Hi) I have a problem
Garuda does not want to move hibernation.
i write command: systemctl hibernate
result: laptop reload
P.S At the installation stage, I selected hibernation mode
my system specs:
inxi -Fxxxza
Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=38d6fd90-4cf4-42e4-bee8-2c92fe11195d rw rootflags=subvol=@
loglevel=3 quiet pci=nocrs
Type: Laptop System: LENOVO product: 81WE v: IdeaPad 3 15IIL05
serial: <superuser required> Chassis: type: 10 v: IdeaPad 3 15IIL05
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: EMCN47WW date: 07/29/2021
ID-1: BAT0 charge: 13.9 Wh (47.0%) condition: 29.6/35.0 Wh (84.6%)
volts: 7.3 min: 7.5 model: SMP L16M2PB2 type: Li-poly serial: <filter>
status: Discharging cycles: 439
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xA6
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1264 high: 1964 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 1964 2: 1098 3: 949
4: 1047 bogomips: 9523
Device-1: Intel Iris Plus Graphics G1 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 04f2:b6ce class-ID: 0e02 serial: <filter>
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
driver: btusb v: 0.8 bus-ID: 1-10:3 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 238.47 GiB used: 40.67 GiB (17.1%)
model: PC SN530 SDBPMPZ-256G-1101 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21110001 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 40.67 GiB (17.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 57.0 C mobo: N/A
Processes: 223 Uptime: 18m wakeups: 1 Memory: 7.33 GiB
used: 3.14 GiB (42.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1637 lib: 396 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
