Dolphin skips asking for Credentials of SMB share and fails
root=UUID=d4f71312-d373-4bbb-8f13-b65701e08cf0 rw rootflags=subvol=@
Type: Desktop System: HP product: HP EliteDesk 800 G4 DM 35W v: N/A
serial: <superuser required> Chassis: type: 6 serial: <superuser required>
Mobo: HP model: 83E2 v: KBC Version 07.D1.00 serial: <superuser required>
UEFI: HP v: Q21 Ver. 02.15.00 date: 12/28/2020
Info: model: Intel Core i5-8500 bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
desc: 1x9 MiB
Speed (MHz): avg: 4000 high: 4001 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 4000 2: 4000 3: 4001
4: 4001 5: 4001 6: 4001 bogomips: 36000
Type: l1tf
STIBP: disabled, RSB filling
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Hewlett-Packard
driver: i915 v: kernel ports: active: HDMI-A-2
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:3e92 class-ID: 0300
loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915
Monitor-1: HDMI-A-2 mapped: HDMI2 model: Dell S2421HN serial: <filter>
built: 2021 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 530x300mm (20.87x11.81") diag: 604mm (23.8") ratio: 16:9 modes:
v: 4.6 Mesa 22.0.0 direct render: Yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-8:4 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 238.47 GiB used: 15.25 GiB (6.4%)
model: MZVLB256HAHQ-000H1 size: 238.47 GiB block-size: physical: 512 B
rev: EXD70H1Q temp: 57.9 C scheme: GPT
used: 15.25 GiB (6.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.41 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 30.0 C pch: 65.0 C mobo: N/A
Processes: 234 Uptime: 17m wakeups: 6 Memory: 15.41 GiB
used: 2.56 GiB (16.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1466 lib: 337 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date:     2022-04-03
Last full system update: 2022-04-04
I'm trying to open a SMB share from a Windows device, When I go to shared folders in Network in Dolphin, it does detect the share (\laptop in windows), but when I go into the folder, I get this error:
The file or folder smb://laptop.local/ does not exist.
when normally (in Manjaro) it would've asked me for credentials which would've resulted in successfully getting access to the share.
I'm using the same program (Dolphin) in both cases so i presume it's some customization by Garuda
Thanks in advance
Garuda ships with ntfsprogs-ntfs3 by default. I'm not sure if you poked around in the forum at all prior to posting, but there have been several NTFS-related issues recently which appear to be caused by a new bug in this package.
A few folks have had success replacing it with ntfs-3g, which is kind of the precursor to ntfsprogs-ntfs3. This may be the package Manjaro is using as well. Give it a shot:
First bring your system fully up to date.
garuda-update
Then install ntfs-3g and accept the replacement.
sudo pacman -S ntfs-3g
This seems to be an incomplete share. If the machine name is correct, that would at best show you the browseable/public shares/folders available. The usual scheme, that I see and use would be
smb://<SERVER>/<SHARE>
Replacing SERVER with the laptop name, and SHARE with the folder’s share name.
There are a few things to try:
  • In dolphin, click Network, at the top in ‘remote’ bar, manually type your server/share following the above format.
  • Replace server with IP in the previous item
  • If still not prompting for credentials, you can also try (using name and/or IP, also)
    smb://<USERNAME>@<SERVERNAME>/<SHARE>
There is other useful information at the following link
Archwiki Samba
Scroll down until you see the heading Client, and also some info in a sub heading KDE.
Welcome To The Community!
You can post an introduction over here --->>> Introduce Yourself
Thanks for the super quick response, unfortunately replacing the package did not work for me
Thanks but I'm a newbie to samba, where do I get the IP of the share?
It's a Windows share and all I used in windows was \\laptop and I'm guessing Dolphin on Manjaro also used smb://laptop.local/.
Edit: I do see this instead of the name sometimes ****::e928:****:****:7c3
could this be it?
I am going to answer your edit first, as that may narrow the issue quickly. That looks like it is possibly an IPv6 address, can cause problems for users, and why you are seeing .local possibly.
Try the above instructions with just (no .local)
smb://laptop
That was a quick test, but If that didn't work open a terminal (Konsole), and type
ping laptop
Again, without .local, and see if you get a response back like this
PING thorrhs (192.xxx.xxx.xxx) 56(84) bytes of data.
64 bytes from thorrhs (192.xxx.xxx.xxx): icmp_seq=1 ttl=63 time=0.508 ms
64 bytes from thorrhs (192.xxx.xxx.xxx): icmp_seq=2 ttl=63 time=0.481 ms
You are looking for what is in place of the 192.xxx.xxx.xxx above
If that fails you will need to open a Command prompt on your laptop, and type
ipconfig
Again looking for an address that matches the 192.xxx.xxx.xxx
If the above works, you might want to consider turning off IPv6. This resource at the Archwiki can help Disable IPv6
It appears laptop isn't being recognized
smb://laptop
returns
The file or folder smb://laptop/ does not exist.
and
ping laptop
returns
ping: laptop: Name or service not known
ipconfig returns
Windows IP Configuration
Ethernet adapter Ethernet:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
Wireless LAN adapter Local Area Connection* 2:
Wireless LAN adapter Local Area Connection* 12:
Wireless LAN adapter Wi-Fi:
   Link-local IPv6 Address . . . . . : xxxx::e928:xxxx:xxxx:7c3%6
   IPv4 Address. . . . . . . . . . . :  192.168.2.178
   Subnet Mask . . . . . . . . . . . : xxx.xxx.xxx.x
   Default Gateway . . . . . . . . . : 192.xxx.x.x
Ethernet adapter Bluetooth Network Connection:
laptop is meaning = vuduo2, so you must know the name of the device, look in your router :slight_smile:
192.168.178.xyz ar local IP's and you must not xxx them.
ping  -c 3 vuduo2
PING vuduo2.fritz.box (192.168.178.26) 56(84) Bytes an Daten.
64 Bytes von vuduo2.fritz.box (192.168.178.26): icmp_seq=1 ttl=64 Zeit=2.62 ms
64 Bytes von vuduo2.fritz.box (192.168.178.26): icmp_seq=2 ttl=64 Zeit=3.12 ms
64 Bytes von vuduo2.fritz.box (192.168.178.26): icmp_seq=3 ttl=64 Zeit=2.77 ms
--- vuduo2.fritz.box ping-Statistik ---
3 Pakete übertragen, 3 empfangen, 0% packet loss, time 2004ms
rtt min/avg/max/mdev = 2.623/2.839/3.122/0.208 ms
So I'm on 'DESKTOP'
and pinging to 192.168.2.178 does work
Thanks a lot everyone but I think i'll go with KDE connect instead of Samba
It's for phone/cells I think, but you can use (s)ftp://, ssh:// too :slight_smile:
Yeah I ended up using NitroShare, cross platform and over LAN
Glad to hear you found something that works for you.
And before I forget, again, Welcome to the community!
Thanks! This may be the most welcoming community I've been to <3
