After installing KDE plasma 6 yesterday, I have just noticed that the storage pane in dolphin on program load is not filled and when clicking on another folder does not seem to fit properly within the window.
I cannot attach an image as I am a new user, so sorry about that.
Sorry if this is the wrong place to report this.
Kernel: 6.7.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=267be6a5-ad12-4ac3-bc11-9f4d2d6cf145 rw rootflags=subvol=@
quiet resume=UUID=e5352c26-4279-402e-bbe8-d011b52ccf75 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.1 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: LENOVO product: 20BUA0V200 v: ThinkPad T450
Mobo: LENOVO model: 20BUA0V200 v: 0B98417 WIN serial: <filter>
part-nu: LENOVO_MT_20BU_BU_Think_FM_ThinkPad T450
uuid: ba769b81-43e8-11cb-b21b-d1056e1fd892 UEFI-[Legacy]: LENOVO
v: JBET73WW (1.37 ) date: 08/14/2019
ID-1: BAT0 charge: 12.4 Wh (79.5%) condition: 15.6/23.5 Wh (66.2%)
volts: 12.2 min: 11.4 model: LGC 45N1113 type: Li-ion serial: <filter>
status: not charging
ID-2: BAT1 charge: 16.0 Wh (79.2%) condition: 20.2/23.2 Wh (86.9%)
volts: 11.5 min: 11.1 model: SANYO 45N1775 type: Li-ion serial: <filter>
Info: model: Intel Core i5-5300U socket: BGA1168 (U3E1) note: check bits: 64
type: MT MCP arch: Broadwell gen: core 5 level: v3 note: check
built: 2015-18 process: Intel 14nm family: 6 model-id: 0x3D (61)
stepping: 4 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2782 high: 2889 min/max: 500/2900 base/boost: 2300/2900
scaling: driver: intel_cpufreq governor: schedutil volts: 1.0 V
ext-clock: 100 MHz cores: 1: 2889 2: 2836 3: 2694 4: 2709 bogomips: 18359
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: DP-1
off: eDP-1 empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1616 class-ID: 0300
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-8:5 chip-ID: 04f2:b449
Display: server: X.Org v: 23.2.4 with: Xwayland v: 23.2.4
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-1 res: 3440x1440 hz: 60 dpi: 109
size: 800x330mm (31.5x12.99") diag: 865mm (34.07") modes: N/A
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW
GT2) device-ID: 8086:1616 memory: 14.97 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 5500 (BDW GT2) driver: mesa intel v: 24.0.2-arch1.2
device-ID: 8086:1616 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.2-arch1.2 (LLVM
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
API: ALSA v: k6.7.9-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.3 status: n/a (root, process) with:
Device-1: Intel Ethernet I218-LM vendor: Lenovo driver: e1000e v: kernel
port: 3080 bus-ID: 00:19.0 chip-ID: 8086:15a2 class-ID: 0200
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:095b class-ID: 0280
IF-ID-1: t450 state: unknown speed: N/A duplex: N/A mac: N/A
IF-ID-2: wwp0s20u4 state: down mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-7:4 chip-ID: 8087:0a2a
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
Local Storage: total: 238.47 GiB used: 66.08 GiB (27.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: HX256GSSDSATA3
size: 238.47 GiB block-size: physical: 512 B logical: 512 B sata: 3.0
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 1CBN temp: 40 C
scheme: MBR
SMART: yes state: enabled health: PASSED on: 161d 6h cycles: 2477
read: 4.5 MiB written: 3 MiB
ID-1: / raw-size: 221.61 GiB size: 221.61 GiB (100.00%)
used: 66.08 GiB (29.8%) fs: btrfs block-size: 4096 B dev: /dev/sda1
maj-min: 8:1
ID-2: /home raw-size: 221.61 GiB size: 221.61 GiB (100.00%)
maj-min: 8:1
ID-3: /var/log raw-size: 221.61 GiB size: 221.61 GiB (100.00%)
maj-min: 8:1
ID-4: /var/tmp raw-size: 221.61 GiB size: 221.61 GiB (100.00%)
maj-min: 8:1
ID-1: swap-1 type: zram size: 15.33 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.86 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 48.0 C pch: 43.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 2471
Memory: total: 16 GiB available: 15.33 GiB used: 3.88 GiB (25.3%)
igpu: 32 MiB
Processes: 230 Power: uptime: 14m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.12 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1711 libs: 490 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
Garuda (2.6.23-1):
System install date: 2024-01-02
Last full system update: 2024-03-11 ↻
Failed units: nmb.service
