Hi. My dock and status bar panels is disappear after restarting system. Also i see that terminal style is change. I cant get images (i get a error that new users cant upload images).
I try to update my mirrors list and update packages:
sudo reflector --country Russia --latest 15 --age 2 --fastest 20 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
sudo pacman -Suy
And kill latte-dock and launch it again. Output of this:
[π΄] Γ latte-dock
Icon theme "gnome" not found.
What can i fix it ?
My inxl -Faz output:
inxi -Faz
System: Kernel: 5.14.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=0a5735df-e5e6-4da1-a758-613a25111d55 rw
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux base: Arch Linux
Machine: Type: Laptop System: HP product: HP Pavilion Notebook v: Type1ProductConfigId serial: <filter> Chassis: type: 10
Mobo: HP model: 845E v: 83.62 serial: <filter> UEFI: Insyde v: F.61 date: 03/29/2018
Battery: ID-1: BAT0 charge: 56.9 Wh (100.0%) condition: 56.9/56.9 Wh (100.0%) volts: 12.4 min: 10.9 model: HP Primary
type: Li-ion serial: N/A status: Full
CPU: Info: Quad Core model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake family: 6 model-id: 9E (158)
stepping: 9 microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19999
Speed: 3239 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 3239 2: 3469 3: 3493 4: 3282
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel HD Graphics 630 vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Hewlett-Packard driver: nvidia v: 470.74
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0302
Device-3: Chicony HP Wide Vision HD type: USB driver: uvcvideo bus-ID: 1-4:3 chip-ID: 04f2:b56d class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting,nvidia display-ID: :0
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 128 size: 382x215mm (15.0x8.5") diag: 438mm (17.3")
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 21.2.3 direct render: Yes
Audio: Device-1: Intel CM238 HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a171 class-ID: 0403
Sound Server-1: ALSA v: k5.14.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: 4000 bus-ID: 04:00.0 chip-ID: 8086:095a
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: br-1cad00b970ac state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-7:4 chip-ID: 8087:0a2a
Drives: Local Storage: total: 1.03 TiB used: 322.35 GiB (30.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD9SN8W-128G-1006 size: 119.24 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 3006 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 3B6Q scheme: GPT
Partition: ID-1: / raw-size: 477.12 GiB size: 477.12 GiB (100.00%) used: 322.32 GiB (67.6%) fs: btrfs dev: /dev/sdb2
maj-min: 8:18
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 32.3 MiB (33.6%) fs: vfat dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw-size: 477.12 GiB size: 477.12 GiB (100.00%) used: 322.32 GiB (67.6%) fs: btrfs dev: /dev/sdb2
maj-min: 8:18
ID-4: /var/log raw-size: 477.12 GiB size: 477.12 GiB (100.00%) used: 322.32 GiB (67.6%) fs: btrfs dev: /dev/sdb2
maj-min: 8:18
ID-5: /var/tmp raw-size: 477.12 GiB size: 477.12 GiB (100.00%) used: 322.32 GiB (67.6%) fs: btrfs dev: /dev/sdb2
maj-min: 8:18
ID-1: swap-1 type: partition size: 7.63 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb1 maj-min: 8:17
ID-2: swap-2 type: zram size: 15.52 GiB used: 1.8 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 57.0 C mobo: N/A
Info: Processes: 270 Uptime: 3m wakeups: 1 Memory: 15.52 GiB used: 3.43 GiB (22.1%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1583 lib: 464 Shell: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
