Hello. Brand new Garuda KDE installation here.
root=UUID=b4ca416f-530b-4ae4-bf0b-835736bc4fe7 rw rootflags=subvol=@
Type: Desktop Mobo: Gigabyte model: B450 GAMING X v: x.x
serial: <superuser required> UEFI: American Megatrends v: F50
date: 11/27/2019
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3604 high: 3856 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3592 2: 3536
3: 3588 4: 3592 5: 3644 6: 3583 7: 3598 8: 3628 9: 3592 10: 3587 11: 3856
12: 3588 13: 3520 14: 3590 15: 3590 16: 3592 bogomips: 114984
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Gigabyte driver: nvidia
v: 470.103.01 alternate: nouveau,nvidia_drm pcie: gen: 2 speed: 5 GT/s
lanes: 8 bus-ID: 07:00.0 chip-ID: 10de:128b class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia
Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x301mm (41.73x11.85")
s-diag: 1102mm (43.38")
Monitor-1: DVI-I-1 pos: primary,right res: 1920x1080 hz: 60 dpi: 92
Monitor-2: HDMI-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
OpenGL: renderer: NVIDIA GeForce GT 710/PCIe/SSE2
v: 4.6.0 NVIDIA 470.103.01 direct render: Yes
Device-1: NVIDIA GK208 HDMI/DP Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8 bus-ID: 07:00.1
chip-ID: 10de:0e0f class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 2.3 TiB used: 505.86 GiB (21.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T9
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 001C
temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-9YN162
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC4B
scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD5000BEKT-22KA9T0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 7200 serial: <filter> scheme: GPT
ID-1: / raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
used: 13.25 GiB (6.8%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 758.06 GiB size: 758.06 GiB (100.00%)
used: 147.57 GiB (19.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-5: /var/tmp raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.36 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 16.8 C mobo: N/A gpu: nvidia temp: 60 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 64%
Processes: 399 Uptime: 7m wakeups: 0 Memory: 31.36 GiB
used: 3.42 GiB (10.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1532 lib: 364 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.1-1):
System install date: 2022-04-12
Last full system update: 2022-04-13
I'm trying to connect some Windows shares from Dolphin. There are some Windows 10 machines, and a Windows Server 2012.
I'm using default smb.conf. Only changed workgroup name and added my netbios name.
I'm able to connect using smbclient, and browse the files in share connected (tried in both Windows 10 and Windows server shares).
smbclient -N \\\\192.168.1.254\\Temp -U myuser --password="mypass"
Dolphin shows computers in network (not the 2012 server, but the windows 10 ones), but when I click in any of them, it says "the file or folder smb://whatever does not exists".
If I try manually access using smb://onecomputernetbiosname, same thing happens. And if try smb://ipadress or smb://ipaddress/share, same message again.
I've checked smb and nmb services and they are up and running, and my user is in sambashares group.
I've noticed that smb4k is not able to browse my workgroup, only shows LOCAL.
I haven't activated a firewall, and I thing Garuda Linux comes with it inactive.
EDIT: if I create a bookmark in smb4k and open it, it opens in dolphin.
Could you help me, please?
