The dock or the bar at the bottom is very small. Maybe about 1/10 its original size. when go into enter edit mode it goes back to normal size by itself and stays that way till i restart then its small again. any idea whats going on? its been like this for about two weeks.
Kernel: 6.9.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=f4654eea-9d78-4538-aa68-df16e79531d4 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop Mobo: MSI model: 760GM-P34(FX) (MS-7641) v: 4.0
BIOS: American Megatrends v: 17.18B3 date: 03/13/2014
Info: model: AMD FX-4300 bits: 64 type: MT MCP arch: Piledriver level: v2
built: 2012-13 process: GF 32nm family: 0x15 (21) model-id: 2 stepping: 0
microcode: 0x6000852
L1: 192 KiB desc: d-4x16 KiB; i-2x64 KiB L2: 4 MiB desc: 2x2 MiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1617 high: 1871 min/max: 1400/3800 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1871 2: 1400
3: 1800 4: 1400 bogomips: 30401
Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: eVga.com. driver: nvidia
v: 550.78 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-04; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 2 speed: 5 GT/s lanes: 16
ports: active: none off: HDMI-A-1 empty: DP-1,DVI-I-1 bus-ID: 01:00.0
chip-ID: 10de:1380 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 750 Ti/PCIe/SSE2
memory: 1.95 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 750 Ti driver: nvidia v: 550.78 device-ID: 10de:1380
Device-1: AMD SBx00 Azalia vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: eVga.com. driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
API: ALSA v: k6.9.3-zen1-1-zen status: kernel-api tools: N/A
lanes: 1 port: e800 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-1:2 chip-ID: 0bda:8771
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter>
Info: acl-mtu: 1021:6 sco-mtu: 255:12 link-policy: rswitch hold sniff park
link-mode: peripheral accept
Local Storage: total: 3.13 TiB used: 67.04 GiB (2.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3320413AS
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: JC66 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 Series
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: AB0Q scheme: MBR
model: WD30NMZW-11GX6S1 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
speed: <unknown> tech: HDD rpm: 5400 serial: <filter> fw-rev: 4005
ID-1: / raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
used: 67.04 GiB (60.0%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
ID-3: /var/log raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
ID-4: /var/tmp raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.82 GiB used: 295 MiB (7.6%) priority: 100
System Temperatures: cpu: 21.0 C mobo: N/A
Memory: total: 4 GiB available: 3.82 GiB used: 2.19 GiB (57.4%)
Processes: 248 Power: uptime: 4m states: freeze,standby,mem,disk
suspend: s2idle avail: shallow wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 1.47 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1519 libs: 414 tools: octopi,paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.34
System install date: 2023-10-12
Last full system update: 2024-06-08
