Document not found (404)
When I’m in Firedragon Settings and click any of the Learn more links, Page not found - Firedragon browser, tab pops up with ’ Document not found (404)’ as a message. I tried turning ‘Fingerprinting’ settings all unchecked (off) and restart Firedragon. There was no change in the results.
The message ‘You’re using Resist Fingerprinting (RFP), which replaces some of FireDragon’s fingerprinting protection settings. This might cause some sites to break. Learn more’ in the ‘Privacy & Security’ section, was still displayed, even with all the settings ‘off’.
I searched for a similar problem, but couldn’t find any.
╰─λ garuda-inxi
Kernel: 6.13.3-arch1-1-znver4 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver4
root=UUID=140734a7-3874-4986-a10d-41f590cdd416 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.1 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Desktop Mobo: Micro-Star model: MPG X870E CARBON WIFI (MS-7E49) v: 1.0
Megatrends LLC. v: 1.A23 date: 01/20/2025
Info: model: AMD Ryzen 9 9950X bits: 64 type: MT MCP arch: N/A level: v4
note: check family: 0x1A (26) model-id: 0x44 (68) stepping: 0
microcode: 0xB404023
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1.2 MiB desc: d-16x48 KiB; i-16x32 KiB L2: 16 MiB
desc: 16x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2981 min/max: 600/5752 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2981 2: 2981 3: 2981
4: 2981 5: 2981 6: 2981 7: 2981 8: 2981 9: 2981 10: 2981 11: 2981 12: 2981
13: 2981 14: 2981 15: 2981 16: 2981 17: 2981 18: 2981 19: 2981 20: 2981
21: 2981 22: 2981 23: 2981 24: 2981 25: 2981 26: 2981 27: 2981 28: 2981
29: 2981 30: 2981 31: 2981 32: 2981 bogomips: 275199
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: Sapphire NITRO+ driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2 empty: DP-1,
HDMI-A-1, HDMI-A-2, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c
vendor: Micro-Star MSI driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: none empty: DP-3, DP-4, DP-5, HDMI-A-3,
Writeback-2 bus-ID: 7a:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 41.0 C
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 model: MSI MPG271QX OLED built: 2024 res: mode: 2560x1440
hz: 120 scale: 100% (1) dpi: 107 gamma: 1.2 size: 606x344mm (23.86x13.54")
diag: 697mm (27.4") ratio: 16:9 modes: max: 2560x1440 min: 640x480
navi31 LLVM 19.1.7 DRM 3.60 6.13.3-arch1-1-znver4) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 8 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: N/A device-ID: 1002:744c
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:13c0
de: kscreen-console,kscreen-doctor gpu: amd-smi wl: wayland-info
Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 7a:00.1 chip-ID: 1002:1640
speed: 16 GT/s lanes: 16 bus-ID: 7a:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-10:5
chip-ID: 0db0:0b58 class-ID: 0300
API: ALSA v: k6.13.3-arch1-1-znver4 status: kernel-api tools: N/A
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 08:00.0
IF: enp8s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
Device-2: Realtek vendor: Micro-Star MSI driver: r8169 v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 1 port: c000 bus-ID: 09:00.0 chip-ID: 10ec:8126
Device-3: Qualcomm WCN785x Wi-Fi 7 320MHz 2x2 [FastConnect 7800]
vendor: Foxconn Band Simultaneous Wireless driver: ath12k_pci v: N/A
modules: ath12k pcie: gen: 3 speed: 8 GT/s lanes: 2 bus-ID: 10:00.0
chip-ID: 17cb:1107 class-ID: 0280
IF: wlp16s0 state: down mac: <filter>
wpa_supplicant
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-9:3 chip-ID: 0489:e10a
rfk-block: hardware: no software: no address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 1.82 TiB used: 239.49 GiB (12.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000T705SSD3
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: PACR5111 temp: 38.9 C
ID-1: / raw-size: 976.56 GiB size: 976.56 GiB (100.00%)
used: 239.49 GiB (24.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 976.56 GiB size: 976.56 GiB (100.00%)
ID-4: /var/log raw-size: 976.56 GiB size: 976.56 GiB (100.00%)
ID-5: /var/tmp raw-size: 976.56 GiB size: 976.56 GiB (100.00%)
ID-1: swap-1 type: zram size: 60.37 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 32
System Temperatures: cpu: 46.2 C mobo: 33.8 C
GPU: device: amdgpu temp: 49.0 C mem: 58.0 C fan: 0 watts: 37.00
device: amdgpu temp: 42.0 C
Memory: total: 60 GiB note: est. available: 60.38 GiB used: 4.5 GiB (7.5%)
Processes: 564 Power: uptime: 2h 19m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.14 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1655 libs: 439 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
Garuda (2.6.26-1.1):
System install date:     2024-11-13
Last full system update: 2025-02-19
These are dead links on “https://firedragon.garudalinux.org/” @dr460nf1r3 and @FGD.
