Hi everyone,
since a long time now I'm not available to access to my SYNOLOGY server by SMB protocol by using dolphin explorator.
when I click on my distant disk I receive that response : kf.kio.core: "The file or folder smb://192.168.1.xxx/ does not exist."
I can acces to my server by using command line with smbclient and with a windows computer two (so the server work well).
I have also see other logs when I start dolphin with a terminal and try to acces to the SMB folder :
smbXcli_negprot_smb1_done: No compatible protocol selected by server.
kf.kio.slaves.smb: Failed to resolve any WS transport address. This suggests that DNS resolution may be broken. (QUrl("http://{{my server}}/{{UUID here}}"))
org.kde.dolphin: could not find entry for charset= "Other encoding ()"
kf.kio.core: "The file or folder smb://{{my server}}.local/ does not exist."
Thank for your help
Kernel: 5.19.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=f327471a-c329-462b-a1dc-fca7bb7580b2 rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Type: Laptop System: LENOVO product: 20TH001AFR v: ThinkPad P1 Gen 3
Mobo: LENOVO model: 20TH001AFR v: SDK0T08861 WIN
serial: <superuser required> UEFI: LENOVO v: N2VET26W (1.11 )
date: 11/16/2020
ID-1: BAT0 charge: 72.3 Wh (100.0%) condition: 72.3/80.4 Wh (90.0%)
volts: 17.2 min: 15.4 model: SMP 5B10X19049 type: Li-poly serial: <filter>
status: full cycles: 145
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
Info: model: Intel Core i9-10885H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
stepping: 2 microcode: 0xF0
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3426 high: 4803 min/max: 800/5300 scaling:
driver: intel_pstate governor: performance cores: 1: 4800 2: 4800 3: 2400
4: 2400 5: 2400 6: 2400 7: 2400 8: 4461 9: 4800 10: 2400 11: 4777
12: 4803 13: 2400 14: 4778 15: 2400 16: 2400 bogomips: 76800
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU117GLM [Quadro T2000 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none off: DP-1
empty: DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1fb8 class-ID: 0300
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:3 chip-ID: 04f2:b6cb class-ID: fe01 serial: <filter>
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1015x285mm (39.96x11.22")
s-diag: 1054mm (41.51")
Monitor-1: DP-1 mapped: DP-1-0 note: disabled pos: primary,left
model: Samsung C27F390 serial: <filter> built: 2020 res: 1920x1080 hz: 60
dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
Monitor-2: eDP-1 pos: primary,right model-id: CSO 0x1500 built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 3840x2160
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0401
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
Sound Server-1: ALSA v: k5.19.2-zen1-1-zen running: yes
bus-ID: 1-14:7 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 953.87 GiB used: 227.94 GiB (23.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 5108AGLA
temp: 43.9 C scheme: GPT
ID-1: / raw-size: 585.94 GiB size: 585.94 GiB (100.00%) used: 227.91 GiB
(38.9%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 33.6 MiB
(13.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 585.94 GiB size: 585.94 GiB (100.00%) used: 227.91
GiB (38.9%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 585.94 GiB size: 585.94 GiB (100.00%) used: 227.91
ID-5: /var/tmp raw-size: 585.94 GiB size: 585.94 GiB (100.00%) used: 227.91
ID-1: swap-1 type: zram size: 30.98 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 68.0 C pch: 59.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 3653 fan-2: 3473
Processes: 351 Uptime: 54m wakeups: 351 Memory: 30.98 GiB used: 5.8 GiB
(18.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1524 lib: 363
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2021-11-16
Last full system update: 2022-08-21 ↻
