Docker Desktop stuck on starting.... possible cause: Itlb_multihit status: KVM: VMX disabled
I am trying to install Docker Desktop(DD).
DD gets stuck on Docker Desktop starting... and after going through the self-diagnose.json, I see this error as the root cause:
"Description": "The Docker engine runs inside a Linux VM. Therefore the host must support virtualization.\n\nCheck that hardware-assisted virtualization (either Intel VMX or AMD SVM) and Data Execution Prevention (sometimes labeled XD or Execute Disable or NX) are enabled in your BIOS.\n\nCheck your bootloader is configured to launch Hyper-V.\n\nSee https://docs.docker.com/desktop/windows/troubleshoot/#virtualization",
I followed this guide to Install and Configure KVM in ArchLinux
I have also installed QEMU and Virtual Machine Manager and tried creating Gardua as a virtual machine and it works.
Digging deeper, I see these:
vulnerable
Is that why Docker Desktop is not starting?
[🔍] × garuda-inxi
Kernel: 5.19.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=54967066-bb53-4839-ac9a-3b81fbb342dc rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 info: latte-dock, docker
Type: Desktop System: Dell product: OptiPlex 3040 v: N/A
Mobo: Dell model: 0HKCW0 v: A00 serial: <superuser required> UEFI: Dell
v: 1.14.2 date: 12/24/2020
Info: model: Intel Core i3-6100 bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 level: v3 built: 2015 process: Intel 14nm family: 6
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 800/3700 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 29598
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: HDMI-A-1
empty: DP-1, DP-2, DP-3, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:1912 class-ID: 0300
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: ViewSonic VX2452 Series
serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x240
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
Sound Server-1: ALSA v: k5.19.12-zen1-1-zen running: yes
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: enp0s20f0u1 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: MediaTek TECNO SPARK Go 2020 type: USB driver: rndis_host
v: kernel bus-ID: 1-1:41 chip-ID: 0e8d:2005 class-ID: 0a00 serial: <filter>
Report: bt-service: enabled,stopped note: tool can't run
Local Storage: total: 465.76 GiB used: 45.89 GiB (9.9%)
model: WD5000AZLX-75K2TA0 size: 465.76 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 201.01 GiB size: 201.01 GiB (100.00%) used: 45.86 GiB
(22.8%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 30.3 MiB
(31.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 201.01 GiB size: 201.01 GiB (100.00%) used: 45.86
GiB (22.8%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
ID-4: /var/log raw-size: 201.01 GiB size: 201.01 GiB (100.00%) used: 45.86
ID-5: /var/tmp raw-size: 201.01 GiB size: 201.01 GiB (100.00%) used: 45.86
ID-1: swap-1 type: zram size: 11.59 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 49.0 C pch: 56.0 C mobo: N/A
Processes: 251 Uptime: 2h 7m wakeups: 0 Memory: 11.59 GiB used: 5.07 GiB
(43.8%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1424
libs: 342 tools: pamac,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.21
Garuda (2.6.8-1):
System install date:     2022-09-03
Last full system update: 2022-10-04
Have you enabled virtualization in your bios
Yes, please
Would you like me to post the output of the DD self-diagnose.json?
Have you checked also this guide? It should be from the official site.
There's a strange requirenent to install gnome-terminal... :thinking:
Consider also that it is experimental / untested for Arch.
Yes, I have gnome-terminal installed.
One thing confuses me, the step 2 Docker docs says I should install the Docker client binaries, but I have docker installed with pacman
I'd give the guide a chance.
They provide the package, they should know what to do.
I think you should try removing your docker package and install the binaries.
At least try...
Well, I was thinking of the same thing, so I tried and ...
Thanks very much for your help...
I now have to figure out how to secure it
