After reboot, I seem to have lost the dock transparency. Seems like I saw this someplace, for some reason its like 50% now instead of 0. Ill keep digging and googling, I saw something about compositor, but that option is not in the same location now or been renamed.
Kernel: 6.6.63-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=c31be1c8-8b6d-4962-95cf-1bed6c6e8ce7 rw rootflags=subvol=@
rd.driver.pre=vfio-pci intel_iommu=on rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3 vfio_pci.ids=10de:1c82,10de:0fb9
pcie_acs_override=downstream,multifunction video=efifb:off iommu=pt
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Mobo: ASUSTeK model: TUF GAMING Z590-PLUS WIFI v: Rev 1.xx
serial: <filter> part-nu: SKU uuid: a9dd70fc-8670-2c1c-c0b7-f02f74550ad3
UEFI: American Megatrends v: 1801 date: 12/26/2022
Device-1: hid-0003:256F:C62E.0006-battery model: 3Dconnexion SpaceMouse
Wireless serial: N/A charge: N/A status: discharging
Info: model: 11th Gen Intel Core i9-11900KF socket: LGA1200 bits: 64
type: MT MCP arch: Rocket Lake gen: core 11 level: v4 note: check
built: 2021+ process: Intel 14nm family: 6 model-id: 0xA7 (167)
stepping: 1 microcode: 0x62
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB
Speed (MHz): avg: 2950 min/max: 800/5100:5300 base/boost: 3465/8500
scaling: driver: intel_pstate governor: powersave volts: 0.9 V
ext-clock: 100 MHz cores: 1: 2950 2: 2950 3: 2950 4: 2950 5: 2950 6: 2950
7: 2950 8: 2950 9: 2950 10: 2950 11: 2950 12: 2950 13: 2950 14: 2950
15: 2950 16: 2950 bogomips: 112160
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: Dell
driver: nvidia v: 565.57.01 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-2,DP-3,HDMI-A-1 empty: DP-1
bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: vfio-pci v: N/A alternate: nouveau,nvidia_drm,nvidia
non-free: 550.xx+ status: current (as of 2024-09; EOL~2026-12-xx)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 3
speed: 8 GT/s lanes: 4 link-max: lanes: 16 bus-ID: 04:00.0
chip-ID: 10de:1c82 class-ID: 0300
Device-3: Adomax Nuroum C40 driver: usbfs type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4.2:12 chip-ID: 0627:a6bf
Device-4: Logitech HD Pro Webcam C920 driver: usbfs type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4.3:22 chip-ID: 046d:082d
Display: unspecified server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
Screen-1: 0 s-res: 6400x1440 s-dpi: 92 s-size: 1767x393mm (69.57x15.47")
s-diag: 1810mm (71.27")
Monitor-1: not-matched mapped: DP-3 pos: bottom-l res: 1920x1080 hz: 60
dpi: 82 size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
Monitor-2: not-matched mapped: DP-4 pos: primary,top-center res: 2560x1440
dpi: 65024 size: 1x1mm (0.04x0.04") diag: 1mm (0.06") modes: N/A
Monitor-3: HDMI-A-1 mapped: HDMI-0 note: disabled pos: bottom-r
model: HP 27es serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 82
gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 565.57.01
memory: 11.72 GiB
API: Vulkan v: 1.3.295 layers: 4 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 565.57.01
device-ID: 10de:2504 surfaces: xcb,xlib
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: Dell
Device-3: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: vfio-pci alternate: snd_hda_intel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s bus-ID: 04:00.1 chip-ID: 10de:0fb9
Device-4: GN Netcom Jabra Engage 75 driver: usbfs type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.4.1:31 chip-ID: 0b0e:1112
Device-5: Adomax Nuroum C40 driver: usbfs type: USB rev: 2.0
Device-6: Logitech HD Pro Webcam C920 driver: usbfs type: USB rev: 2.0
Device-7: Giga-Byte ESS SABRE HiFi USB Audio Device
lanes: 1 mode: 2.0 bus-ID: 1-9.2:11 chip-ID: 0414:a00c class-ID: 0300
Device-8: Giga-Byte USB Audio driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9.3:18 chip-ID: 0414:a008
API: ALSA v: k6.6.63-1-lts status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.6 status: n/a (root, process) with:
IF-ID-1: virbr0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: vnet15 state: unknown speed: 10000 Mbps duplex: full
mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:16 chip-ID: 8087:0026
Local Storage: total: 9.48 TiB used: 401.58 GiB (4.1%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 233010WD temp: 33.9 C scheme: MBR
SMART: yes health: PASSED on: 2y 144d 10h cycles: 890
read-units: 12,811,293 [6.55 TB] written-units: 16,457,662 [8.42 TB]
ID-2: /dev/nvme1n1 maj-min: 259:9 model: PCIe SSD size: 931.51 GiB
tech: SSD serial: <filter> fw-rev: EHFM60.0 temp: 33.9 C scheme: MBR
SMART: yes health: PASSED on: 216d 11h cycles: 412
read-units: 3,522,641 [1.80 TB] written-units: 5,607,528 [2.87 TB]
ID-3: /dev/nvme2n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 38.9 C
SMART: yes health: PASSED on: 2y 3d 19h cycles: 1,835
read-units: 124,370,427 [63.6 TB] written-units: 83,122,633 [42.5 TB]
ID-4: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
family: Marvell based SSDs size: 931.52 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 00RL temp: 37 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 174d 15h cycles: 778
ID-5: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 1000GB
fw-rev: 00RL temp: 32 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 368d 13h cycles: 1005
ID-6: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SDSSDH3 512G
size: 476.94 GiB block-size: physical: 512 B logical: 512 B sata: 3.3
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 1000 temp: 31 C
scheme: MBR
SMART: yes state: enabled health: PASSED on: 4y 122d 15h cycles: 1049
read: 1.4 MiB written: 2 MiB
ID-7: /dev/sdd maj-min: 8:48 vendor: ASMedia model: T ASM236X NVME
size: 119.24 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
drive serial: <filter> fw-rev: E8FK11.C temp: 72 Celsius C scheme: GPT
SMART: yes health: PASSED on: 346d 3h cycles: 603
read-units: 2,654,328 [1.35 TB] written-units: 2,707,754 [1.38 TB]
ID-8: /dev/sde maj-min: 8:64 vendor: Samsung model: SSD 850 PRO 256GB
family: based SSDs size: 238.47 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: SSD serial: <filter> fw-rev: 0103 drive-rev: EXM04B6Q temp: 25 C
scheme: MBR
SMART: yes state: enabled health: PASSED on: 7y 131d 8h cycles: 462
written: 10.77 TiB Pre-Fail: reallocated sector: 99 threshold: 10
ID-9: /dev/sdf maj-min: 8:80 vendor: Samsung model: SSD 860 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 0301 scheme: GPT
ID-10: /dev/sdg maj-min: 8:96 vendor: Samsung model: SSD 850 PRO 256GB
sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0103
drive-rev: EXM02B6Q temp: 26 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 8y 300d 2h cycles: 81
written: 19.71 TiB
ID-11: /dev/sdh maj-min: 8:112 vendor: Samsung model: SSD 860 EVO 500GB
ID-12: /dev/sdi maj-min: 8:128 vendor: Samsung model: SSD 860 EVO 500GB
ID-13: /dev/sdj maj-min: 8:144 vendor: Samsung model: SSD 860 EVO 500G
ID-14: /dev/sdk maj-min: 8:160 model: SATA SSD size: 476.94 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
drive serial: <filter> fw-rev: 0301 drive-rev: 0964 temp: 33 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 325d 3h cycles: 58
written: 301 KiB
ID-15: /dev/sdl maj-min: 8:176 vendor: Western Digital model: WD Blue
SA510 2.5 1000GB drive model: SATA SSD size: 223.57 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1
mode: 3.2 gen-1x1 tech: N/A serial: <filter> drive serial: <filter>
SMART: yes state: enabled health: PASSED on: 326d 4h cycles: 58
written: 429 KiB
ID-16: /dev/sdm maj-min: 8:192 model: External USB3.0
drive model: SDSSDX240GG25 family: Driven SSDs size: 476.94 GiB block-size:
fw-rev: 0301 drive-rev: 0964 temp: 128 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 7y 318d 2h cycles: 278
read: 12145 GiB written: 17777 GiB Pre-Fail: retired block: 100 threshold: 3
ID-17: /dev/sdn maj-min: 8:208 model: External USB3.0
drive model: SATA SSD size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: N/A serial: <filter> drive serial: <filter> fw-rev: 0301
drive-rev: 0964 temp: 33 C scheme: MBR
written: 429 KiB
ID-1: / raw-size: 205.13 GiB size: 205.13 GiB (100.00%) used: 29 GiB (14.1%)
fs: btrfs block-size: 4096 B dev: /dev/nvme2n1p5 maj-min: 259:8
used: 26.2 MiB (27.3%) fs: vfat block-size: 512 B dev: /dev/nvme2n1p1
maj-min: 259:4
ID-3: /home raw-size: 205.13 GiB size: 205.13 GiB (100.00%)
used: 29 GiB (14.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme2n1p5
maj-min: 259:8
ID-4: /var/log raw-size: 205.13 GiB size: 205.13 GiB (100.00%)
maj-min: 259:8
ID-5: /var/tmp raw-size: 205.13 GiB size: 205.13 GiB (100.00%)
maj-min: 259:8
ID-1: swap-1 type: zram size: 31.15 GiB used: 512 KiB (0.0%) priority: 100
System Temperatures: cpu: 38.0 C mobo: 31.0 C gpu: nvidia temp: 55 C
Fan Speeds (rpm): fan-1: 0 fan-2: 1174 fan-3: 0 fan-4: 0 fan-5: 0
fan-6: 4166 fan-7: 0 gpu: nvidia fan: 0%
Memory: total: 32 GiB available: 31.16 GiB used: 17.61 GiB (56.5%)
Processes: 482 Power: uptime: 5h 45m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.41 GiB services: org_kde_powerdevil,
Packages: 1776 pm: pacman pkgs: 1770 libs: 462 tools: octopi,pamac,paru
pm: appimage pkgs: 0 pm: flatpak pkgs: 6 Compilers: clang: 18.1.8
gcc: 14.2.1 Shell: garuda-inxi (sudo) default: fish v: 3.7.1
System install date: 2024-11-23
Last full system update: 2024-11-27 ↻
/issues-assistance/15 Windows dual boot: Yes
