62.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1326 libs: 373 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: alacritty inxi: 3.3.27
System install date: 2023-06-16
Last full system update: 2023-06-17
