Dolphin thumbnails not loading anymore
I’ve had my garuda Dragonized installation since February 2025.
But since May, I’ve noticed that my thumbnails in Dolphin don’t show anymore.
I’ve done following steps:
  1. deleted ~/.cache/thumbnails
  2. Checked the dolphin settings. They say "preview for every file of any size
  3. Checked multiple system packages, including kio
Then I noticed, when I open dolphin as root (right click, admin actions, open in dolphin), a new window of dolphin opens. The themes are missing, it’s white and default, but the icons are back.
So somehow my user config is corrupt? But I checked the setting in dolphin with my user and those seem correct. What am I missing?
Would be really helpful if someone knows what to do.
Thank you and best regards
Ven
Here is the ~/.config/dolphinrc file:
[$Version]
update_info=dolphin_detailsmodesettings.upd:rename-leading-padding,dolphin_detailsmodesettings.upd:move-content-display,dolphin_directorysizemode.upd:convert-directorysizecount-to-directorys
izemode
[ContentDisplay]
DirectorySizeMode=ContentSize
[ExtractDialog]
2 screens: Height=720
2 screens: Width=1548
DirHistory[$e]=$HOME/Downloads/
[General]
OpenExternallyCalledFolderInNewTab=false
ShowCopyMoveMenu=true
ShowZoomSlider=false
Version=202
ViewPropsTimestamp=2025,2,6,23,19,10.196
[IconsMode]
IconSize=160
PreviewSize=176
[KFileDialog Settings]
Places Icons Auto-resize=false
Places Icons Static Size=22
[MainWindow]
MenuBar=Disabled
[PreviewSettings]
Plugins=appimagethumbnail,audiothumbnail,windowsexethumbnail,imagethumbnail,blenderthumbnail,comicbookthumbnail,cursorthumbnail,djvuthumbnail,exe-thumbnailer,ebookthumbnail,exrthumbnail,jpeg
thumbnail,kraorathumbnail,windowsimagethumbnail,mobithumbnail,opendocumentthumbnail,directorythumbnail,gsthumbnail,rawthumbnail,fontthumbnail,svgthumbnail,ffmpegthumbs,gdk-pixbuf-thumbnailer
And here is my garuda-inxi:
╭─ven@garuda in ~ took 0s
╰─λ garuda-inxi
root=UUID=2b323d09-9d7c-4d25-90c8-669affba6d93 rw rootflags=subvol=@
rd.luks.uuid=015628c5-ef3b-437f-83aa-7808ca43135d
rd.luks.uuid=b812c7bf-201f-4aeb-8ca0-41ce41b614a5
resume=/dev/mapper/luks-b812c7bf-201f-4aeb-8ca0-41ce41b614a5 loglevel=3
splash nvidia-drm.modeset=1 quiet rd.neednet=1 ip=dhcp ibt=off
Mobo: ASUSTeK model: ROG STRIX X670E-F GAMING WIFI v: Rev 1.xx
UEFI: American Megatrends v: 1303 date: 04/26/2023
Info: model: AMD Ryzen 9 7950X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB
desc: 16x1024 KiB L3: 128 MiB desc: 1x32 MiB, 1x96 MiB
Speed (MHz): avg: 2985 min/max: 400/5763 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 2985 2: 2985 3: 2985
4: 2985 5: 2985 6: 2985 7: 2985 8: 2985 9: 2985 10: 2985 11: 2985 12: 2985
13: 2985 14: 2985 15: 2985 16: 2985 17: 2985 18: 2985 19: 2985 20: 2985
21: 2985 22: 2985 23: 2985 24: 2985 25: 2985 26: 2985 27: 2985 28: 2985
29: 2985 30: 2985 31: 2985 32: 2985 bogomips: 268286
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: ASUSTeK driver: nvidia
v: 570.144 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-4,HDMI-A-2 empty: DP-2,DP-3,HDMI-A-3
bus-ID: 01:00.0 chip-ID: 10de:2684 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASUSTeK
empty: DP-1,HDMI-A-1,Writeback-1 bus-ID: 12:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 47.0 C
alternate: fbdev,nouveau,nv,vesa dri: radeonsi gpu: nvidia,nvidia-nvswitch
d-rect: 4480x2520 display-ID: 0
Monitor-1: DP-4 pos: primary,top-left model: Samsung LC32G7xT
serial: <filter> built: 2022 res: mode: 2560x1440 hz: 240 scale: 100% (1)
dpi: 93 gamma: 1.2 size: 698x393mm (27.48x15.47") diag: 806mm (31.7")
Monitor-2: HDMI-A-2 pos: bottom-r model: Samsung C24F390 serial: <filter>
built: 2015 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia drv: amd radeonsi
platforms: device: 0 drv: nvidia device: 1 drv: radeonsi device: 2
drv: nouveau device: 3 drv: swrast gbm: drv: radeonsi surfaceless:
drv: nvidia wayland: drv: nvidia x11: drv: nvidia
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
memory: 23.43 GiB display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 10 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4090 driver: nvidia v: 570.144 device-ID: 10de:2684
surfaces: N/A device: 1 type: discrete-gpu name: NVIDIA GeForce RTX 4090
driver: nvidia v: 570.144 device-ID: 10de:2684 surfaces: N/A
Device-1: NVIDIA AD102 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:22ba class-ID: 0403
Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 12:00.1 chip-ID: 1002:1640
Device-3: HP HyperX QuadCast S driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4.4:7
chip-ID: 03f0:0294 class-ID: 0300
Device-4: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:5
API: ALSA v: k6.14.6-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
lanes: 1 bus-ID: 08:00.0 chip-ID: 14c3:0616 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0
rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.4:3
IF: enp13s0u2u4 state: down mac: <filter>
wpa_supplicant
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:4 chip-ID: 0489:e0e2
Local Storage: total: 18.21 TiB used: 12.91 TiB (70.9%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 43.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Intel model: SSDPEKKW256G8
lanes: 4 tech: SSD serial: <filter> fw-rev: 005C temp: 34.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:7 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 43.9 C
ID-4: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
ID-5: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD60EZAZ-00SF3B0 size: 5.46 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 500GB
ID-7: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST10000VN000-3AK101
size: 9.1 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
ID-8: /dev/sde maj-min: 8:64 vendor: Generic model: Flash Disk
size: 14.65 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: 8.07 scheme: MBR
ID-1: / raw-size: 1.74 TiB size: 1.74 TiB (100.00%) used: 848.17 GiB (47.6%)
fs: btrfs dev: /dev/dm-0 maj-min: 253:0
mapped: luks-015628c5-ef3b-437f-83aa-7808ca43135d
ID-2: /boot raw-size: 1.7 GiB size: 1.7 GiB (100.00%)
used: 1.03 GiB (60.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
ID-3: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
used: 603 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-4: /home raw-size: 1.74 TiB size: 1.74 TiB (100.00%)
used: 848.17 GiB (47.6%) fs: btrfs dev: /dev/dm-0 maj-min: 253:0
ID-5: /var/log raw-size: 1.74 TiB size: 1.74 TiB (100.00%)
ID-6: /var/tmp raw-size: 1.74 TiB size: 1.74 TiB (100.00%)
ID-1: swap-1 type: partition size: 78.12 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 253:1
mapped: luks-b812c7bf-201f-4aeb-8ca0-41ce41b614a5
ID-2: swap-2 type: zram size: 61.93 GiB used: 18.1 MiB (0.0%)
max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 56.8 C mobo: 49.0 C gpu: amdgpu temp: 46.0 C
Memory: total: 64 GiB available: 61.93 GiB used: 10.06 GiB (16.2%)
Processes: 886 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.67 GiB services: org_kde_powerdevil,
Packages: 2304 pm: dpkg pkgs: 0 pm: pacman pkgs: 2291 libs: 552
tools: octopi,paru pm: rpm pkgs: 0 pm: flatpak pkgs: 13 Compilers:
clang: 19.1.7 gcc: 15.1.1 alt: 13/14 Shell: garuda-inxi default: fish
System install date:     2025-02-03
Last full system update: 2025-05-22
Is partially upgraded:   Yes
Relevant software:       timeshift(custom) NetworkManager dracut nvidia-dkms
Welcome aboard. Have you done a reboot. On Wednesday I had the icons disappear and while I was trying to figure it out a few things started acting up finally making me have to power off the system. All has been fine since. I suggest a reboot to see what you get. Please also add your garuda-inxi to your first post.
Thank you. I’ve had this problem for many weeks now, so I did many reboots. And I’ve added my inxi.
Best regards
Try creating a new user, log in as them, and see if the thumbnails show up in Dolphin. If they do, check for differences in the dotfiles of the two users. Are ~/.config/dolphinrc and ~/.config/kdeglobals the same (between the two users), for example?
I’ve created a new user over the kde settings (useradd won’t apply any themes).
Dolphin thumbnails are working there. Then I’ve compared and even replaced ~/.config/kdeglobals and ~/.config/dolphinrc.
I’ve cleared the file index database and restarted indexing again-
Something’s wrong with my user then, but I dpn’t know what
I don’t know either…but KDE has always had a habit of having config files kinda scattered everywhere :wink:
well mine started working again, I’m guessing a package update fixed it.
If, you should use Garuda Settings Manager.
and
pls bios update
Thank you for the suggestion, I updated my bios just two weeks ago, it’s now at version 3003 with date 05/05/2025.
But that didn’t fix it.
The previews started working for a day, and then stopped working again.
And as it only affects my user, I think it’s a user-specific problem, not a system-problem
