inxi -b
Host: Garuda-Linux Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.27.7 Distro: Garuda Linux
Type: Desktop Mobo: ASRock model: X470 Taichi serial: <superuser required>
UEFI: American Megatrends v: P5.10 date: 10/20/2022
Info: 6-core AMD Ryzen 5 5600X [MT MCP] speed (MHz): avg: 4524
min/max: 550/4651
driver: amdgpu v: kernel
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.0
unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu resolution:
1: 2048x864 2: 1536x864 3: 1536x864
API: OpenGL v: 4.6 Mesa 23.1.6 renderer: AMD Radeon RX 6700 XT (navi22
LLVM 15.0.7 DRM 3.52 6.4.12-zen1-1-zen)
Device-2: Intel I211 Gigabit Network driver: igb
Local Storage: total: 2.96 TiB used: 4.14 TiB (140.1%)
Processes: 552 Uptime: 0m Memory: total: 32 GiB available: 31.26 GiB
used: 12.09 GiB (38.7%) Shell: fish inxi: 3.3.29
╭─zany130@Garuda in ~ via v3.11.3 took 1s
╰─λ garuda-inxi
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: hpet,acpi_pm parameters: amd_pstate=active
BOOT_IMAGE=/@/boot/vmlinuz-linux-linux-zen
root=UUID=53e270ad-dfd5-4874-a125-69d21ada6b8d rw rootflags=subvol=@
sysrq_always_enabled=1 amdgpu.ppfeaturemask=0xffffffff nowatchdog
nmi_watchdog=0 psi=1 initrd=@\boot\initramfs-linux-zen.img
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4007 high: 4625 min/max: 550/4651 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3699 2: 3699 3: 4624
4: 3697 5: 4625 6: 3699 7: 3698 8: 3700 9: 4625 10: 3698 11: 4625 12: 3700
bogomips: 88808
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,DP-2,HDMI-A-2 empty: HDMI-A-1
bus-ID: 10:00.0 chip-ID: 1002:73df class-ID: 0300
gpu: amdgpu d-rect: 5120x2592 display-ID: 0
Monitor-1: DP-1 pos: bottom-r res: 2048x864 size: N/A modes: N/A
Monitor-2: DP-2 pos: primary,top-left res: 1536x864 size: N/A modes: N/A
Monitor-3: HDMI-A-2 pos: middle-c res: 1536x864 size: N/A modes: N/A
LLVM 15.0.7 DRM 3.52 6.4.12-zen1-1-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:ab28
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 12:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Sony INZONE H9 / H7
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3:3 chip-ID: 054c:0e53
class-ID: 0a00
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.78 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Edimax Bluetooth Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 7392:c611
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: yes pairing: yes class-ID: 7c0104
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 44.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 38.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: GPT
used: 831.28 GiB (89.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
used: 31 MiB (10.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
System Temperatures: cpu: 76.0 C mobo: 38.0 C gpu: amdgpu temp: 53.0 C
mem: 54.0 C
Fan Speeds (rpm): cpu: 2662 fan-1: 0 fan-3: 0 fan-4: 0 fan-5: 1516
gpu: amdgpu fan: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.20 vbat: 3.28 gpu: amdgpu watts: 29.00
Processes: 545 Uptime: 0m wakeups: 2 Memory: total: 32 GiB
available: 31.26 GiB used: 12.13 GiB (38.8%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: 2734 pm: pacman pkgs: 2693 libs: 593 tools: octopi,paru
pm: appimage pkgs: 0 pm: flatpak pkgs: 41 Shell: fish v: 3.6.1
running-in: alacritty inxi: 3.3.29
System install date: 2023-07-10
Last full system update: 2023-08-26
Failed units: goldwarden.service
Attempting to run any game through Dolphin causes a failed to-create Vulkan surface error.
I tried switching to OpenGL, and the message changed to "failed to initialize video backend:
This emulator works on a Chimeria OS install on this same computer. Also, strangely, the Dolphin flatpack does not have this issue, only the arch package.
Other games and emulators such as Yuzu work without issue
