Dolphin can't mount HDD, but sudo mount can
I tried to mount my HDD disk (NTFS) after formatting my system (it worked fine before, just click the disk in Dolphin and it’s mounted) but now I’m getting this error:
An error occurred while accessing 'Dados', the system responded: The requested operation has failed: Error mounting /dev/sdb1 at /run/media/user/Dados: wrong fs type, bad option, bad superblock on /dev/sdb1, missing codepage or helper program, or other error
If I use sudo mount and mount it anywhere I can use the disk normally, even in Dolphin.
  Kernel: 6.6.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
    available: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
    root=UUID=6b5b9c23-853e-414d-a6bc-aaa81fb8b311 rw rootflags=subvol=@ quiet loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Desktop Mobo: ASRock model: H110M-HG4 serial: <superuser required>
    UEFI-[Legacy]: American Megatrends v: P7.40 date: 06/22/2018
  Info: model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake gen: core 7 level: v3
    note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9
    microcode: 0xF4
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB
    L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 2769 high: 3475 min/max: 800/3500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 3401 2: 3400 3: 800 4: 3475 bogomips: 24000
  Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] driver: nvidia v: 545.29.06
    alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of 2023-10; EOL~2026-12-xx)
    arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 ports: active: none off: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 01:00.0
    chip-ID: 10de:1c02 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2 compositor: kwin_x11 driver: X:
    loaded: nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch
  Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.02x10.71") s-diag: 554mm (21.82")
  Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: LG (GoldStar) FULL HD built: 2016
    res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2 size: 480x270mm (18.9x10.63") diag: 551mm (21.7")
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast gbm:
    drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2 memory: 2.93 GiB
  API: Vulkan v: 1.3.269 layers: 4 device: 0 type: discrete-gpu name: NVIDIA GeForce GTX 1060 3GB
    driver: nvidia v: 545.29.06 device-ID: 10de:1c02 surfaces: xcb,xlib device: 1 type: cpu
    name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
  Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
  API: ALSA v: k6.6.5-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse status: active
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8169
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
  Local Storage: total: 1.03 TiB used: 9.85 GiB (0.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Lexar model: 128GB SSD size: 119.24 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 1A scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate m
odel: ST1000DM010-2EP102 size: 931.51 GiB
    fw-rev: CC43 scheme: MBR
  ID-1: / raw-size: 38.09 GiB size: 38.09 GiB (100.00%) used: 9.85 GiB (25.9%) fs: btrfs
    dev: /dev/sda4 maj-min: 8:4
  ID-2: /home raw-size: 38.09 GiB size: 38.09 GiB (100.00%) used: 9.85 GiB (25.9%) fs: btrfs
  ID-3: /var/log raw-size: 38.09 GiB size: 38.09 GiB (100.00%) used: 9.85 GiB (25.9%) fs: btrfs
  ID-4: /var/tmp raw-size: 38.09 GiB size: 38.09 GiB (100.00%) used: 9.85 GiB (25.9%) fs: btrfs
  ID-1: swap-1 type: zram size: 15.58 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
  System Temperatures: cpu: 42.0 C pch: 42.0 C mobo: N/A gpu: nvidia temp: 43 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 27%
  Processes: 228 Uptime: 9m wakeups: 0 Memory: total: 16 GiB available: 15.58 GiB
  used: 2.4 GiB (15.4%) Init: systemd v: 255 default: graphical tool: systemctl Compilers:
  gcc: 13.2.1 Packages: pm: pacman pkgs: 1337 libs: 375 tools: octopi,paru Client: shell wrapper
  v: 5.2.21-release inxi: 3.3.31
Garuda (2.6.19-2):
  System install date:     2023-12-10
  Last full system update: 2023-12-10
Thanks for any help :smiley:
Please use search web/forum before posting help requests.
Use gnome-disk-utility, make owner. There is more than one solution.
Forgot to mention, already tried this but Take Ownership option is greyed out. Also chown $USER:$USER didn’t seems to work too.
I appreciate any other possibilities.
Check this: NTFS-3G - ArchWiki
Thanks for the info guys, I managed to fix it somehow with KDE Partition Manager, I configured the mount point again and now Dolphin behaves fine.
EDIT: To clarify the problem, somehow my mount point was not right, so I essentially just set the default mountpoint (/run/media/user/diskLabel).
I could’ve done it in the fstab file too, KDE Partition Manager just changes it in the GUI way.
