I’ve installed Garuda, and I got shocked how buggy the resolution was. I’ve tried to do some CVT commands but it didn’t work at all, so I tried to change to X11 and it was completely fine, like the login screen.
I’ve seen others complaining in the forum too, so I’m gladly to not be the only one ![]()
There’s no fixes for that? I’m losing something by using X11? Thanks ![]()
Kernel: 6.6.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
available: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=2f970926-472a-468c-af26-0ab4d2f90bf9 rw rootflags=subvol=@ quiet loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: ASRock model: H110M-HG4 serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: P7.40 date: 06/22/2018
Info: model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake gen: core 7 level: v3
note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9
microcode: 0xF4
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB
L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3321 high: 3340 min/max: 800/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 3340 2: 3301 3: 3340 4: 3305 bogomips: 24000
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] driver: nvidia v: 545.29.02
alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of 2023-10; EOL~2026-12-xx)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c02 class-ID: 0300
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.02x10.71") s-diag: 554mm (21.82")
Monitor-1: HDMI-0 pos: primary res: 1920x1080 hz: 60 dpi: 102 size: 480x270mm (18.9x10.63")
diag: 551mm (21.68") modes: N/A
Monitor-2: None-1-1 size-res: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.02 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2 memory: 2.93 GiB
API: Vulkan v: 1.3.269 layers: 1 device: 0 type: discrete-gpu name: NVIDIA GeForce GTX 1060 3GB
driver: nvidia v: 545.29.02 device-ID: 10de:1c02 surfaces: xcb,xlib
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.85 status: active with: 1: pipewire-pulse status: active
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
Local Storage: total: 1.03 TiB used: 8.92 GiB (0.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Lexar model: 128GB SSD size: 119.24 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 1A scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
fw-rev: CC43 scheme: MBR
ID-1: / raw-size: 38.09 GiB size: 38.09 GiB (100.00%) used: 8.92 GiB (23.4%) fs: btrfs
dev: /dev/sda4 maj-min:
