Hello together,
I'm total new to Garudo linux.
My pc has an uncommon setup of two gpus, one old gtx780 and a newer rx5700xt. The amd GPU is primary used for gaming and stuff and the gtx780 only for the OBS Studio to render the stream (just for fun, no big deal), but the rx5700xt is to weak to game @4k and also render the stream.
My problem is now: how can I switch the primary gpu under garudo?
They are both installed, but default the nvidia gpu is used for everything.
I clicked a bit through the optimus manager, but can't really find a way to switch it on the gui. I also tried running Valheim, it works, but the performance is very poor what might be the use of the wrong gpu.
Have you any idea how I can get the amd gpu working as primary?
inxi -zaF
System: Kernel: 5.14.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3a22bd02-3058-4c8c-98aa-4ed76cc588a4 rw rootflags=subvol=@ quiet splash
resume=UUID=12518e0a-eec7-4823-95e2-d7c2124d91bc loglevel=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASRock model: Z590 Extreme serial: <filter>
UEFI: American Megatrends LLC. v: P1.90 date: 07/22/2021
CPU: Info: 10-Core model: Intel Core i9-10900F bits: 64 type: MT MCP arch: Comet Lake family: 6
model-id: A5 (165) stepping: 5 microcode: EC cache: L2: 20 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 111997
Speed: 4788 MHz min/max: 800/5200 MHz Core speeds (MHz): 1: 4788 2: 4800 3: 4800 4: 4800
5: 4679 6: 4800 7: 4794 8: 4804 9: 4801 10: 4801 11: 4798 12: 4805 13: 4800 14: 4800 15: 4708
16: 4797 17: 4736 18: 4747 19: 4808 20: 4799
Graphics: Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: Sapphire Limited
driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:731f class-ID: 0300
Device-2: NVIDIA GK110 [GeForce GTX 780] driver: nvidia v: 470.74 alternate: nouveau
bus-ID: 04:00.0 chip-ID: 10de:1004 class-ID: 0300
Device-3: Elgato Systems Cam Link 4K type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 2-4:3 chip-ID: 0fd9:0066
Screen-1: 0 s-res: 7680x2160 s-dpi: 96 s-size: 2030x571mm (79.9x22.5") s-diag: 2109mm (83")
Monitor-1: DP-1 res: 3840x2160 hz: 60 dpi: 161 size: 607x345mm (23.9x13.6")
diag: 698mm (27.5")
Monitor-2: DVI-I-1-1 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6")
diag: 547mm (21.5")
Monitor-3: DP-1-0 res: 1920x1080 hz: 60 dpi: 102 size: 478x269mm (18.8x10.6")
diag: 548mm (21.6")
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.42.0 5.14.12-zen1-1-zen LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
mhwd -li
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2021.08.29 true PCI
video-optimus-manager 2021.08.29 false PCI
Warning: No installed USB configs!
inxi -Fxxxza | grep loaded
